Hi guys, recently when I turn on my laptop, I saw two Manjaro entry boot in my manjaro bootloader. And both of them is the same manjaro system. My question is, can I remove one of the two entries? And how to do that if I can?. Thank you and sorry for my english.
Give output of command sudo update-grub
After i ran update-grub
, it solved the problem. Thanks for the solution sir.
