Hello everybody…
A newbie here…
I am running Manjaro Gnome from a week and it is awesome. But I’m unable to change the lock screen wallpaper. From Settings>Background I can only change for background. And from Gnome Tweaks>Appearance> …even after I change there and lock the screen it shows the same background image (even if I change background as one picture and lock screen wallpaper as another.)
I even copied my picture to usr/share/backgrounds/
Hi @ReoKark,
Manjaro feels nice because it’s awesome!
The login background can be changed by customizing SDDM. At least that’s in KDE.
In KDE, you’d have to go to System Settings → Workspace → Startup and shutdown. There is the Login screen (SDDM) section.
So perhaps it would be similar for you.
Thanks for the help. But I couldn’t find any such options neither in System settings nor in Tweaks.
Then maybe it’s not the same for Gnoome, and in that case I can’t help further. Sorry 'bout that.
