It booted perfectly with USB, after testing I decided to install it. I’m familiar with installing linux/ubuntu distros, I decided to manual partitioning using MBR option since my laptop system uses BIOS. After that, the installation program asked me to change the partitions to GPT and adding an additional unformatted partition of 8MB with bios-grub flag enabled. I did as requested, and after finished the installation, I restarted and it didn’t boot. It was only showing me a black screen that flashes on and off every second.
Kernel: 5.15.59-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.1
root=UUID=ebe5008f-92c2-44b5-9fc5-c1497262103c rw quiet
resume=UUID=dc749f11-436c-4cee-af52-a073891a6135 udev.log_priority=3
Desktop: KDE Plasma v: 5.24.6 tk: Qt v: 5.15.5 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: SAMSUNG product: 300E4A/300E5A/300E7A/3430EA/3530EA
v: 0.1 serial: <superuser required> Chassis: type: 9 v: 0.1
Mobo: SAMSUNG model: 300E4A/300E5A/300E7A/3430EA/3530EA v: FAB1
serial: <superuser required> UEFI-[Legacy]: Phoenix v: 03QA date: 12/14/2011
RAM: total: 5.71 GiB used: 2.58 GiB (45.3%)
RAM Report: permissions: Unable to run dmidecode. Root privileges
required.
Info: model: Intel Core i3-2350M bits: 64 type: MT MCP arch: Sandy Bridge
gen: core 2 built: 2010-12 process: Intel 32nm family: 6 model-id: 0x2A (42)
stepping: 7 microcode: 0x2F
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 829 high: 924 min/max: 800/2300 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 798 2: 924 3: 798 4: 798
bogomips: 18367
Flags: acpi aperfmperf apic arat arch_perfmon avx bts clflush cmov
constant_tsc cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept est
flexpriority flush_l1d fpu fxsr ht ibpb ibrs lahf_lm lm mca mce md_clear
mmx monitor msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pebs pge pln pni popcnt pse pse36 pti pts rdtscp sep ssbd sse sse2 sse4_1
sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_deadline_timer vme
vmx vnmi vpid x2apic xsave xsaveopt xtopology xtpr
vulnerable
prctl and seccomp
Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics
vendor: Samsung Co driver: i915 v: kernel arch: Gen-6 process: Intel 32nm
built: 2011 ports: active: LVDS-1 empty: DP-1,HDMI-A-1,VGA-1
bus-ID: 00:02.0 chip-ID: 8086:0116 class-ID: 0300
Device-2: Silicon Motion WebCam SC-03FFL11939N type: USB driver: uvcvideo
bus-ID: 1-1.4:3 chip-ID: 2232:1028 class-ID: 0e02
Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,vesa gpu: i915 display-ID: :0
screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.21x7.99")
s-diag: 414mm (16.31")
Monitor-1: LVDS-1 model: Seiko Epson 0x4249 built: 2011 res: 1366x768
hz: 60 dpi: 112 gamma: 1.2 size: 309x174mm (12.17x6.85") diag: 355mm (14")
ratio: 16:9 modes: 1366x768
OpenGL: renderer: Mesa Intel HD Graphics 3000 (SNB GT2) v: 3.3 Mesa 22.1.4
direct render: Yes
vendor: Samsung Co driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:1c20 class-ID: 0403
Sound Server-1: ALSA v: k5.15.59-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.56 running: yes
Device-1: Intel Centrino Wireless-N 130 driver: iwlwifi v: kernel pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 01:00.0 chip-ID: 8086:0896
class-ID: 0280
vendor: Samsung Co driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 2000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-1: Intel Centrino Advanced-N 6230 Bluetooth adapter type: USB
driver: btusb v: 0.8 bus-ID: 2-1.3:4 chip-ID: 8086:0189 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 5 state: up address: see --recommends
Local Storage: total: 298.09 GiB used: 14.17 GiB (4.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ01ABF032
size: 298.09 GiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
type: HDD rpm: 5400 serial: <filter> rev: 1A scheme: MBR
Optical-1: /dev/sr0 vendor: TSSTcorp model: CDDVDW SN-208BB rev: SC00
dev-links: cdrom
ID-1: / raw-size: 289.29 GiB size: 283.68 GiB (98.06%) used: 14.17 GiB
(5.0%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: ebe5008f-92c2-44b5-9fc5-c1497262103c
dev: /dev/sda2 maj-min: 8:2 label: swap
uuid: dc749f11-436c-4cee-af52-a073891a6135
Hub-1: 1-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
speed: 480 Mb/s chip-ID: 8087:0024 class-ID: 0900
Device-1: 1-1.4:3 info: Silicon Motion WebCam SC-03FFL11939N type: Video
Hub-3: 2-0:1 info: Full speed or root hub ports: 2 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
Device-1: 2-1.1:3 info: YICHIP Wireless Device type: Keyboard,Mouse
power: 100mA chip-ID: 3151:1002 class-ID: 0301
Device-2: 2-1.3:4 info: Intel Centrino Advanced-N 6230 Bluetooth adapter
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
Device-3: 2-1.5:5 info: TABLET Pen type: Mouse driver: uclogic,usbhid
interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 50mA chip-ID: 256c:006e
class-ID: 0301
System Temperatures: cpu: 49.0 C mobo: N/A
Processes: 212 Uptime: 22h 1m wakeups: 1 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.1.1 clang: 14.0.6
Packages: 1202 pacman: 1197 lib: 322 flatpak: 5 Shell: Zsh v: 5.9
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.20
What did I do wrong and how can I fix it? I installed the system erasing all and skiping the manual partitioning and it worked but I need to make the partitions so I can have /home separed from the rest.
