So, after recently updating the usb drive with the new manjaro ISO my computer simply refuses to boot into the installation media for some reason, both on efi and legacy mode, I tried 2 different USB drives and both of them just display a blank gray screen, and get stuck in there. The weird thing is that it works completely fine on a little celeron from 2010 I have and Also works completely fine when I used the CatchyOS installer instead, so it seems like it’s manjaro specific. Any ideas as to what it might be?
Maybe a buggy iso, but we first have to know which one was it (full name and source) and secondly, did you check it after download for integrity? And thirdly- how do you flash the usb? We usually recommend ventoy here.
The full KDE Plasma one (manjaro-kde-26.0.4-260327-linux618.iso), Yes and balena etcher
e1 - I’ll go give ventoy a try instead and see if it helps
e2 - @soundofthunder So yeah, it really was my pc Being funky, Grub 2 mode on ventoy made it work like a charm so, many thanks
More information is needed:
- What did you use to create the USB?
- If Ventoy, did you check the settings before creation?
- Have you tried different USB types/ports?
- Which ISO is in play (be accurate; include the file name)?
- Lastly, did you check the ISO for consistency before using it?
Ventoy is generally recommended *
inxi -zv8 |
(short-form) |
inxi --filter --verbosity=8 |
(long-form) |
- man inxi (The
inximanual)
Command output should be presented as pre-formatted text in accordance with forum guidelines. ![]()
- Add
--color=0to the long-form command, or… - Change the short-form command to
inxi -zv8c0
Your privacy is respected
Note: Grave accent (or, backtick) characters are used. ![]()
- please follow this simple example:
code here.
- place text beween two rows of three (```) backtick characters to form a scrollable text box, or …
- use the </> button in the Compose window to achieve the same result.
What is a Quark?
Please avoid consecutive posts (I saw you typing). Instead, edit your existing post to include more information, and use a @mention to respond to other users;
If you type the @ character you should see a small modal dialog that allows you to select who to respond to from a dropdown list. This is convenient and helps misspelling a username, plus it notifies them of being mentioned.
For example:
(though, typically we don’t mention ourselves in that way) ![]()
Just for reference, it’s only to avoid consecutive posts that you should edit the existing post. If someone has already responded to your post, go ahead and post a normal reply.
Good to know your problem is no more. ![]()
