I have several AUR packages I use and I’m trying to update them. I installed them using git clone and makepkg. When I navigate to the git directory and run git pull, I get the following error message:
fatal: unable to access 'https://aur.archlinux.org/insync.git/': Couldn't connect to server
I get the same error for all AUR repos. I get the same error if I try to git clone a new repo.
Some solutions I have tried that I found around the Arch forum:
I tried disabling ipv6 in the Network Manager gui and on my router, but it didn’t change anything.
I made sure to update Manjaro.
I tried reinstalling ca-certificates
I reset my router to default settings and I changed my DNS settings from my ISP’s defaults to the Google DNS servers.
Manjaro provides now a file via CDN serves, like https://aur.manjaro.org/packages-meta-ext-v1.json.gz that snycs every 5 mins and has the information/update for AUR database. You can simply use the pamac build <package> without cloning and without flooding AUR server.
