Ubuntu, Pop!_OS and Linux Mint vs Hybrid Graphics. What about Manjaro?
What are Hybrid Graphics?
Some laptops come with two graphics cards: one for use in applications that require a lot of computing power such as games, called the discrete GPU, and one that is less powerful, but conserves energy, called the integrated GPU. The integrated GPU is often embedded in the CPU, hence the name. This concept is called Hybrid Graphics.
Ubuntu 20.04 LTS
Those of you with hybrid graphics are now able to launch applications using the discrete GPU from within GNOME Shell, via the ‘Launch on Discrete GPU’ menu item. This works both for AMD and NVIDIA GPUs.
Summary
Summary
Pop!_OS 20.04
Previously on Pop!_OS: Laptops with Intel and NVIDIA graphics have the power to Jekyll and Hyde between integrated graphics and the dGPU.
Now on Pop!_OS: In addition to switching between Intel and NVIDIA graphics, you can choose Hybrid Graphics from the system menu. In Hybrid Graphics mode, your laptop runs on the battery-saving Intel GPU and only uses the NVIDIA GPU for applications you designate. To do this, simply right-click on the app icon and select “Launch using Dedicated Graphics Card”.
Summary
Application developers and maintainers can configure their applications to use the dedicated GPU by default by setting the following flag in their .desktop file:
  • X-KDE-RunOnDiscreteGpu=true
Linux Mint 20
Linux Mint 20 will feature improved support for NVIDIA Optimus.
In Mint 20, the NVIDIA prime applet now shows your GPU renderer and you can select which card to switch to straight from its menu.
Summary
Screenshot_2020-06-06 Monthly News – May 2020 – The Linux Mint Blog
The NVIDIA “On-Demand” profile is also now fully supported both in MATE (by mintmenu) and in Cinnamon (by the Cinnamon menu applet). When you run in that mode, it is your Intel card which renders the session and a menu option is available to let you offload a particular application to your NVIDIA card.
Select an application in the menu, right-click and select “Run with NVIDIA GPU”. It’s that simple.
Summary
Screenshot_2020-06-06 Monthly News – May 2020 – The Linux Mint Blog(1)
From the command-line, two new commands are available to offload to GLX or to Vulkan:
  • nvidia-optimus-offload-glx
  • nvidia-optimus-offload-vulkan
To boost compatibility and make it easier to boot Linux Mint 20 in live mode without NVIDIA drivers, “nomodeset” was added to the “Compatibility Mode”.
And finally, what about Manjaro? :slight_smile:
Did you try it, does it actually work or is it just another option what works only on developers machines? :slight_smile:
Manjaro uses optimus-manager - available in the repo.
sudo pacman -Syu optimus-manager
Please: Extensive use of cold text are noisy and so are images - please hide them using the :gear: -> Hide Details form the post toolbar.
