I have been using Manjaro as my main distro in dual boot for the last couple of days. Rather new to this as a computing student but I was understanding how to use it fine.
I needed to move the desktop computer upstairs and I believe it only went into suspend mode rather than shut down before the power was unplugged.
Then when I go back onto the computer when it’s setup upstairs I can log into Ubuntu fine with internet connection but when I get to manjaro KDE login screen, I can put in my password but then it freezes when I press login (Mouse continues to work but can’t click on anything, the login button looks pressed but just freezes)
I’m struggling to work out how to fix it from many articles on the internet. I know this one is arch but hoped it might be similar: [attached [bbs . archlinux . org / viewtopic.php?id=152284]
I don’t think I understnad the steps that were made to fix this?
Thank you very much for the help,
Peter
Finished File System Check on /dev/disk/by-uuid/…
Mounting /boot/efi…
Unrecognised mount option “umask=077” or missing value
[FAILED] Failed to mount /boot/efi
See ‘systemctl status boot-efi.mount’ for details.
[DEPEND] Dependence failed for Local File Systems.
