Typing in dmenu closes it
i3
#1
Hi folks,
I have found similar issues in previous threads. Tried changing the locale then locale-gen and removing the cache in ~/.cache/. Both methods didn’t avail.
Any ideas?
Edit: I can click with the cursor to navigate through the menu and open apps, but can’t do anything with typing.
#2
Having the same exact problem after the recent update.
very similar to the existing problem you have mention, both for Dmenu and Morc-menu.
And none of the previous solutions works. Again like you have described.
Tried launch Dmenu from terminal. NOTHING ~ just nothing.
#4
As seen in Dmenu / morc-menu broken by latest update? there is a patch already up which fixes this problem.
