Two swappiness configuration files
I searched the forum for information about swappiness optimization, and created a 100-manjaro.conf file in /etc/sysctl.d/, with vm.swappiness=10 inside.
The file does its job, but next to it another 100-manjaro.conf.safe has appeared, which I don’t know if I should keep or delete. I’m not sure if I created it unintentionally, since I had some problems with the nano commands.
*.conf.safe or *.conf~ are not used by system, you can remove it
if backup by nano , he add ~ to extension :wink:
Thanks for the answer, although I still have the doubt whether I created it or the system itself :slightly_smiling_face:
