Tvheadend on Odroid N2
Hello.
I'm newbie.
Is it possible to install tvheadend on odroid n2.
Hello and Welcome to the Manjaro Community.
After doing some online search about tvheadend and odroid, I dont think it is working yet for N2. Their official website shows that they have arm64 support but only for Ubuntu 16.04 Ref. Link
Maybe you need to compile it yourself and give it a try ? Also I think it is best to check with the tvheadend forum, it is more likely to get an accurate response there.
Cheers.
Why not?!
N2 terminal:
$ pamac build tvheadend
bring up your compiling with root password.
after install type:
sudo systemctl enable tvheadend
sudo systemctl start tvheadend
with sudo systemctl status tvheadend you see IP&Port for your browsing
tested on Raspi3B+ with 19.06 arm
It works fine for me!!!!!!
Thank you...
@Lila-Kuh
How to compile and install oscam emu ?
Build Oscam 11537 git from AUR
Open your terminal:
git clone https://aur.archlinux.org/oscam-git.git
cd oscam-git
makepkg -si
After auto install ..
sudo systemctl enable oscam
sudo systemctl start oscam
regards ... The Cow
Other question: why you use Odroid N2 with ManjaroaARM for Multimedia (Video/Live-TV)?
Coreelec (fork from Libreelec) is a nice Kodi Build for Odroid's with 4k HW-Support... you can install addons TVH-Server & oscam-server & etc ...
Because​ Coreelec or libreelec. some feed sport live channels on asiasat5 100.5 e cannot be decoded 4:2:2 10bit, yuv422p10le.
Sometime I want to watch football laliga and serie italy feed 4:2:2 10bit.
and Coreelec team said 10bit H264 cannot be decoded in hardware on Amlogic.
But I tried run recorded video from 4:2:2 on manjaro with mpv player it's perfect for me.
You can see my videos link below.
Sorry for my bad English.
Thank you for reply.
