Tuxguitar doesn't work
Tuxguitar doesn’t work anymore and I don’t know what to do…reinstall does not work.
Here’s the terminal.
[iwakura@iwakura-hp290g4microtowerpc ~]$ tuxguitar
Errore: LinkageError durante il caricamento della classe principale org.herac.tuxguitar.app.TGMainSingleton
	java.lang.UnsatisfiedLinkError: /usr/lib/jvm/java-11-openjdk/lib/libnio.so: /usr/lib/jvm/java-11-openjdk/lib/libnio.so: undefined symbol: reuseport_available
Check the comments here:
https://aur.archlinux.org/packages/tuxguitar
Have you tried to rebuild this (AUR) package?
pamac build tuxguitar
It build well but it does not work…
The result is the same at the first post.
It is a known bug and the workaround is mentioned in the first comment on the AUR page.
bug
https://bugs.archlinux.org/task/77183
AUR page:
"Just edit tuxguitar.sh and append a line
LD_LIBRARY_PATH=${LD_LIBRARY_PATH}:/usr/lib/jvm/default/lib/server
will perfectly solve my problem."
Thank’s a lot.
It worked.
