If I try to start HDMI-Output with arandr
, I get the following error message:
XRandR fehlgeschlagen: XRandR returned error code 1: b’xrandr: Configure crtc 4 failed\nX Error of failed request: Badvalue (integer parameter out of range for operation}\n Major opcode of failed request: 140 (RANDR}n Minor opcode of failed request: 21 (RRSetCrtcConfig)n Value in failed request: 0x0\n Serialnumber of failed request: 67\n Current serial number in output stream:62
There is nothing shown at the HDMI monitor.
$ inxi -G
Graphics: Device-1: NVIDIA TU116M [GeForce GTX 1650 Ti Mobile] driver: nvidia v: 455.45.01
Device-2: Advanced Micro Devices [AMD/ATI] Renoir driver: amdgpu v: kernel
Device-3: Chicony HD Webcam type: USB driver: uvcvideo
Display: x11 server: X.Org 1.20.10 driver: amdgpu,ati,nvidia unloaded: modesetting,nouveau
resolution: 1920x1080~144Hz
OpenGL: renderer: AMD RENOIR (DRM 3.39.0 5.9.11-3-MANJARO LLVM 11.0.0) v: 4.6 Mesa 20.2.3
$ nvidia-smi
Fri Dec 25 09:22:08 2020
| NVIDIA-SMI 455.45.01 Driver Version: 455.45.01 CUDA Version: 11.1 |
| GPU Name Persistence-M| Bus-Id Disp.A | Volatile Uncorr. ECC |
| Fan Temp Perf Pwr:Usage/Cap| Memory-Usage | GPU-Util Compute M. |
| | | MIG M. |
| 0 GeForce GTX 165... Off | 00000000:01:00.0 Off | N/A |
| N/A 42C P8 5W / N/A | 8MiB / 3911MiB | 0% Default |
| | | N/A |
| Processes: |
| GPU GI CI PID Type Process name GPU Memory |
| ID ID Usage |
| 0 N/A N/A 1297 G /usr/lib/Xorg 4MiB |
$ mhwd -li
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-hybrid-amd-nvidia-455xx-prime 2020.10.04 false PCI
$ head -n 9999 /etc/X11/xorg.conf.d/*?
==> /etc/X11/xorg.conf.d/00-keyboard.conf <==
# Read and parsed by systemd-localed. It's probably wise not to edit this file
# manually too freely.
Section "InputClass"
Identifier "system-keyboard"
MatchIsKeyboard "on"
Option "XkbLayout" "de"
EndSection
==> /etc/X11/xorg.conf.d/90-mhwd.conf <==
## Generated by mhwd - Manjaro Hardware Detection
$ nvidia-xconfig --query-gpu-info
Number of GPUs: 1
GPU #0:
Name : GeForce GTX 1650 Ti
UUID : GPU-370cdb3d-a0f6-7a66-e454-74335917946b
PCI BusID : PCI:1:0:0
Number of Display Devices: 1
Display Device 0 (TV-4):
EDID Name : SAMSUNG
Minimum HorizSync : 26.000 kHz
Maximum HorizSync : 68.000 kHz
Minimum VertRefresh : 24 Hz
Maximum VertRefresh : 75 Hz
Maximum PixelClock : 230.000 MHz
Maximum Width : 1920 pixels
Maximum Height : 1080 pixels
Preferred Width : 1360 pixels
Preferred Height : 768 pixels
Preferred VertRefresh : 60 Hz
Physical Width : 160 mm
Physical Height : 90 mm
$ xrandr
Screen 0: minimum 320 x 200, current 3280 x 1080, maximum 16384 x 16384
eDP connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 382mm x 215mm
1920x1080 144.00*+ 60.00
1680x1050 144.00
1280x1024 144.00
1440x900 144.00
1280x800 144.00
1280x720 144.00
1024x768 144.00
800x600 144.00
640x480 144.00
DP-1-0 disconnected
DP-1-1 disconnected
DP-1-2 disconnected
DP-1-3 disconnected
HDMI-1-0 connected
1360x768 60.02 +
1920x1080 59.94 50.00 29.97 25.00 23.98
1280x720 60.00 59.94 50.00
1024x768 75.03 70.07 60.00
800x600 75.00 72.19 60.32
720x576 50.00
720x480 59.94
640x480 75.00 72.81 59.94
If I connect a mini displayport to HDMI adapter, the laptop screen freezes and the external monitor is showing nothing.
