I’m considering the Tuxedo InfinityBook Pro 14, which has an option for a 3K display. The machine defaults to their OS, which I think is a version of Ubuntu, but I’m not sure. Anyway, was wondering if anyone has any thoughts about how well Manjaro supports a 3K display.
thx
Reid
If it works with 1 Linux distro, it should work with any Linux distro.
It’s not how well Manjaro supports 3K displays, it’s the matter of how well the DE (eg. Gnome or KDE Plasma) supports it.
And I think both of them should work just fine with the 3K display.
thx…that’s good to know. I use Gnome. DE=Display Environment ?
No, actually DE stands for Desktop Environment.
About as well as other distributions.
But if you run a window manager like i3 or Openbox - you will need to tweak your settings for it to be readable on a 14" display.
I run an old Thinkpad T550 with a 15" display and a default Openbox is tiny - and I bet much more tiny on a 14" display.
