You can copy from the terminal, just select the text and press Ctrl+Shift+C, that should work. Alternatively run inxi -Fazy > ~/inxi.out
and then open the inxi.out
file in your home dirctory and then post that.
Whatâs the output of optimus-manager --status
and optimus-manager --version
~]$ inxi -Fazy
Kernel: 5.8.18-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64
root=UUID=577d859d-2418-4f13-9eab-5685d065a8e7 rw quiet apparmor=1
Desktop: KDE Plasma 5.20.4 tk: Qt 5.15.2 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Laptop System: ASUSTeK product: TUF Gaming FA506II_FX506II v: 1.0
serial:
Mobo: ASUSTeK model: FA506II v: 1.0 serial:
UEFI: American Megatrends v: FA506II.309 date: 07/02/2020
ID-1: BAT1 charge: 39.3 Wh condition: 40.4/48.2 Wh (84%) volts: 4.0/11.9
model: ASUS A32-K55 type: Li-ion serial: N/A status: Charging
Info: 8-Core model: AMD Ryzen 7 4800H with Radeon Graphics bits: 64
type: MT MCP arch: Zen family: 17 (23) model-id: 60 (96) stepping: 1
microcode: 8600104 L2 cache: 4096 KiB
bogomips: 92666
Speed: 2395 MHz min/max: 1400/2900 MHz boost: enabled Core speeds (MHz):
1: 1397 2: 1398 3: 1397 4: 1397 5: 1397 6: 1396 7: 1398 8: 1397 9: 1397
10: 1397 11: 1397 12: 1397 13: 1532 14: 1593 15: 1397 16: 1397
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW,
Device-1: NVIDIA TU117M [GeForce GTX 1650 Ti Mobile] vendor: ASUSTeK
driver: nvidia v: 455.45.01 alternate: nouveau,nvidia_drm bus ID: 01:00.0
chip ID: 10de:1f95
Device-2: AMD Renoir vendor: ASUSTeK driver: amdgpu v: kernel
bus ID: 05:00.0 chip ID: 1002:1636
Device-3: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus ID: 1-4:2 chip ID: 13d3:56a2 serial:
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11
driver: amdgpu,ati,nvidia unloaded: modesetting,nouveau
alternate: fbdev,nv,vesa display ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP res: 1920x1080 hz: 144 dpi: 142 size: 344x194mm (13.5x7.6")
diag: 395mm (15.5")
OpenGL: renderer: AMD RENOIR (DRM 3.38.0 5.8.18-1-MANJARO LLVM 11.0.0)
v: 4.6 Mesa 20.2.3 direct render: Yes
Device-1: AMD vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus ID: 05:00.1 chip ID: 1002:1637
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor
driver: snd_rn_pci_acp3x v: kernel alternate: snd_pci_acp3x bus ID: 05:00.5
chip ID: 1022:15e2
Device-3: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus ID: 05:00.6 chip ID: 1022:15e3
Sound Server: ALSA v: k5.8.18-1-MANJARO
vendor: ASUSTeK driver: r8169 v: kernel port: e000 bus ID: 02:00.0
chip ID: 10ec:8168
IF: enp2s0 state: down mac:
Device-2: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
vendor: AzureWave driver: rtw_8822ce v: N/A modules: rtw88_8822ce port: d000
bus ID: 03:00.0 chip ID: 10ec:c822
IF: wlp3s0 state: up mac:
Local Storage: total: 476.94 GiB used: 16.08 GiB (3.4%)
ID-1: /dev/nvme0n1 vendor: Kingston model: OM8PCP3512F-AB size: 476.94 GiB
block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4
serial: rev: ECFK52.3 scheme: GPT
ID-1: / raw size: 476.64 GiB size: 468.16 GiB (98.22%)
used: 16.08 GiB (3.4%) fs: ext4 dev: /dev/nvme0n1p2
System Temperatures: cpu: 64.1 C mobo: N/A gpu: amdgpu temp: 44.0 C
Processes: 312 Uptime: 40m Memory: 15.13 GiB used: 2.30 GiB (15.2%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: pacman: 1273 lib: 367
flatpak: 0 Shell: Bash v: 5.0.18 running in: konsole inxi: 3.1.08
[roblovesjosie@rob-tufgamingfa506iifx506ii ~]$ /home/roblovesjosie/Desktop/gpu 2 .png
Not sure where do i find that info please.
Those are command that you need to run in a terminal.
optimus-manager --status and optimus-manager
âversion?
usage: optimus-manager [-h] [-v] [âstatus] [âprint-mode] [--print-next-mode]
[--print-startup] [--switch MODE] [--set-
startup` STARTUP_MODE]
[âtemp-config PATH] [âunset-temp-config]
[âno-confirm] [âcleanup]
optimus-manager: error: unrecognized arguments: and optimus-manager --version?
You need to run them separately. Copy and paste optimus-manager --status
, then run that; after that copy and paste optimus-manager --version
, then run that.
Ok thankyou for your patience .
ok i get these errors ,
ERROR: the latest GPU setup attempt failed at Xorg pre-start hook.
Log at /var/log/optimus-manager/switch/switch-20201210T083526.log
Config parsing : error in option
"startup_auto_battery_mode`" in section [optimus] : invalid`
value âintegratedâ
Config parsing : unknown section [amd]. Ignoring.
Cannot execute command because of previous errors.
Ok i cant see the version ?
Got to go out for a bit brb.
Iâve just seen that you installed optimus-manager
, and not optimus-manager-git
. Since you have an AMD+NVIDIA configuration, only optimus-manager-git
will work at the moment. So please install optimus-manager-git
by running pamac build optimus-manager-git
(or you can use yay
, etc.).
Oh fantastic thanks do i need to remove the optimus- manager?
Itâll automatically be removed when you install optimus-manager-git
You donât need to edit the build files. Answer the first question with n
, and the second one with y
. So now press Ctrl+X, and then answer the next question with y
You donât know your password?
