Hello Masters
I’m trying to use alltray to minimize a WhatsApp web Chromium app to tray… I can do it but only if I launch the web app first and call alltray after
What I really liked to do is to launch it with alltray…
NOTE: I have 3 different Chromium profiles so when I type this:
error: command line parsing failed (Unknown option --user-data-dir=/home/ricardo/.config/chromium/Default/)
To me it seems the error message is saying that it’s an unknown option to alltray and not to chromium… so perhaps the chromium args need to “wraped” or something like that?
Also, if I run just /usr/bin/chromium --user-data-dir=/home/ricardo/.config/chromium/Default/ --app-id=hnpfjngllnobngcgfapefoaidbinmjnm it gives me a new empty profile??? It only works if I use --profile-directory option and not --user-data-dir … now I’m confused
No problem BTW here’s my WhatsApp web app minimized to tray
P.S: I know, I know, I have updates to do… don’t want to update my Thunderbird just yet because some extensions are not working on v78 (going to edit pacman.conf now to ignore that package ;))
