Hello,
I’m using 6.10.13-3-MANJARO #1 SMP PREEMPT_DYNAMIC Tue Oct 8 03:24:49 UTC 2024 x86_64 GNU/Linux
I experience intermittend connection issues, I tried to find the issue maybe it is related to my router but any kind of trying to find a workaround or configure it correctly is not solving my issue.
I got a AX6100 Asus router mesh system (2x Asus RTAX92U) I’m sitting 3m away from my mesh router using my notbook and I do not move during the isses occurs.
I checked out dmesg and found those entries:
[19309.076266] wlp5s0: Limiting TX power to 20 (20 - 0) dBm as advertised by fc:34:97:76:48:f0
[19344.086782] wlp5s0: Limiting TX power to 23 (23 - 0) dBm as advertised by fc:34:97:91:65:34
[19454.514207] wlp5s0: Limiting TX power to 20 (20 - 0) dBm as advertised by fc:34:97:91:65:31
[20291.495907] wlp5s0: Limiting TX power to 30 (30 - 0) dBm as advertised by fc:34:97:91:65:38
[22087.518955] wlp5s0: Limiting TX power to 20 (20 - 0) dBm as advertised by fc:34:97:91:65:31
[22194.378939] wlp5s0: Limiting TX power to 20 (20 - 0) dBm as advertised by fc:34:97:76:48:f0
[22210.776172] wlp5s0: Limiting TX power to 30 (30 - 0) dBm as advertised by fc:34:97:91:65:38
These MAC-Adresses belong to Mesh-Head and Mesh client
I’m not sure why my router sends those advertisements, for me it sounds like the router is commanding the client to go to power safe mode.
I tried to have a workaround by:
entering those config commands in /etc/NetworkManaher/conf.d/default-powersafe.conf:
[connection]
wifi.powersave = 2
wifi.scan-rand-mac-address=no
Addtionaly I tried to add this to my stored network:
sudo nmcli connection modify mySSID wifi.powersave 2
The entries in dmesg are still there, and the WIFI connection is still dropping intermittendly.
Addtiionally I’ve taken a look at:
journalctl --unti=nmcli:
15 01:54:38 ASUSFA627XS NetworkManager[418683]: <info> [1731632078.6883] device (wlp5s0): Activation: starting connection 'Bastiknet3 Auto' (12a854d0-ca66-4ae1-b7a3-cf62459f846f)
Nov 15 01:54:38 ASUSFA627XS NetworkManager[418683]: <info> [1731632078.6884] device (wlp5s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Nov 15 01:54:38 ASUSFA627XS NetworkManager[418683]: <info> [1731632078.6884] manager: NetworkManager state is now CONNECTING
Nov 15 01:54:38 ASUSFA627XS NetworkManager[418683]: <info> [1731632078.7239] device (wlp5s0): set-hw-addr: reset MAC address to 10:68:38:AA:F8:5A (preserve)
Nov 15 01:54:38 ASUSFA627XS NetworkManager[418683]: <info> [1731632078.8464] device (wlp5s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Nov 15 01:54:38 ASUSFA627XS NetworkManager[418683]: <info> [1731632078.8466] device (wlp5s0): Activation: (wifi) access point 'Bastiknet3 Auto' has security, but secrets are required.
Nov 15 01:54:38 ASUSFA627XS NetworkManager[418683]: <info> [1731632078.8466] device (wlp5s0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Nov 15 01:54:38 ASUSFA627XS NetworkManager[418683]: <info> [1731632078.8467] device (wlp5s0): supplicant interface state: inactive -> interface_disabled
Nov 15 01:54:38 ASUSFA627XS NetworkManager[418683]: <info> [1731632078.8467] device (p2p-dev-wlp5s0): supplicant management interface state: inactive -> interface_disabled
Nov 15 01:54:38 ASUSFA627XS NetworkManager[418683]: <info> [1731632078.8505] device (wlp5s0): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
Nov 15 01:54:38 ASUSFA627XS NetworkManager[418683]: <info> [1731632078.8506] device (wlp5s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Nov 15 01:54:38 ASUSFA627XS NetworkManager[418683]: <info> [1731632078.8507] device (wlp5s0): Activation: (wifi) connection 'Bastiknet3 Auto' has security, and secrets exist. No new secre>
Nov 15 01:54:38 ASUSFA627XS NetworkManager[418683]: <info> [1731632078.8508] Config: added 'ssid' value 'Bastiknet3'
Nov 15 01:54:38 ASUSFA627XS NetworkManager[418683]: <info> [1731632078.8509] Config: added 'scan_ssid' value '1'
Nov 15 01:54:38 ASUSFA627XS NetworkManager[418683]: <info> [1731632078.8509] Config: added 'bgscan' value 'simple:30:-65:300'
Nov 15 01:54:38 ASUSFA627XS NetworkManager[418683]: <info> [1731632078.8509] Config: added 'key_mgmt' value 'SAE FT-SAE'
Nov 15 01:54:38 ASUSFA627XS NetworkManager[418683]: <info> [1731632078.8509] Config: added 'psk' value '<hidden>'
Nov 15 01:54:38 ASUSFA627XS NetworkManager[418683]: <info> [1731632078.8509] Config: added 'ieee80211w' value '2'
Nov 15 01:54:38 ASUSFA627XS NetworkManager[418683]: <info> [1731632078.8637] device (wlp5s0): supplicant interface state: interface_disabled -> inactive
Nov 15 01:54:38 ASUSFA627XS NetworkManager[418683]: <info> [1731632078.8637] device (p2p-dev-wlp5s0): supplicant management interface state: interface_disabled -> inactive
Nov 15 01:54:39 ASUSFA627XS NetworkManager[418683]: <info> [1731632079.0637] device (wlp5s0): supplicant interface state: inactive -> authenticating
Nov 15 01:54:39 ASUSFA627XS NetworkManager[418683]: <info> [1731632079.0637] device (p2p-dev-wlp5s0): supplicant management interface state: inactive -> authenticating
Nov 15 01:54:39 ASUSFA627XS NetworkManager[418683]: <info> [1731632079.1088] device (wlp5s0): supplicant interface state: authenticating -> associating
Nov 15 01:54:39 ASUSFA627XS NetworkManager[418683]: <info> [1731632079.1089] device (p2p-dev-wlp5s0): supplicant management interface state: authenticating -> associating
Nov 15 01:54:39 ASUSFA627XS NetworkManager[418683]: <info> [1731632079.2481] device (wlp5s0): supplicant interface state: associating -> disconnected
Nov 15 01:54:39 ASUSFA627XS NetworkManager[418683]: <info> [1731632079.2481] device (p2p-dev-wlp5s0): supplicant management interface state: associating -> disconnected
Nov 15 01:54:40 ASUSFA627XS NetworkManager[418683]: <info> [1731632080.3619] device (wlp5s0): supplicant interface state: disconnected -> scanning
Nov 15 01:54:40 ASUSFA627XS NetworkManager[418683]: <info> [1731632080.3620] device (p2p-dev-wlp5s0): supplicant management interface state: disconnected -> scanning
Nov 15 01:54:44 ASUSFA627XS NetworkManager[418683]: <info> [1731632084.1326] device (wlp5s0): supplicant interface state: scanning -> authenticating
Nov 15 01:54:44 ASUSFA627XS NetworkManager[418683]: <info> [1731632084.1326] device (p2p-dev-wlp5s0): supplicant management interface state: scanning -> authenticating
Nov 15 01:54:44 ASUSFA627XS NetworkManager[418683]: <info> [1731632084.1565] device (wlp5s0): supplicant interface state: authenticating -> associating
Nov 15 01:54:44 ASUSFA627XS NetworkManager[418683]: <info> [1731632084.1565] device (p2p-dev-wlp5s0): supplicant management interface state: authenticating -> associating
Nov 15 01:54:44 ASUSFA627XS NetworkManager[418683]: <info> [1731632084.2805] device (wlp5s0): supplicant interface state: associating -> 4way_handshake
Nov 15 01:54:44 ASUSFA627XS NetworkManager[418683]: <info> [1731632084.2805] device (p2p-dev-wlp5s0): supplicant management interface state: associating -> 4way_handshake
Nov 15 01:54:44 ASUSFA627XS NetworkManager[418683]: <info> [1731632084.4145] device (wlp5s0): supplicant interface state: 4way_handshake -> completed
Nov 15 01:54:44 ASUSFA627XS NetworkManager[418683]: <info> [1731632084.4145] device (wlp5s0): Activation: (wifi) Stage 2 of 5 (Device Configure) successful. Connected to wireless network ">
Nov 15 01:54:44 ASUSFA627XS NetworkManager[418683]: <info> [1731632084.4145] device (p2p-dev-wlp5s0): supplicant management interface state: 4way_handshake -> completed
Nov 15 01:54:44 ASUSFA627XS NetworkManager[418683]: <info> [1731632084.4146] device (wlp5s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
Nov 15 01:54:44 ASUSFA627XS NetworkManager[418683]: <info> [1731632084.4149] dhcp4 (wlp5s0): activation: beginning transaction (timeout in 45 seconds)
Nov 15 01:54:53 ASUSFA627XS NetworkManager[418683]: <info> [1731632093.2575] dhcp4 (wlp5s0): state changed new lease, address=192.168.111.235, acd pending
Nov 15 01:54:53 ASUSFA627XS NetworkManager[418683]: <info> [1731632093.4646] dhcp4 (wlp5s0): state changed new lease, address=192.168.111.235
Nov 15 01:54:53 ASUSFA627XS NetworkManager[418683]: <info> [1731632093.4650] policy: set 'Bastiknet3 Auto' (wlp5s0) as default for IPv4 routing and DNS
Nov 15 01:54:53 ASUSFA627XS NetworkManager[418683]: <info> [1731632093.4741] device (wlp5s0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
Nov 15 01:54:53 ASUSFA627XS NetworkManager[418683]: <info> [1731632093.5285] device (wlp5s0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
Nov 15 01:54:53 ASUSFA627XS NetworkManager[418683]: <info> [1731632093.5286] device (wlp5s0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
Nov 15 01:54:53 ASUSFA627XS NetworkManager[418683]: <info> [1731632093.5287] manager: NetworkManager state is now CONNECTED_SITE
Nov 15 01:54:53 ASUSFA627XS NetworkManager[418683]: <info> [1731632093.5289] device (wlp5s0): Activation: successful, device activated.
Nov 15 01:54:53 ASUSFA627XS NetworkManager[418683]: <info> [1731632093.5291] manager: NetworkManager state is now CONNECTED_GLOBAL
Nov 15 01:55:00 ASUSFA627XS NetworkManager[418683]: <info> [1731632100.6380] device (wlp5s0): supplicant interface state: completed -> authenticating
Nov 15 01:55:00 ASUSFA627XS NetworkManager[418683]: <info> [1731632100.6381] device (p2p-dev-wlp5s0): supplicant management interface state: completed -> authenticating
Nov 15 01:55:00 ASUSFA627XS NetworkManager[418683]: <info> [1731632100.6542] device (wlp5s0): supplicant interface state: authenticating -> associating
Nov 15 01:55:00 ASUSFA627XS NetworkManager[418683]: <info> [1731632100.6542] device (p2p-dev-wlp5s0): supplicant management interface state: authenticating -> associating
Nov 15 01:55:00 ASUSFA627XS NetworkManager[418683]: <info> [1731632100.7810] device (wlp5s0): supplicant interface state: associating -> completed
Nov 15 01:55:00 ASUSFA627XS NetworkManager[418683]: <info> [1731632100.7811] device (wlp5s0): ip:dhcp4: restarting
Nov 15 01:55:00 ASUSFA627XS NetworkManager[418683]: <info> [1731632100.8234] dhcp4 (wlp5s0): canceled DHCP transaction
Nov 15 01:55:00 ASUSFA627XS NetworkManager[418683]: <info> [1731632100.8235] dhcp4 (wlp5s0): activation: beginning transaction (timeout in 45 seconds)
Nov 15 01:55:00 ASUSFA627XS NetworkManager[418683]: <info> [1731632100.8235] dhcp4 (wlp5s0): state changed no lease
Nov 15 01:55:00 ASUSFA627XS NetworkManager[418683]: <info> [1731632100.8236] device (p2p-dev-wlp5s0): supplicant management interface state: associating -> completed
Nov 15 01:55:01 ASUSFA627XS NetworkManager[418683]: <info> [1731632101.4791] dhcp4 (wlp5s0): state changed new lease, address=192.168.111.235, acd pending
Nov 15 01:55:01 ASUSFA627XS NetworkManager[418683]: <info> [1731632101.4793] dhcp4 (wlp5s0): state changed new lease, address=192.168.111.235
I tried different settings on router site, setting TX power to 100% (performance). I’m really not sure what’s the cause of the issue.
I use something like ping www.google.de for longer durations, and my ping somtimes went up to 2 seconds, intermittend there is no connection. Usually the pings have 20-50ms responce. This issues occur every 5-20 mins.
Thanks for any advice.
Best regards
