HI folks,
I am a newbie to linux and installed it just today. I wanted to attend zoom call and I realized my webcam isnt working. After some googling I tried this command
sudo rmmod uvcvideo && sudo modprobe uvcvideo
got a blank output
After that tried this
v4l2-ctl --list-devices
Output:
Integrated_Webcam_HD: Integrate (usb-0000:00:14.0-5):
/dev/video0
/dev/video1
/dev/media0
My pc config:
inxi -Fazy
Kernel: 5.15.28-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=6ccaeabe-5aec-429a-81bc-54810002a8e4 rw quiet apparmor=1
security=apparmor resume=UUID=a6f3eb6a-2206-482e-b75f-37506c8ccdd4
udev.log_priority=3
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1
vt: 7 dm: LightDM 1.30.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: Dell product: Inspiron 15-3567 v: N/A
serial: <superuser required> Chassis: type: 9 serial: <superuser required>
Mobo: Dell model: 05269N v: A00 serial: <superuser required> UEFI: Dell
v: 2.9.0 date: 01/17/2019
ID-1: BAT0 charge: 21.1 Wh (90.6%) condition: 23.3/41.4 Wh (56.2%)
volts: 16.8 min: 14.8 model: LGC-LGC2.80 DELL 991XP6C type: Li-poly
serial: <filter> status: Charging
Info: model: Intel Core i5-7200U bits: 64 type: MT MCP arch: Amber/Kaby Lake
note: check family: 6 model-id: 0x8E (142) stepping: 9 microcode: 0xEC
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 802 high: 809 min/max: 400/3100 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 800 3: 800 4: 809
bogomips: 21607
Type: l1tf
Device-1: Intel HD Graphics 620 vendor: Dell driver: i915 v: kernel ports:
active: HDMI-A-1,eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:5916
class-ID: 0300
Device-2: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 1-5:7 chip-ID: 0c45:6a05 class-ID: 0e02
Display: x11 server: X.Org v: 1.21.1.3 compositor: xfwm v: 4.16.1 driver:
X: loaded: modesetting alternate: fbdev,vesa gpu: i915 display-ID: :0.0
screens: 1
Screen-1: 0 s-res: 2806x900 s-dpi: 96 s-size: 742x238mm (29.2x9.4")
s-diag: 779mm (30.7")
Monitor-1: HDMI-1 mapped: HDMI-A-1 pos: right model: LG (GoldStar) W1742
serial: <filter> built: 2009 res: 1440x900 hz: 60 dpi: 89 gamma: 1.2
size: 410x256mm (16.1x10.1") diag: 436mm (17.2") ratio: 16:10 or 15/9
modes: max: 1440x900 min: 720x400
Monitor-2: eDP-1 pos: primary,left model: Chi Mei Innolux built: 2016
res: 1366x768 hz: 60 dpi: 101 gamma: 1.2 size: 344x193mm (13.5x7.6")
diag: 394mm (15.5") ratio: 16:9 modes: 1366x768
Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell driver: snd_hda_intel
v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3 chip-ID: 8086:9d71
class-ID: 0403
Sound Server-1: ALSA v: k5.15.28-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.48 running: yes
Device-1: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
vendor: Dell driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 01:00.0 chip-ID: 168c:0042 class-ID: 0280
Device-2: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000
bus-ID: 02:00.0 chip-ID: 10ec:8136 class-ID: 0200
Device-1: Qualcomm Atheros type: USB driver: btusb v: 0.8 bus-ID: 1-8:6
chip-ID: 0cf3:e009 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Local Storage: total: 931.51 GiB used: 33.84 GiB (3.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ01ABD100
type: HDD rpm: 5400 serial: <filter> rev: 3D scheme: GPT
ID-1: / raw-size: 927.01 GiB size: 911.39 GiB (98.31%)
used: 33.84 GiB (3.7%) fs: ext4 dev: /dev/sda3 maj-min: 8:3
used: 288 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default)
ID-1: swap-1 type: partition size: 4 GiB used: 1 MiB (0.0%) priority: -2
dev: /dev/sda2 maj-min: 8:2
System Temperatures: cpu: 53.0 C pch: 51.0 C mobo: 51.0 C
Fan Speeds (RPM): cpu: 2546
Processes: 216 Uptime: 1h 1m wakeups: 1 Memory: 15.5 GiB
used: 4.42 GiB (28.5%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1114 lib: 321 flatpak: 0
Shell: Bash v: 5.1.16 running-in: xfce4-terminal inxi: 3.3.13
Please help. Thanks in advance
