Hi,
I recently have installed Manjaro alongside with my Windows 11 installation as my first distro. I am trying to get my 1650ti max-q to work but it is extremely stubborn.
nvidia-smi
gives this output:
No devices were found
lspci | grep VGA
gives this output:
00:02.0 VGA compatible controller: Intel Corporation CometLake-H GT2 [UHD Graphics] (rev 05)
However lspci -k
gives this output (i’ve cut it so it only shows nvidia):
01:00.0 3D controller: NVIDIA Corporation TU117M [GeForce GTX 1650 Ti Mobile] (rev a1)
Subsystem: Micro-Star International Co., Ltd. [MSI] Device 12bd
Kernel driver in use: nvidia
Kernel modules: nouveau, nvidia_drm, nvidia
EDIT:
Apologies for not knowing the norms around here,
inxi --admin --verbosity=7 --filter --width
ouput:
Kernel: 5.15.41-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=9748fa6a-6c96-4526-9402-e6ba62ec395b rw quiet
udev.log_priority=3
Desktop: KDE Plasma v: 5.24.5 tk: Qt v: 5.15.4 info: latte-dock
wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: Micro-Star product: GF63 Thin 10SCSR v: REV:1.0
Mobo: Micro-Star model: MS-16R4 v: REV:1.0 serial: <superuser required>
UEFI: American Megatrends v: E16R4IMS.107 date: 05/28/2020
ID-1: BAT1 charge: 37.7 Wh (80.2%) condition: 47.0/51.3 Wh (91.6%)
volts: 11.8 min: 11.4 model: MSI Corp. MS-16R4 type: Li-ion serial: N/A
status: discharging
RAM: total: 15.45 GiB used: 4.28 GiB (27.7%)
RAM Report:
Info: model: Intel Core i5-10300H bits: 64 type: MT MCP arch: Comet Lake
family: 6 model-id: 0xA5 (165) stepping: 2 microcode: 0xF0
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 800 min/max: 800/4500 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
8: 800 bogomips: 40009
arch_capabilities arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt
cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts
epb ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr
ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ibrs_enhanced ida
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe mpx msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq
pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts rdrand rdseed
rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3
stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx
vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Micro-Star MSI
driver: i915 v: kernel ports: active: eDP-1 empty: DP-1,HDMI-A-1,HDMI-A-2
bus-ID: 00:02.0 chip-ID: 8086:9bc4 class-ID: 0300
Device-2: NVIDIA TU117M [GeForce GTX 1650 Ti Mobile]
vendor: Micro-Star MSI driver: nvidia v: 510.73.05
alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-05) arch: Turing pcie: gen: 3 speed: 8 GT/s
lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:1f95 class-ID: 0302
Device-3: Chicony USB 2.0 Webcam Device type: USB driver: uvcvideo
bus-ID: 1-11:3 chip-ID: 04f2:b648 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.3 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,vesa gpu: i915 display-ID: :0
screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: BOE Display 0x0957 built: 2020 res: 1920x1080
hz: 144 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
diag: 395mm (15.5") ratio: 16:9 modes: 1920x1080
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 22.0.4
direct render: Yes
Device-1: Intel Comet Lake PCH cAVS vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci_intel_cnl
bus-ID: 00:1f.3 chip-ID: 8086:06c8 class-ID: 0403
Sound Server-1: ALSA v: k5.15.41-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.51 running: yes
Device-1: Intel Comet Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:06f0 class-ID: 0280
vendor: Micro-Star MSI driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
IP v4: <filter> scope: global
bus-ID: 1-14:4 chip-ID: 8087:0026 class-ID: e001
Local Storage: total: 476.94 GiB used: 145.2 GiB (30.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: OM8PCP3512F-AI1
lanes: 4 type: SSD serial: <filter> rev: ECFK52.8 temp: 38.9 C scheme: GPT
ID-1: / raw-size: 264.25 GiB size: 259.04 GiB (98.03%)
used: 32.72 GiB (12.6%) fs: ext4 dev: /dev/nvme0n1p7 maj-min: 259:7
label: N/A uuid: 9748fa6a-6c96-4526-9402-e6ba62ec395b
ID-2: /boot/efi raw-size: 300 MiB size: 296 MiB (98.67%)
used: 29 MiB (9.8%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: SYSTEM uuid: 62FA-487B
ID-3: /run/media/stratz/Storage raw-size: 41.86 GiB
size: 41.86 GiB (100.00%) used: 11.38 GiB (27.2%) fs: ntfs
dev: /dev/nvme0n1p4 maj-min: 259:4 label: Storage uuid: 46504BC7504BBC85
ID-4: /run/media/stratz/Windows raw-size: 153.92 GiB
size: 153.92 GiB (100.00%) used: 101.08 GiB (65.7%) fs: ntfs
dev: /dev/nvme0n1p3 maj-min: 259:3 label: Windows uuid: A0ECD59EECD56ED2
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 128 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p5 maj-min: 259:5 size: 900 MiB fs: ntfs
label: WinRE tools uuid: 06DEFB22DEFB0927
ID-3: /dev/nvme0n1p6 maj-min: 259:6 size: 15.61 GiB fs: ntfs
label: BIOS_RVY uuid: A8BCFD4BBCFD1492
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
Device-1: 1-3:5 info: HP HP USB Optical Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
power: 100mA chip-ID: 03f0:1f4a class-ID: 0301
Device-2: 1-11:3 info: Chicony USB 2.0 Webcam Device type: Video
Device-3: 1-14:4 info: Intel AX201 Bluetooth type: Bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0026
class-ID: e001
Hub-2: 2-0:1 info: Super-speed hub ports: 8 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 56.0 C pch: 54.0 C mobo: N/A
Processes: 268 Uptime: 57m wakeups: 2 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 12.1.0 clang: 13.0.1 Packages: pacman: 1332 lib: 410
Shell: Bash v: 5.1.16 running-in: alacritty inxi: 3.3.16
