it’s the first time this occurred:
after booting up,the sound icon on the panel(KDE)was red.
looking at the journal log shows:
systemd-udevd[411]: could not read from '/sys/module/pcc_cpufreq/initstate': No such device
kernel:
kernel: sof-audio-pci 0000:00:1f.3: error: cl_dsp_init: timeout HDA_DSP_SRAM_REG_ROM_STATUS read
kernel: sof-audio-pci 0000:00:1f.3: error: status = 0x00000000 panic = 0x00000000
kernel: sof-audio-pci 0000:00:1f.3: error: extended rom status: 0x1000010 0x0 0x0 0x0 0x0 0x0 0x1830118 0x0
kernel: sof-audio-pci 0000:00:1f.3: error: dsp init failed after 3 attempts with err: -110
kernel: sof-audio-pci 0000:00:1f.3: ROM error=0xffffffff: FW status=0xffffffff
kernel: sof-audio-pci 0000:00:1f.3: error: status = 0xffffffff panic = 0xffffffff
kernel: sof-audio-pci 0000:00:1f.3: error: extended rom status: 0xffffffff 0xffffffff 0xffffffff 0xffffffff 0xffffffff 0xffffffff 0xffffffff 0xffffffff
kernel: sof-audio-pci 0000:00:1f.3: error: failed to reset DSP
kernel: sof-audio-pci 0000:00:1f.3: error: failed to boot DSP firmware -110
kernel: sof-audio-pci 0000:00:1f.3: error: hda_dsp_core_reset_enter: timeout on HDA_DSP_REG_ADSPCS read
kernel: sof-audio-pci 0000:00:1f.3: error: dsp core reset failed: core_mask f
kernel: sof-audio-pci 0000:00:1f.3: error: sof_probe_work failed err: -110
after rebooting it got fixed.
i sometimes get the following errors,but it doesn’t affect the sound:
pulseaudio[979]: Error opening PCM device _ucm0001.hw:sofhdadsp,5: No such device
pulseaudio[979]: Error opening PCM device _ucm0001.hw:sofhdadsp,4: No such device
pulseaudio[979]: Error opening PCM device _ucm0001.hw:sofhdadsp: No such device
pulseaudio[979]: Error opening PCM device _ucm0001.hw:sofhdadsp,6: No such device
i have the regular Pulseaudio that came with Manjaro and didn’t mess or try Pipewire.
any ideas,I’m a bit worried for my hardware?
Edit:
I’ve seen a lot of sound related issues lately here on the forum.
the only change I’ve made the last day is stop/disable avahi-deamon+socket.
Edit 2:
it might be a problem with “sof” and not just me.
