Trying hdtv as monitor in i3 edition
Approximately a 40 inch diagonal screen with scaling turned off. Looks pretty good but could stand higher resolution but xrandr shows 1920x1080 as the highest. And it is already set at that. Relevant stats.
[christo@christo-pc ~]$ inxi -F
System: Host: christo-pc Kernel: 5.0.14-rt9-MANJARO x86_64 bits: 64 Desktop: i3 4.16.1
Distro: Manjaro Linux
Machine: Type: Desktop Mobo: ASUSTeK model: TUF B450-PLUS GAMING v: Rev X.0x
serial: UEFI: American Megatrends v: 0221 date: 06/08/2018
CPU: Topology: 6-Core model: AMD Ryzen 5 2600X bits: 64 type: MT MCP L2 cache: 3072 KiB
Speed: 2834 MHz min/max: 2200/3600 MHz Core speeds (MHz): 1: 2586 2: 2634 3: 2378
4: 2394 5: 2305 6: 2310 7: 2308 8: 2304 9: 3748 10: 3397 11: 2831 12: 3807
Graphics: Device-1: AMD Baffin [Radeon RX 460/560D / Pro 450/455/460/555/555X/560/560X]
driver: amdgpu v: kernel
Display: x11 server: X.Org 1.20.5 driver: amdgpu FAILED: ati unloaded: modesetting
resolution: 1920x1080~60Hz
OpenGL:
renderer: AMD Radeon RX 460 Graphics (POLARIS11 DRM 3.27.0 5.0.14-rt9-MANJARO LLVM 8.0.0)
v: 4.5 Mesa 19.0.6
Audio: Device-1: AMD Baffin HDMI/DP Audio [Radeon RX 550 640SP / RX 560/560X]
driver: snd_hda_intel
Device-2: AMD Family 17h HD Audio driver: snd_hda_intel
Sound Server: ALSA v: k5.0.14-rt9-MANJARO
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet driver: r8168
IF: enp4s0 state: up speed: 1000 Mbps duplex: full mac: 0c:9d:92:75:46:a4
Drives: Local Storage: total: 2.25 TiB used: 31.71 GiB (1.4%)
ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 960 EVO 250GB size: 232.89 GiB
ID-2: /dev/sda vendor: Seagate model: ST1000DM010-2EP102 size: 931.51 GiB
ID-3: /dev/sdb type: USB vendor: Seagate model: BUP Slim BK size: 931.51 GiB
ID-4: /dev/sdc type: USB vendor: Lexar model: JumpDrive size: 29.82 GiB
ID-5: /dev/sdd type: USB vendor: SanDisk model: Ultra Fit size: 114.56 GiB
ID-6: /dev/sde type: USB vendor: PNY model: USB 3.0 FD size: 29.80 GiB
ID-7: /dev/sdf type: USB model: UFD USB Flash Drive size: 7.47 GiB
ID-8: /dev/sdg type: USB vendor: Patriot model: Patriot Memory size: 1.87 GiB
ID-9: /dev/sdh type: USB vendor: Kingston model: DataTraveler 2.0 size: 29.08 GiB
Partition: ID-1: / size: 210.99 GiB used: 10.81 GiB (5.1%) fs: ext4 dev: /dev/nvme0n1p2
ID-2: swap-1 size: 17.22 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/nvme0n1p3
Sensors: System Temperatures: cpu: 44.9 C mobo: N/A gpu: amdgpu temp: 43 C
Fan Speeds (RPM): cpu: 0 gpu: amdgpu fan: 1038
Info: Processes: 383 Uptime: 1h 14m Memory: 15.65 GiB used: 985.8 MiB (6.1%) Shell: bash
inxi: 3.0.34
[christo@christo-pc ~]$ ls /sys/class/drm
card0 card0-DP-1 card0-DVI-D-1 card0-HDMI-A-1 renderD128 ttm version
[christo@christo-pc ~]$ xdpyinfo | grep -B2 resolution
screen #0:
dimensions: 1920x1080 pixels (508x285 millimeters)
resolution: 96x96 dots per inch
And 'card0-HDMI-A-1 is the big screen. Can I up the resolution, maybe? Thanks in advance!
Depends on the TV. If it's a 1080p tv, no.
What make/model tv is it?
It is, indeed 1080p. A Samsung. Thanks for the reply. Just went back to my dual monitor layout, which was fine.
