Tryin to delete calendar from panel
I added the calendar widget to my manjaro kde plasma panel and then wanted to delete it. I have been searching and reading posts about deleting widgets but didn’t find a solution that worked. In trying to find a way to delete the one calendar widget I have managed to add 5 more and now I have 6 calendars showing in my panel.
I read one post about clicking on the hamburger menu in the panel but I don’t have one showing in my panel Can someone direct me to a solution?
Hi @hjblue,
It’s, at least according to me, an easy thing to do.
Right click on the panel and select “Enter edit mode”:
https://i.imgur.com/AJXwHGf.png
When it’s in Edit mode, hover, not click but hover over the widget you want to remove un5til you get the popup menu:
https://i.imgur.com/fUeVgIb.png
Select “Remove” from this menu. It should be removed now.
Remember to Exit edit mode by clicking the button in the toolbar:
https://i.imgur.com/542Rjlq.png
Hope this helps!
Thanks so much. Now I wonder why I didn’t try that? :upside_down_face:
Because we’re all human, we all have bran-farts brain-farts.
Edit:
That was a strong, potent fart.
