Hi,
I bought a cheap bluetooth keyboard (Dierya DK63) and I can’t get it working over bluetooth (though it works fine over USB and Android with Bluetooth). It easily connects to Manjaro PC using the Blueman applet. I can pair and trust the keyboard no problem, but keypresses don’t do anything. I removed the device and re-added using the procedure on the Arch Wiki page for Bluetooth Keyboards, but the same thing happens: the keyboard will pair and is trusted, but won’t type. I also tried in TT3, but that was no different.
How can I get this keyboard’s keypresses working in Manjaro? Thanks a bunch for helping out. I appreciate it.
inxi output and blueman info are below.
Here’s what Blueman looks like:
Address type: random
Alias: Dierya DK63
Class: 0x000000
Appearance: 0x03c1
Icon: input-keyboard
Paired: yes
Trusted: yes
Blocked: no
LegacyPairing: no
Connected: yes
UUIDs:
00001800-0000-1000-8000-00805f9b34fb Generic Access
00001801-0000-1000-8000-00805f9b34fb Generic Attribute
0000180a-0000-1000-8000-00805f9b34fb Device Information
0000180f-0000-1000-8000-00805f9b34fb Battery Service
00001812-0000-1000-8000-00805f9b34fb Human Interface Device
0000f200-0000-1000-8000-00805f9b34fb Unknown
0000ffb0-0000-1000-8000-00805f9b34fb Unknown
Modalias: bluetooth:vAC01p4F05d0000
Adapter: /org/bluez/hci0
output of inxi --admin --verbosity=7 --filter --no-host --width
Kernel: 5.18.7-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.18-x86_64
root=UUID=8904615e-31c4-49b2-9f60-8f66c308db85 rw quiet
cryptdevice=UUID=772d8c3d-0dbd-4014-8260-614657dfbce0:luks-772d8c3d-0dbd-4014-8260-614657dfbce0
root=/dev/mapper/luks-772d8c3d-0dbd-4014-8260-614657dfbce0 apparmor=1
security=apparmor udev.log_priority=3 amd_iommu=on iommu=pt
Desktop: Xfce v: 4.16.0 tk: Gtk v: 3.24.29 info: xfce4-panel wm: xfwm
v: 4.16.1 vt: 7 dm: LightDM v: 1.30.0 Distro: Manjaro Linux base: Arch Linux
Type: Desktop System: Gigabyte product: B550 AORUS MASTER v: N/A
serial: <superuser required>
Mobo: Gigabyte model: B550 AORUS MASTER serial: <superuser required>
UEFI: American Megatrends LLC. v: F15d date: 05/11/2022
Device-1: hidpp_battery_0 model: Logitech M570 serial: <filter> charge: 65%
rechargeable: yes status: discharging
RAM: total: 31.25 GiB used: 4.04 GiB (12.9%)
RAM Report:
Info: model: AMD Ryzen 7 5800X bits: 64 type: MT MCP arch: Zen 3 gen: 4
built: 2021-22 process: TSMC n7 (7nm) family: 0x19 (25) model-id: 0x21 (33)
stepping: 0 microcode: 0xA201016
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 3207 high: 3826 min/max: 2200/4850 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3379 2: 2881
3: 2880 4: 3439 5: 3053 6: 2880 7: 2873 8: 3596 9: 3594 10: 3788 11: 3826
12: 2903 13: 2875 14: 2879 15: 2880 16: 3600 bogomips: 121656
cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
STIBP: always-on, RSB filling
Device-1: NVIDIA GP102 [GeForce GTX 1080 Ti] driver: nvidia v: 515.57
alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-06) arch: Pascal process: TSMC 16nm
built: 2016-21 pcie: gen: 3 speed: 8 GT/s lanes: 8 link-max: lanes: 16
bus-ID: 07:00.0 chip-ID: 10de:1b06 class-ID: 0300
Display: x11 server: X.Org v: 21.1.3 compositor: xfwm v: 4.16.1 driver: X:
loaded: nvidia gpu: nvidia display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 2560x1440 s-dpi: 96 s-size: 677x381mm (26.65x15.00")
s-diag: 777mm (30.58")
Monitor-1: DP-4 res: 2560x1440 dpi: 109 size: 597x336mm (23.5x13.23")
diag: 685mm (26.97") modes: N/A
OpenGL: renderer: NVIDIA GeForce GTX 1080 Ti/PCIe/SSE2
v: 4.6.0 NVIDIA 515.57 direct render: Yes
Device-1: NVIDIA GP102 HDMI Audio driver: snd_hda_intel v: kernel pcie:
gen: 3 speed: 8 GT/s lanes: 8 link-max: lanes: 16 bus-ID: 07:00.1
chip-ID: 10de:10ef class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Gigabyte
bus-ID: 0a:00.4 chip-ID: 1022:1487 class-ID: 0403
Sound Server-1: ALSA v: k5.18.7-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.52 running: yes
Device-1: Realtek RTL8125 2.5GbE vendor: Gigabyte driver: r8169 v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: f000 bus-ID: 05:00.0
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 06:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp6s0 state: down mac: <filter>
IF-ID-1: virbr0 state: down mac: <filter>
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-5:9
Report: hciconfig ID: hci0 rfk-id: 2 state: up address: <filter> bt-v: 3.0
lmp-v: 5.2 sub-v: 2076 hci-v: 5.2 rev: 2076
Info: acl-mtu: 1021:4 sco-mtu: 96:6 link-policy: rswitch sniff
link-mode: peripheral accept
service-classes: rendering, capturing, object transfer, audio, telephony
Device-1: luks-772d8c3d-0dbd-4014-8260-614657dfbce0 maj-min: 254:0
type: LUKS dm: dm-0 size: 185.3 GiB
Components:
p-1: nvme1n1p2 maj-min: 259:5 size: 185.3 GiB
Local Storage: total: 5.87 TiB used: 1.54 TiB (26.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 model: PCIe SSD size: 1.86 TiB
block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4
type: SSD serial: <filter> rev: ECFM13.3 temp: 26.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:3 vendor: Intel model: SSDPEDMW400G4
size: 372.61 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: 8EV101H0 temp: 34.9 C scheme: GPT
ID-3: /dev/nvme2n1 maj-min: 259:6 vendor: Samsung
model: SSD 970 EVO Plus 2TB size: 1.82 TiB block-size: physical: 512 B
rev: 2B2QEXM7 temp: 43.9 C scheme: GPT
ID-4: /dev/sda maj-min: 8:0 vendor: Crucial model: CT2000MX500SSD1
type: SSD serial: <filter> rev: 023 scheme: GPT
Optical-1: /dev/sr0 vendor: ASUS model: BW-16D1HT rev: 3.02
dev-links: cdrom
Optical-2: /dev/sr1 vendor: ASUS model: BW-16D1HT rev: 3.01 dev-links: N/A
Optical-3: /dev/sr2 vendor: HL-DT-ST model: BD-RE BU40N rev: 1.03
dev-links: N/A
ID-1: / raw-size: 185.3 GiB size: 181.33 GiB (97.86%)
used: 123.57 GiB (68.1%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-772d8c3d-0dbd-4014-8260-614657dfbce0 label: N/A
uuid: 8904615e-31c4-49b2-9f60-8f66c308db85
used: 27.8 MiB (9.3%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:4
label: NO_LABEL uuid: ABE1-5D3A
ID-3: /data/mx500 raw-size: 1.82 TiB size: 1.82 TiB (100.00%)
used: 963.71 GiB (51.7%) fs: ntfs dev: /dev/sda2 maj-min: 8:2 label: MX500
uuid: 584CF2FB4CF2D32C
ID-4: /home raw-size: 788.8 GiB size: 775.35 GiB (98.30%)
used: 490.56 GiB (63.3%) fs: ext4 dev: /dev/nvme2n1p1 maj-min: 259:7
label: 970evo01 uuid: 69129bfb-ec84-4cd4-a076-362b40f7ea45
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 252.44 GiB fs: ntfs label: N/A
uuid: 5A74315C74313BD7
ID-3: /dev/sda1 maj-min: 8:1 size: 16 MiB fs: <superuser required>
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 10 rev: 2.0
Device-1: 1-4:2 info: Topre Realforce 87 type: Keyboard
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 0853:0111 class-ID: 0301
Device-2: 1-5:9 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
class-ID: e001
Hub-2: 1-6:4 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Device-1: 1-7:5 info: Integrated Express ITE Device type: HID
power: 100mA chip-ID: 048d:5702 class-ID: 0300
Device-2: 1-9:6 info: Razer USA RZ01-0325 Gaming Mouse [Viper Mini]
type: Mouse,Keyboard driver: hid-generic,usbhid interfaces: 3 rev: 2.0
speed: 12 Mb/s power: 500mA chip-ID: 1532:008a class-ID: 0300
Hub-3: 1-10:7 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Device-1: 1-10.4:8 info: Logitech Unifying Receiver
type: Keyboard,Mouse,HID driver: logitech-djreceiver,usbhid interfaces: 3
rev: 2.0 speed: 12 Mb/s power: 98mA chip-ID: 046d:c52b class-ID: 0300
Hub-4: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Hub-6: 3-3:2 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s
power: 100mA chip-ID: 05e3:0610 class-ID: 0900
Hub-7: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Device-1: 4-2:2 info: Initio USB3.0 DEVICE type: Mass Storage
driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s power: 144mA
chip-ID: 13fd:3609 class-ID: 0806 serial: <filter>
Hub-8: 4-3:3 info: Genesys Logic Hub ports: 4 rev: 3.0 speed: 5 Gb/s
chip-ID: 05e3:0612 class-ID: 0900
System Temperatures: cpu: N/A mobo: N/A gpu: nvidia temp: 46 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 25%
Processes: 382 Uptime: 1h 9m wakeups: 7 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.1.0 clang: 13.0.1
Packages: 1736 pacman: 1721 lib: 460 flatpak: 5 snap: 10 Shell: Bash
v: 5.1.16 running-in: xfce4-terminal inxi: 3.3.19
