Troubles after upgrading Manjaro
#41
I have a partition to my system alone. So my data is safe …
#42
a separate drive is better in case the main one your using craps out on ya, but a separate partition is still better than using the same partition your backing up, and definitely better than having no backup at all. timeshift is certainly one of my most valued tools, its saved more than a few times and it’s enabled me to play/tinker with things i otherwise would not do out of fear of having to re-install.
#43
Yes you are right
#44
Another issue is that some times I’ve need to reboot because the wire connection did not success
#45
are you still in the process of fixing the last issue? sloooooow it down… one thing at a time
#46
Ok! I’m just telling. Until when you’ll be online
#47
i spend a decent amount of time on here off and on throughout the day. i still usually check my alerts every so often. hope it works out
#48
Thanks for all man. It is possible to contact you directly in case of future issues. I’m new here in this community but it feels good here.
The work of manjaro developers really impressed me :muscle:
#49
no need, answers to most issues are easily found with a forum/wiki search and for the ones that are a little more difficult to understand you can create a thread asking for help and there are plenty of great people here on the forum who never mind helping someone who at least gives an honest attempt to figure it out on their own. in this case, it seems some earlier installed packages from aur conflicted with the ones manjaro supplies and caused issues during update which then would not let you change to the video-linux drivers, it happens but i see this as a valid reason for making a thread.
besides, if one is looking for me specifically, dropping a @dglt in any post will alert me.
theres nothing wrong with creating threads that are not repeats of others already asked and answered. someone else may run into this issue and this thread could show them how to fix it whereas if i was to help you in a private message, it would only benefit 1 person.
#50
Yeah I understand.
By the way I only installed one package from aur and was youtube-dl when I was using the previous version of aManjaro, that’s before upgrade
which is still preseent installed at /usr/local. I think it is not a trouble at all
#51
Hey @dglt I couldn’t upgrade. A lot of errors such like these:
error: failed to commit transaction (conflicting files)
tzdata: /usr/bin/tzselect exists in filesystem
tzdata: /usr/bin/zdump exists in filesystem
tzdata: /usr/bin/zic exists in filesystem
tzdata: /usr/lib/libtz.a exists in filesystem
tzdata: /usr/share/man/man3/newctime.3.gz exists in filesystem
tzdata: /usr/share/man/man3/newtzset.3.gz exists in filesystem
tzdata: /usr/share/man/man5/tzfile.5.gz exists in filesystem
tzdata: /usr/share/man/man8/tzselect.8.gz exists in filesystem
tzdata: /usr/share/man/man8/zdump.8.gz exists in filesystem
tzdata: /usr/share/man/man8/zic.8.gz exists in filesystem
tzdata: /usr/share/zoneinfo-leaps/Africa/Abidjan exists in filesystem
tzdata: /usr/share/zoneinfo-leaps/Africa/Accra exists in filesystem
tzdata: /usr/share/zoneinfo-leaps/Africa/Addis_Ababa exists in filesystem
tzdata: /usr/share/zoneinfo-leaps/Africa/Algiers exists in filesystem
tzdata: /usr/share/zoneinfo-leaps/Africa/Asmara exists in filesystem
tzdata: /usr/share/zoneinfo-leaps/Africa/Asmera exists in filesystem
tzdata: /usr/share/zoneinfo-leaps/Africa/Bamako exists in filesystem
tzdata: /usr/share/zoneinfo-leaps/Africa/Bangui exists in filesystem
tzdata: /usr/share/zoneinfo-leaps/Africa/Banjul exists in filesystem
tzdata: /usr/share/zoneinfo-leaps/Africa/Bissau exists in filesystem
tzdata: /usr/share/zoneinfo-leaps/Africa/Blantyre exists in filesystem
tzdata: /usr/share/zoneinfo-leaps/Africa/Brazzaville exists in filesystem
tzdata: /usr/share/zoneinfo-leaps/Africa/Bujumbura exists in filesystem
tzdata: /usr/share/zoneinfo-leaps/Africa/Cairo exists in filesystem
tzdata: /usr/share/zoneinfo-leaps/Africa/Casablanca exists in filesystem
tzdata: /usr/share/zoneinfo-leaps/Africa/Ceuta exists in filesystem
tzdata: /usr/share/zoneinfo-leaps/Africa/Conakry exists in filesystem
tzdata: /usr/share/zoneinfo-leaps/Africa/Dakar exists in filesystem
tzdata: /usr/share/zoneinfo-leaps/Africa/Dar_es_Salaam exists in filesystem
tzdata: /usr/share/zoneinfo-leaps/Africa/Djibouti exists in filesystem
tzdata: /usr/share/zoneinfo-leaps/Africa/Douala exists in filesystem
tzdata: /usr/share/zoneinfo-leaps/Africa/El_Aaiun exists in filesystem
tzdata: /usr/share/zoneinfo-leaps/Africa/Freetown exists in filesystem
tzdata: /usr/share/zoneinfo-leaps/Africa/Gaborone exists in filesystem
tzdata: /usr/share/zoneinfo-leaps/Africa/Harare exists in filesystem
tzdata: /usr/share/zoneinfo-leaps/Africa/Johannesburg exists in filesystem
tzdata: /usr/share/zoneinfo-leaps/Africa/Juba exists in filesystem
tzdata: /usr/share/zoneinfo-leaps/Africa/Kampala exists in filesystem
tzdata: /usr/share/zoneinfo-leaps/Africa/Khartoum exists in filesystem
tzdata: /usr/share/zoneinfo-leaps/Africa/Kigali exists in filesystem
tzdata: /usr/share/zoneinfo-leaps/Africa/Kinshasa exists in filesystem
tzdata: /usr/share/zoneinfo-leaps/Africa/Lagos exists in filesystem
tzdata: /usr/share/zoneinfo-leaps/Africa/Libreville exists in filesystem
tzdata: /usr/share/zoneinfo-leaps/Africa/Lome exists in filesystem
tzdata: /usr/share/zoneinfo-leaps/Africa/Luanda exists in filesystem
tzdata: /usr/share/zoneinfo-leaps/Africa/Lubumbashi exists in filesystem
tzdata: /usr/share/zoneinfo-leaps/Africa/Lusaka exists in filesystem
tzdata: /usr/share/zoneinfo-leaps/Africa/Malabo exists in filesystem
tzdata: /usr/share/zoneinfo-leaps/Africa/Maputo exists in filesystem
tzdata: /usr/share/zoneinfo-leaps/Africa/Maseru exists in filesystem
tzdata: /usr/share/zoneinfo-leaps/Africa/Mbabane exists in filesystem
tzdata: /usr/share/zoneinfo-leaps/Africa/Mogadishu exists in filesystem
tzdata: /usr/share/zoneinfo-leaps/Africa/Monrovia exists in filesystem
tzdata: /usr/share/zoneinfo-leaps/Africa/Nairobi exists in filesystem
tzdata: /usr/share/zoneinfo-leaps/Africa/Ndjamena exists in filesystem
tzdata: /usr/share/zoneinfo-leaps/Africa/Niamey exists in filesystem
tzdata: /usr/share/zoneinfo-leaps/Africa/Nouakchott exists in filesystem
tzdata: /usr/share/zoneinfo-leaps/Africa/Ouagadougou exists in filesystem
tzdata: /usr/share/zoneinfo-leaps/Africa/Porto-Novo exists in filesystem
tzdata: /usr/share/zoneinfo-leaps/Africa/Sao_Tome exists in filesystem
tzdata: /usr/share/zoneinfo-leaps/Africa/Timbuktu exists in filesystem
tzdata: /usr/share/zoneinfo-leaps/Africa/Tripoli exists in filesystem
tzdata: /usr/share/zoneinfo-leaps/Africa/Tunis exists in filesystem
tzdata: /usr/share/zoneinfo-leaps/Africa/Windhoek exists in filesystem
tzdata: /usr/share/zoneinfo-leaps/America/Adak exists in filesystem
tzdata: /usr/share/zoneinfo-leaps/America/Anchorage exists in filesystem
tzdata: /usr/share/zoneinfo-leaps/America/Anguilla exists in filesystem
tzdata: /usr/share/zoneinfo-leaps/America/Antigua exists in filesystem
tzdata: /usr/share/zoneinfo-leaps/America/Araguaina exists in filesystem
tzdata: /usr/share/zoneinfo-leaps/America/Argentina/Buenos_Aires exists in filesystem
tzdata: /usr/share/zoneinfo-leaps/America/Argentina/Catamarca exists in filesystem
tzdata: /usr/share/zoneinfo-leaps/America/Argentina/ComodRivadavia exists in filesystem
tzdata: /usr/share/zoneinfo-leaps/America/Argentina/Cordoba exists in filesystem
tzdata: /usr/share/zoneinfo-leaps/America/Argentina/Jujuy exists in filesystem
tzdata: /usr/share/zoneinfo-leaps/America/Argentina/La_Rioja exists in filesystem
tzdata: /usr/share/zoneinfo-leaps/America/Argentina/Mendoza exists in filesystem
I did all exactly as you said to me
#52
so pacman failed to finish? or did it throw those errors and then finish?
#53
I could download all packages but couldn’t upgrade because the libraries were also at the system. He found this errors and ended.
@dglt
#54
im looking for similar errors, feel free to do some searching. i dont know off hand why thats happening
can you post any errors from trying to reinstall tzdata
sudo pacman -S tzdata
#55
The same error:
Once I had the same problem And I made pacman but with --override option because pacman fails installing as the library is already installed.
What do you think? I did it @dglt
#56
you got the update to finish using --override ?
btw, i have this thread set to “watching” so you can save yourself the 5 keystrokes on @dglt :sunglasses:
i get alerted of any post to this thread or any post that replies to my own posts
#57
I couldn’t because I need to specify which file overwrite and there are a lot.
I think it is because in the directory /var/lib/pacman/local I have the old and new packages. So pacman maybe trying to decompress both.
#58
before you go clearing all the packages you just spent a while downloading, try this first
sudo pacman -Rdd tzdata
#59
Yes I could upgrade tzdata, but what about then with others
#60
the only errors you showed me are related to tzdata
