Troubles after upgrading Manjaro
#21
Ok! I’m on it
#22
I got errors
:: xf86-video-ati and xorg-server are in conflict. Remove xorg-server? [y/N] error: unresolvable package conflicts detected
error: failed to prepare transaction (conflicting dependencies)
:: xf86-video-ati and xorg-server are in conflict (xorg-server<1.20.0)
Error: pacman failed!
Error: script failed!
#23
I got errors
#24
I got errors
#25
is this during uninstall of video-intel? or install of video-linux?
please update mirrors and run update and then try again
sudo pacman-mirrors -f5
sudo pacman -Syyu
report any errors
remove xf86-video-ati (dont know why you would have this??)
sudo pacman -R xf86-video-ati
post `pacman -Qs xf86-video
#26
It was during the install of video-linux
#27
You need to update your system before installing drivers/software.
#28
Ok. I’ll do it.
One question
When I uninstalled video-intel I still can play videos. So it means that this driver was not being used?
#29
from the looks of it you didnt have xorg-server installed and xf86-video-ati conflict with each other, so removing xf86-video-ati , make sure mirrors are in fact synced and pacman -Syyu runs without issue, you should be able to
sudo mhwd -i pci video-linux
DO NOT RESTART UNTIL ALL IS FINISHED
please stop playing videos while we are trying to fix video drivers :man_facepalming:
#30
Look
resolving dependencies…
warning: removing ‘deepin-desktop-schemas’ from target list because it conflicts with ‘deepin-desktop-schemas-manjaro’
warning: dependency cycle detected:
warning: bashrc-manjaro will be installed before its bash dependency
warning: harfbuzz will be installed before its freetype2 dependency
warning: libglvnd will be installed before its mesa dependency
warning: x264 will be installed before its ffmpeg dependency
warning: deepin-session-ui will be installed before its deepin-control-center dependency
warning: deepin-session-ui will be installed before its deepin-daemon dependency
warning: startdde will be installed before its deepin-daemon dependency
It is part of the update
#31
yes indeed it is, seems your recent update was not so recent apparently
run the update.
it looks like youve customized yourself into quite a hole (albeit, a special hole :grin:)
did the update run successfully?
#32
Yeah I’m downloading the packages it is about 1.2 gb
By the way. Thanks for help.
I was wondering if it is not possible to get some repositiories that could provide the packages I need for my previous version. Thus I wouldn’t need to upgrade and wouldn’t have troubles.
#33
how to do usually update? pamac? pacman? what command?
#34
pacman and yaourt. But now and most frequently pacman
#35
Question
Last update I lose my desktop. I were not able to enter in the graphic mode. So I had to reinstall using an iso file. And then I saw that my system was running better in a previous edition. I reinstalled the kernel to the previous one 4.9 but it did not fix the problem.
There is somthing dark here?
#36
Question
There is something dark here?
#37
yaourt is no longer maintained and is recommended not to be used. yay is a great alternative , its in the manjaro repo. stop using yaourt and be mindful of what you install from aur, if it conflicts with something you have from manjaro repo, its likely theres a chance it will cause problems/conflicts down the line .
when you update sudo pacman -Syyu so you know the database synced
dont reboot unless pacman update finishes without errors and you
post any errors
edit: why do i get the feeling that @kafka is staring into a black unresponsive screen right now? it wasnt me :innocent: .
#38
What do you mean?
I always can recover my system if something fails. Don’t have nothing to lose
#39
#40
surprisingly i come across more people that dont backup than those who do. :+1:
everything going according to plan so far?
