Trouble with opencv-5.0.0-5 - invalid or corrupt
Hi group - thanks in advance for your help pointing me to useful next steps. Below is the system I’m running:
Manjaro Linux x86_64
Galago Pro galp5
6.18.38-1-MANJARO
bash 5.3.15
Plasma 6.6.6
kwin
Yesterday I tried to execute the most recent update and get this error. Something is clearly wrong with opencv but I’m not sure how to respond. Can you advise about best next steps. Thx
rsv2@reid-galagopro:~$ sudo pacman -Syu
[sudo] password for rsv2:
 core is up to date
 extra is up to date
 multilib is up to date
error: could not open file /var/lib/pacman/local/opencv-5.0.0-5/desc: No such file or directory
resolving dependencies...
:: There are 128 providers available for tessdata:
:: Repository extra
   1) tesseract-data-afr  2) tesseract-data-amh  3) tesseract-data-ara  4) tesseract-data-asm  5) tesseract-data-aze
   6) tesseract-data-aze_cyrl  7) tesseract-data-bel  8) tesseract-data-ben  9) tesseract-data-bod  10) tesseract-data-bos
   11) tesseract-data-bre  12) tesseract-data-bul  13) tesseract-data-cat  14) tesseract-data-ceb  15) tesseract-data-ces
   16) tesseract-data-chi_sim  17) tesseract-data-chi_sim_vert  18) tesseract-data-chi_tra  19) tesseract-data-chi_tra_vert
   20) tesseract-data-chr  21) tesseract-data-cos  22) tesseract-data-cym  23) tesseract-data-dan  24) tesseract-data-dan_frak
   25) tesseract-data-deu  26) tesseract-data-deu_frak  27) tesseract-data-div  28) tesseract-data-dzo  29) tesseract-data-ell
   30) tesseract-data-eng  31) tesseract-data-enm  32) tesseract-data-epo  33) tesseract-data-equ  34) tesseract-data-est
   35) tesseract-data-eus  36) tesseract-data-fao  37) tesseract-data-fas  38) tesseract-data-fil  39) tesseract-data-fin
   40) tesseract-data-fra  41) tesseract-data-frk  42) tesseract-data-frm  43) tesseract-data-fry  44) tesseract-data-gla
   45) tesseract-data-gle  46) tesseract-data-glg  47) tesseract-data-grc  48) tesseract-data-guj  49) tesseract-data-hat
   50) tesseract-data-heb  51) tesseract-data-hin  52) tesseract-data-hrv  53) tesseract-data-hun  54) tesseract-data-hye
   55) tesseract-data-iku  56) tesseract-data-ind  57) tesseract-data-isl  58) tesseract-data-ita  59) tesseract-data-ita_old
   60) tesseract-data-jav  61) tesseract-data-jpn  62) tesseract-data-jpn_vert  63) tesseract-data-kan  64) tesseract-data-kat
   65) tesseract-data-kat_old  66) tesseract-data-kaz  67) tesseract-data-khm  68) tesseract-data-kir  69) tesseract-data-kmr
   70) tesseract-data-kor  71) tesseract-data-kor_vert  72) tesseract-data-lao  73) tesseract-data-lat  74) tesseract-data-lav
   75) tesseract-data-lit  76) tesseract-data-ltz  77) tesseract-data-mal  78) tesseract-data-mar  79) tesseract-data-mkd
   80) tesseract-data-mlt  81) tesseract-data-mon  82) tesseract-data-mri  83) tesseract-data-msa  84) tesseract-data-mya
   85) tesseract-data-nep  86) tesseract-data-nld  87) tesseract-data-nor  88) tesseract-data-oci  89) tesseract-data-ori
   90) tesseract-data-pan  91) tesseract-data-pol  92) tesseract-data-por  93) tesseract-data-pus  94) tesseract-data-que
   95) tesseract-data-ron  96) tesseract-data-rus  97) tesseract-data-san  98) tesseract-data-sin  99) tesseract-data-slk
   100) tesseract-data-slk_frak  101) tesseract-data-slv  102) tesseract-data-snd  103) tesseract-data-spa
   104) tesseract-data-spa_old  105) tesseract-data-sqi  106) tesseract-data-srp  107) tesseract-data-srp_latn
   108) tesseract-data-sun  109) tesseract-data-swa  110) tesseract-data-swe  111) tesseract-data-syr  112) tesseract-data-tam
   113) tesseract-data-tat  114) tesseract-data-tel  115) tesseract-data-tgk  116) tesseract-data-tgl  117) tesseract-data-tha
   118) tesseract-data-tir  119) tesseract-data-ton  120) tesseract-data-tur  121) tesseract-data-uig  122) tesseract-data-ukr
   123) tesseract-data-urd  124) tesseract-data-uzb  125) tesseract-data-uzb_cyrl  126) tesseract-data-vie  127) tesseract-data-yid
   128) tesseract-data-yor
Enter a number (default=1):
warning: could not fully load metadata for package opencv-5.0.0-5
error: failed to prepare transaction (invalid or corrupted package)
You could try tagging opencv onto the pacman command. (Sure I’ve needed to do this before for some package or other). All branches currently have version 5.0.0.7.
Another option is to remove then reinstall the offending package, but that would also need to be done for spectacle and the other package which depend on it.
As for the tesseract choice, I’d pick 30 but it’s up to you. :slightly_smiling_face:
Also, it’s always advised to provide output of inxi -zv8 rather than just a few details. :wink:
Create the missing file with sudo touch /var/lib/pacman/local/opencv-5.0.0-5/desc and try again.
Hello again -
When I tried to update opencv with pamac update command (I’m most familiar with that) it kicked me back to the tessdata update dialogue:
rsv2@reid-galagopro:~$ pamac update opencv
Preparing...
Authenticating as: Reid (rsv2)
Password:
Refreshing AUR...
cp: cannot access '/var/lib/pacman/sync/download-TT8XPv': Permission denied
Choose a provider for tessdata:
  1:  tesseract-data-afr           2:4.1.0-5  extra
  2:  tesseract-data-amh           2:4.1.0-5  extra
  3:  tesseract-data-ara           2:4.1.0-5  extra
  4:  tesseract-data-asm           2:4.1.0-5  extra
  5:  tesseract-data-aze           2:4.1.0-5  extra
I selected 30, it rejected that and restarted the same…
Enter a number (default=1): 30
Resolving dependencies...
As for inxi output…that’s shown below,
rsv2@reid-galagopro:~$ inxi -zv8
  Kernel: 6.18.38-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 16.1.1
    root=UUID=6c1f5b80-96fa-4e72-b95e-ee99c44cd85d rw quiet apparmor=1
  Desktop: KDE Plasma v: 6.6.6 tk: Qt v: N/A info: frameworks v: 6.27.0
  Type: Laptop System: System76 product: Galago Pro v: galp5
    serial: <superuser required> Chassis: type: 9 serial: <superuser required>
  Mobo: System76 model: Galago Pro v: galp5 serial: <superuser required>
    Firmware: UEFI vendor: coreboot v: 2025-07-29_6f4c4bf date: 07/29/2025
  ID-1: BAT0 charge: 27.3 Wh (72%) condition: 37.9/49.4 Wh (76.8%) volts: 17.3
    min: 15.2 model: Notebook BAT type: Li-ion serial: <filter> charging:
    status: charging control: start: 90% end: 100% cycles: 594
  Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M325
    status: discharging
  System RAM: total: 16 GiB available: 15.46 GiB used: 2.56 GiB (16.6%)
  Array-1: capacity: 128 GiB note: check slots: 2 modules: 2 EC: None
    max-module-size: 64 GiB note: est.
  Device-1: Channel-0-DIMM-0 type: DDR4 detail: N/A size: 8 GiB speed:
    spec: 2667 MT/s actual: 3200 MT/s volts: note: check curr: 1 min: 1 max: 1
    width (bits): data: 64 total: 64 manufacturer: Samsung
    part-no: M471A1K43DB1-CWE serial: <filter>
  Device-2: Channel-0-DIMM-0 type: DDR4 detail: N/A size: 8 GiB speed:
  Info: model: 11th Gen Intel Core i7-1165G7 bits: 64 type: MT MCP
    arch: Tiger Lake gen: core 11 level: v4 note: check built: 2020
    process: Intel 10nm family: 6 model-id: 0x8C (140) stepping: 1
    microcode: 0xBE
  Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 threads: 8 tpc: 2
    smt: enabled cache: L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB
    desc: 4x1.2 MiB L3: 12 MiB desc: 1x12 MiB
  Speed (MHz): avg: 400 min/max: 400/4700 scaling: driver: intel_pstate
    governor: powersave cores: 1: 400 2: 400 3: 400 4: 400 5: 400 6: 400 7: 400
    8: 400 bogomips: 44851
    arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
    avx512_vnni avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd
    avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts cat_l2
    cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid cpuid_fault cx16
    cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
    flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp hwp_act_window hwp_epp
    hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt invpcid
    lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b movdiri msr mtrr
    nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs
    pge pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed rdt_a rdtscp
    rep_good sdbg sep sha_ni smap smep split_lock_detect ss ssbd sse sse2
    tsc_deadline_timer tsc_known_freq umip user_shstk vaes vme vmx vnmi
    vpclmulqdq vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology
    xtpr
  Type: indirect_target_selection mitigation: Aligned branch/return thunks
    conditional; PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW loop
  Type: vmscape status: Not affected
  Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: CLEVO/KAPOK
    driver: i915 v: kernel alternate: xe arch: Xe process: Intel 10nm
    built: 2020-21 ports: active: DP-1,eDP-1 empty: DP-2, DP-3, DP-4, HDMI-A-1
    bus-ID: 00:02.0 chip-ID: 8086:9a49 class-ID: 0300
  Device-2: Bison BisonCam NB Pro driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-7:3 chip-ID: 5986:9102
    class-ID: 0e02
  Display: wayland server: X.org v: 1.21.1.24 with: Xwayland v: 24.1.13
    alternate: fbdev,vesa dri: iris gpu: i915 d-rect: 3840x1080 display-ID: 0
  Monitor-1: DP-1 pos: right model: HP VH240a serial: <filter> built: 2020
    res: mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 93 gamma: 1.2 chroma: red:
    x: 0.655 y: 0.337 green: x: 0.322 y: 0.612 blue: x: 0.153 y: 0.059 white:
    x: 0.314 y: 0.329 size: 527x296mm (20.75x11.65") diag: 604mm (23.8")
    ratio: 16:9 modes: 1920x1080, 1680x1050, 1600x900, 1280x1024, 1440x900,
    1280x800, 1280x720, 1024x768, 800x600, 720x576, 720x480, 640x480, 720x400
  Monitor-2: eDP-1 pos: primary,left model: ChiMei InnoLux 0x14f2
    built: 2018 res: mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 158 gamma: 1.2
    chroma: red: x: 0.639 y: 0.329 green: x: 0.298 y: 0.600 blue: x: 0.149
    y: 0.059 white: x: 0.314 y: 0.329 size: 309x173mm (12.17x6.81")
    diag: 354mm (13.9") ratio: 16:9 modes: 1920x1080
    drv: iris x11: drv: iris
  API: OpenGL v: 4.6 vendor: intel mesa v: 26.1.4-arch1.1 glx-v: 1.4
    direct-render: yes renderer: Mesa Intel Iris Xe Graphics (TGL GT2)
    device-ID: 8086:9a49 memory: 15.1 GiB unified: yes display-ID: :1.0
  API: Vulkan v: 1.4.350 layers: 2 device: 0 type: integrated-gpu name: Intel
    Iris Xe Graphics (TGL GT2) driver: mesa intel v: 26.1.4-arch1.1
    device-ID: 8086:9a49 surfaces: N/A
  Device-1: Intel 500 Series Family On-Package High Definition Audio
    vendor: CLEVO/KAPOK driver: snd_hda_intel v: kernel
    alternate: snd_soc_avs,snd_sof_pci_intel_tgl bus-ID: 00:1f.3
    chip-ID: 8086:a0c8 class-ID: 0403
  Device-2: No brand CalDigit Thunderbolt 3 Audio
    driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 5-2:2 chip-ID: 2188:6533 class-ID: 0300
  API: ALSA v: k6.18.38-1-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.6.7 status: off with: pipewire-media-session
    status: active tools: pw-cli
  Server-4: PulseAudio v: 17.0-98-gb096 status: active with: pulseaudio-alsa
    type: plugin tools: pacat,pactl,pavucontrol
  Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 00:14.3
    chip-ID: 8086:a0f0 class-ID: 0280
  Device-2: Intel I210 Gigabit Network vendor: CalDigit TS3 Plus
    Thunderbolt 3 Dock PCIe NIC driver: igb v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 port: 5000 bus-ID: 07:00.0 chip-ID: 8086:1533
    class-ID: 0200
  IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-3: Realtek RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet
    vendor: CLEVO/KAPOK driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 port: d000 bus-ID: 0d:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp13s0 state: down mac: <filter>
  IF-ID-1: virbr0 state: down mac: <filter>
  Info: services: NetworkManager, smbd, systemd-timesyncd, wpa_supplicant
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:4 chip-ID: 8087:0026
    class-ID: e001
  Local Storage: total: 465.76 GiB used: 225.07 GiB (48.3%)
    model: SSD 970 EVO Plus 500GB size: 465.76 GiB block-size: physical: 512 B
    fw-rev: 2B2QEXM7 temp: 39.9 C scheme: GPT
  ID-1: / raw-size: 34.18 GiB size: 33.35 GiB (97.56%) used: 23.48 GiB (70.4%)
    fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
    uuid: 6c1f5b80-96fa-4e72-b95e-ee99c44cd85d
    used: 22.9 MiB (4.5%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: 8248-A46B
  ID-3: /home raw-size: 427.08 GiB size: 419.31 GiB (98.18%)
    used: 201.57 GiB (48.1%) fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3
    label: Home uuid: f2813d37-ab65-4392-874c-37ceddcb7694
  ID-1: swap-1 type: partition size: 4 GiB used: 0 KiB (0.0%) priority: -2
    dev: /dev/nvme0n1p4 maj-min: 259:4 label: N/A
    uuid: c8e9710a-d939-4dc7-9aab-5ea7ce86551a
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 3-3:2 info: Logitech Unifying Receiver type: keyboard,mouse,HID
    driver: logitech-djreceiver,usbhid interfaces: 3 rev: 2.0
    chip-ID: 046d:c52b class-ID: 0300
  Device-2: 3-7:3 info: Bison BisonCam NB Pro type: video driver: uvcvideo
    interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
    power: 500mA chip-ID: 5986:9102 class-ID: 0e02
  Device-3: 3-10:4 info: Intel AX201 Bluetooth type: bluetooth driver: btusb
    power: 100mA chip-ID: 8087:0026 class-ID: e001
  Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
  Device-1: 5-2:2 info: No brand CalDigit Thunderbolt 3 Audio
    type: audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 4
    rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 100mA
  Hub-6: 6-0:1 info: super-speed hub ports: 4 rev: 3.0
  Hub-7: 7-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
  Hub-8: 7-3:2 info: Dell USB 2.0 Hub [MTT] ports: 4 rev: 2.0
    chip-ID: 413c:1010 class-ID: 0900
  Device-1: 7-3.4:3 info: Dell Wired Multimedia Keyboard
    type: keyboard,mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
    speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0 power: 98mA
    chip-ID: 413c:2110 class-ID: 0301
  Hub-9: 8-0:1 info: super-speed hub ports: 4 rev: 3.0
  Device-1: 8-4:2 info: No brand Card Reader type: mass storage
    driver: usb-storage interfaces: 1 rev: 3.1 speed: 5 Gb/s (596.0 MiB/s)
    lanes: 1 mode: 3.2 gen-1x1 power: 896mA chip-ID: 2188:0747 class-ID: 0806
    serial: <filter>
  Hub-10: 9-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-11: 10-0:1 info: super-speed hub ports: 2 rev: 3.1
  System Temperatures: cpu: 67.0 C mobo: N/A
  Fan Speeds (rpm): cpu: 0
  Packages: 1899 pm: pacman pkgs: 1887 libs: 476 tools: octopi,pamac,paru,yay
    pm: flatpak pkgs: 6 pm: snap pkgs: 6
    1: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
    2: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
    3: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
    4: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
    5: https://distrohub.kyiv.ua/manjaro/stable/$repo/$arch
    6: https://mirrors.xtom.jp/manjaro/stable/$repo/$arch
    7: https://mirror.aarnet.edu.au/pub/manjaro/stable/$repo/$arch
    8: https://mirrors.sjtug.sjtu.edu.cn/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 276
  1: cpu: 87.6% command: pamac-checkupdates pid: 2068 mem: 715.1 MiB (4.5%)
  2: cpu: 18.1% command: plasmashell pid: 1357 mem: 312.8 MiB (1.9%)
  3: cpu: 5.3% command: kwin_wayland pid: 1195 mem: 185.8 MiB (1.1%)
  4: cpu: 4.1% command: baloo_file pid: 1196 mem: 94.5 MiB (0.5%)
  5: cpu: 1.9% command: init pid: 1 mem: 14.6 MiB (0.0%)
  Memory top: 5 of 276
  1: mem: 715.1 MiB (4.5%) command: pamac-checkupdates pid: 2068 cpu: 87.6%
  2: mem: 312.8 MiB (1.9%) command: plasmashell pid: 1357 cpu: 18.1%
  3: mem: 185.8 MiB (1.1%) command: kwin_wayland pid: 1195 cpu: 5.3%
  4: mem: 124.7 MiB (0.7%) command: konsole pid: 1991 cpu: 1.1%
  5: mem: 116.7 MiB (0.7%) command: kded6 pid: 1312 cpu: 0.8%
  Processes: 276 Power: uptime: 1m states: freeze,mem,disk suspend: s2idle
    image: 6.16 GiB services: org_kde_powerdevil,upowerd Init: systemd v: 261
  Compilers: gcc: 16.1.1 Shell: Bash v: 5.3.15 running-in: konsole
    inxi: 3.3.41
Question at the colleagues since i have no experience with that error, but it looks like broken database to me? Wouldn’t it be better to refresh and resync mirrors first? And as an exception do a Syyu?
Too many tools.
Probably you ran any of pamac,paru,yay as sudo. But the folder can be removed
sudo rm -r /var/lib/pacman/sync/download-TT8XPv
Then try again :man_shrugging:
Opentrack won’t compile with opencv 5 either. I had already downgraded to opencv 4 before this update and didn’t have any problems. Sorry, not a fix but might help with the troubleshooting.
Any chance of getting OpenTrack in the main repos? It’s the only AUR package I’m using.
Don’t hijack topics from other people with completely unrelated problems…and aur at that! :enraged_face:
jofi -
you are right, I did misunderstand the pamac syntax and stopped doing that (since it failed!) but that was some time ago, but I guess that created an issue. I removed it…
rsv2@reid-galagopro:~$ ls -l /var/lib/pacman/sync/download-TT8XPv
ls: cannot access '/var/lib/pacman/sync/download-TT8XPv': No such file or directory
retried the update and get the same tessdata dialogue
I might have too many tools, but not intentionally, I do like octopi and pamac. Are they stepping on each other?
Did you do
sudo pacman -Syu
The tesseract dialog is normal. Spectacle needs it, so you have to choose a language.
Mod Edit: Added the rest of the solution for posterity
sudo touch /var/lib/pacman/local/opencv-5.0.0-5/files
sudo pacman -Syu --overwrite="*"
Hi -
Yes I’m not surprised Spectacle needs it. Mine is FUBAR. Was broken after the update (before the current update).
Update from your suggested commands:
rsv2@reid-galagopro:~$ sudo touch /var/lib/pacman/local/opencv-5.0.0-5/desc
rsv2@reid-galagopro:~$ sudo rm -r /var/lib/pacman/sync/download-TT8XPv
rm: cannot remove '/var/lib/pacman/sync/download-TT8XPv': No such file or directory
 core is up to date
 extra is up to date
:: Repository extra
   1) tesseract-data-afr  2) tesseract-data-amh  3) tesseract-data-ara  4) tesseract-data-asm  5) tesseract-data-aze  6) tesseract-data-aze_cyrl  7) tesseract-data-bel
   8) tesseract-data-ben  9) tesseract-data-bod  10) tesseract-data-bos  11) tesseract-data-bre  12) tesseract-data-bul  13) tesseract-data-cat  14) tesseract-data-ceb
   15) tesseract-data-ces  16) tesseract-data-chi_sim  17) tesseract-data-chi_sim_vert  18) tesseract-data-chi_tra  19) tesseract-data-chi_tra_vert  20) tesseract-data-chr
   21) tesseract-data-cos  22) tesseract-data-cym  23) tesseract-data-dan  24) tesseract-data-dan_frak  25) tesseract-data-deu  26) tesseract-data-deu_frak  27) tesseract-data-div
   28) tesseract-data-dzo  29) tesseract-data-ell  30) tesseract-data-eng  31) tesseract-data-enm  32) tesseract-data-epo  33) tesseract-data-equ  34) tesseract-data-est
   35) tesseract-data-eus  36) tesseract-data-fao  37) tesseract-data-fas  38) tesseract-data-fil  39) tesseract-data-fin  40) tesseract-data-fra  41) tesseract-data-frk
   42) tesseract-data-frm  43) tesseract-data-fry  44) tesseract-data-gla  45) tesseract-data-gle  46) tesseract-data-glg  47) tesseract-data-grc  48) tesseract-data-guj
   49) tesseract-data-hat  50) tesseract-data-heb  51) tesseract-data-hin  52) tesseract-data-hrv  53) tesseract-data-hun  54) tesseract-data-hye  55) tesseract-data-iku
   56) tesseract-data-ind  57) tesseract-data-isl  58) tesseract-data-ita  59) tesseract-data-ita_old  60) tesseract-data-jav  61) tesseract-data-jpn  62) tesseract-data-jpn_vert
   63) tesseract-data-kan  64) tesseract-data-kat  65) tesseract-data-kat_old  66) tesseract-data-kaz  67) tesseract-data-khm  68) tesseract-data-kir  69) tesseract-data-kmr
   70) tesseract-data-kor  71) tesseract-data-kor_vert  72) tesseract-data-lao  73) tesseract-data-lat  74) tesseract-data-lav  75) tesseract-data-lit  76) tesseract-data-ltz
   77) tesseract-data-mal  78) tesseract-data-mar  79) tesseract-data-mkd  80) tesseract-data-mlt  81) tesseract-data-mon  82) tesseract-data-mri  83) tesseract-data-msa
   84) tesseract-data-mya  85) tesseract-data-nep  86) tesseract-data-nld  87) tesseract-data-nor  88) tesseract-data-oci  89) tesseract-data-ori  90) tesseract-data-pan
   91) tesseract-data-pol  92) tesseract-data-por  93) tesseract-data-pus  94) tesseract-data-que  95) tesseract-data-ron  96) tesseract-data-rus  97) tesseract-data-san
   98) tesseract-data-sin  99) tesseract-data-slk  100) tesseract-data-slk_frak  101) tesseract-data-slv  102) tesseract-data-snd  103) tesseract-data-spa  104) tesseract-data-spa_old
   105) tesseract-data-sqi  106) tesseract-data-srp  107) tesseract-data-srp_latn  108) tesseract-data-sun  109) tesseract-data-swa  110) tesseract-data-swe  111) tesseract-data-syr
   112) tesseract-data-tam  113) tesseract-data-tat  114) tesseract-data-tel  115) tesseract-data-tgk  116) tesseract-data-tgl  117) tesseract-data-tha  118) tesseract-data-tir
   119) tesseract-data-ton  120) tesseract-data-tur  121) tesseract-data-uig  122) tesseract-data-ukr  123) tesseract-data-urd  124) tesseract-data-uzb  125) tesseract-data-uzb_cyrl
   126) tesseract-data-vie  127) tesseract-data-yid  128) tesseract-data-yor
error: could not open file /var/lib/pacman/local/opencv-5.0.0-5/files: No such file or directory
Is it time for me to just re-install? I don’t want to waste all of your time, folks. It’s a lot of cycles. I appreciate you taking the time you have spent already.
If there are no intervening replies, please edit your previous post instead to add further information. Cheers!
:wink:
The question is how did it got broken…if you have an interrupted update due to power outage of filesystem damage, there will be such errors in many packages. The restoration is complicated so indeed a reinstallation may be easier.
But let us stay positive and hope only opencv is broken. In that case, you can try the following:
No, why? Just same procedure again
sudo pacman -Syu
THAT’S WHAT I’m talking about !!! Update in progress…yea… this could take a bit !
I did have an update that was interrupted. it just failed…two updates ago, before the Spectacle errors started…
You got a bit lucky that the third file in that folder - the mtree was ok. Because replacing it with an empty file would have later bitten you in the posterior. But the files and desc are not so important.
p.s. the homework
ummm… still an issue…message at the bottom:
              networkmanager-vpn-plugin-pptp-1.2.12-8  npm-12.0.1-1  nss-3.126-1  ntfs-3g-2026.7.7-1  ntfsprogs-2026.7.7-1  ocean-sound-theme-6.7.3-1  onetbb-2023.1.0-1
               openconnect-1:9.21-1  opencv-5.0.0-7  openssh-10.4p1-3  openucx-1.20.1-2  ostree-2026.2-1  oxygen-6.7.3-1  oxygen-cursors-6.7.3-1  oxygen-icons-1:6.28.0-1
               oxygen-sounds-6.7.3-1  oxygen5-6.7.3-1  p11-kit-0.26.4-1  perl-alien-build-2.84-5  perl-dbi-1.651-1  perl-http-date-6.08-1  perl-http-message-7.03-1  pipewire-1:1.6.8-1
               pkgconf-3.0.3-1  plasma-activities-6.7.3-1  plasma-activities-stats-6.7.3-1  plasma-browser-integration-6.7.3-1  plasma-desktop-6.7.3-1  plasma-disks-6.7.3-1
               plasma-firewall-6.7.3-1  plasma-integration-6.7.3-1  plasma-nm-6.7.3-1  plasma-pa-6.7.3-1  plasma-sdk-6.7.3-1  plasma-systemmonitor-6.7.3-1  plasma-thunderbolt-6.7.3-1
               plasma-vault-6.7.3-1  plasma-welcome-6.7.3-1  plasma-workspace-6.7.3-1  plasma-workspace-wallpapers-6.7.3-1  plasma5-integration-6.7.3-1  plasma5support-6.7.3-1
               plymouth-26.134.222-3  plymouth-kcm-6.7.3-1  polkit-kde-agent-6.7.3-1  poppler-26.07.0-1  poppler-glib-26.07.0-1  poppler-qt6-26.07.0-1  powerdevil-6.7.3-1  ppp-2.5.3-1
               print-manager-1:6.7.3-1  prison-6.28.0-1  purpose-6.28.0-1  python-dropbox-12.2.1-1  python-grpcio-1.82.1-1  python-grpcio-tools-1.82.1-1  python-platformdirs-4.11.0-1
               python-sentry_sdk-2.66.0-1  python-stone-3.5.3-1  qbittorrent-5.2.3-3  qemu-audio-spice-11.0.2-4  qemu-base-11.0.2-4  qemu-block-curl-11.0.2-4  qemu-block-dmg-11.0.2-4
               qemu-block-nfs-11.0.2-4  qemu-block-ssh-11.0.2-4  qemu-chardev-spice-11.0.2-4  qemu-common-11.0.2-4  qemu-hw-display-qxl-11.0.2-4  qemu-hw-display-virtio-gpu-11.0.2-4
               qemu-hw-display-virtio-gpu-gl-11.0.2-4  qemu-hw-display-virtio-gpu-pci-11.0.2-4  qemu-hw-display-virtio-gpu-pci-gl-11.0.2-4  qemu-hw-display-virtio-vga-11.0.2-4
               qemu-hw-display-virtio-vga-gl-11.0.2-4  qemu-hw-s390x-virtio-gpu-ccw-11.0.2-4  qemu-hw-usb-host-11.0.2-4  qemu-hw-usb-redirect-11.0.2-4  qemu-hw-usb-smartcard-11.0.2-4
               qemu-img-11.0.2-4  qemu-pr-helper-11.0.2-4  qemu-system-x86-11.0.2-4  qemu-system-x86-firmware-11.0.2-4  qemu-tools-11.0.2-4  qemu-ui-curses-11.0.2-4
               qemu-ui-opengl-11.0.2-4  qemu-ui-spice-app-11.0.2-4  qemu-ui-spice-core-11.0.2-4  qgpgme-2.2.0-1  qqc2-breeze-style-6.7.3-1  qqc2-desktop-style-6.28.0-1  qt-sudo-2.4.1-1
               rawtherapee-1:5.12-3  rdma-core-64.0-1  ripgrep-15.2.0-1  rpm-sequoia-1.10.2-2  rpm-tools-6.0.1-2  ruby-3.4.10-1  ruby-bundled-gems-3.4.10-1  ruby-default-gems-3.4.10-1
               ruby-erb-4.0.4.1-1  ruby-minitest-5.27.0-1  ruby-net-imap-0.5.15-1  ruby-nkf-0.3.0-1  ruby-rake-13.4.2-1  ruby-rbs-3.9.2-1  ruby-stdlib-3.4.10-1  ruby-test-unit-3.7.8-1
               sddm-kcm-6.7.3-1  shared-mime-info-2.5.1-2  socat-1.8.1.3-1  solid-6.28.0-1  sonnet-6.28.0-1  spectacle-1:6.7.3-1  srt-1.5.6-1  stress-ng-0.21.04-2  svt-av1-4.2.0-1
               syndication-6.28.0-1  syntax-highlighting-6.28.1-1  syslinux-6.04.pre3.r3.g05ac953c-5  systemsettings-6.7.3-1  taglib-2.3.1-1  tesseract-5.5.2-1
               tesseract-data-eng-2:4.1.0-5  tesseract-data-osd-2:4.1.0-5  threadweaver-6.28.0-1  thunar-4.20.9-1  thunderbird-152.0.1-1  tzdata-2026c-1  vim-9.2.0804-1
               vim-runtime-9.2.0804-1  virt-install-5.1.0-4  virt-manager-5.1.0-4  vulkan-intel-1:26.1.5-1  vulkan-mesa-implicit-layers-1:26.1.5-1  vulkan-radeon-1:26.1.5-1
               wacomtablet-6.7.3-1  webkit2gtk-4.1-2.52.5-2  wget-1.25.0-6  wine-11.13-1  xdg-desktop-portal-kde-6.7.3-1  xorg-mkfontscale-1.2.4-2  xorg-xmodmap-1.0.12-1  xorg-xrdb-1.2.3-1
               xorg-xset-1.2.6-1  zbar-0.23.93-7  zsh-5.9.2-1
Total Download Size:   1909.80 MiB
Total Installed Size:  5845.25 MiB
Net Upgrade Size:       254.89 MiB
:: Proceed with installation? [Y/n] y
:: Retrieving packages...
 plasma-workspace-wallpapers-6.7.3-1-any                                              254.2 MiB  10.8 MiB/s 00:24 [####################################################################] 100%
 libreoffice-fresh-26.2.4-4-x86_64                                                    147.2 MiB  10.8 MiB/s 00:14 [####################################################################] 100%
 linux618-6.18.39-1-x86_64                                                            145.8 MiB  10.8 MiB/s 00:13 [####################################################################] 100%
 linux612-6.12.96-1-x86_64                                                            141.0 MiB  10.8 MiB/s 00:13 [####################################################################] 100%
 chromium-150.0.7871.181-1-x86_64                                                     127.8 MiB  10.8 MiB/s 00:12 [####################################################################] 100%
 firefox-153.0-1-x86_64        83.0 MiB  10.7 MiB/s 00:08 [####################################################################] 100%
 electron39-39.8.10-2-x86_64                                                           80.5 MiB  11.0 MiB/s 00:07 [####################################################################] 100%
 thunderbird-152.0.1-1-x86_64                                                          77.9 MiB  10.7 MiB/s 00:07 [####################################################################] 100%
 wine-11.13-1-x86_64        77.5 MiB  10.7 MiB/s 00:07 [####################################################################] 100%
 gcc-16.1.1+r346+g4e03491b401d-4-x86_64                                                57.8 MiB  11.0 MiB/s 00:05 [####################################################################] 100%
 lib32-llvm-libs-1:22.1.8-1-x86_64                                                     42.3 MiB  10.4 MiB/s 00:04 [####################################################################] 100%
 llvm-libs-22.1.8-2-x86_64                                                             41.0 MiB  11.0 MiB/s 00:04 [####################################################################] 100%
 breeze-6.7.3-1-x86_64        40.1 MiB  11.0 MiB/s 00:04 [####################################################################] 100%
 webkit2gtk-4.1-2.52.5-2-x86_64                                                        36.1 MiB  10.2 MiB/s 00:04 [####################################################################] 100%
 opencv-5.0.0-7-x86_64        33.9 MiB  11.0 MiB/s 00:03 [####################################################################] 100%
 oxygen-icons-1:6.28.0-1-any                                                           32.0 MiB  11.0 MiB/s 00:03 [####################################################################] 100%
 oxygen-6.7.3-1-x86_64        30.1 MiB  10.1 MiB/s 00:03 [####################################################################] 100%
 gimp-3.2.4-2-x86_64        23.7 MiB  10.9 MiB/s 00:02 [####################################################################] 100%
 plasma-workspace-6.7.3-1-x86_64                                                       21.1 MiB  10.9 MiB/s 00:02 [####################################################################] 100%
 rawtherapee-1:5.12-3-x86_64                                                           21.1 MiB  10.9 MiB/s 00:02 [####################################################################] 100%
 plasma-desktop-6.7.3-1-x86_64                                                         18.2 MiB  10.9 MiB/s 00:02 [####################################################################] 100%
 cmake-4.4.0-2-x86_64        14.9 MiB  10.9 MiB/s 00:01 [####################################################################] 100%
 ffmpeg-2:8.1.2-10-x86_64                                                              14.8 MiB  9.28 MiB/s 00:02 [####################################################################] 100%
 mesa-1:26.1.5-1-x86_64        13.2 MiB  10.9 MiB/s 00:01 [####################################################################] 100%
 lib32-mesa-1:26.1.5-1-x86_64                                                          13.1 MiB  10.9 MiB/s 00:01 [####################################################################] 100%
 lib32-gcc-libs-16.1.1+r346+g4e03491b401d-4-x86_64                                     10.8 MiB  10.8 MiB/s 00:01 [####################################################################] 100%
 kwin-6.7.3-1-x86_64        10.6 MiB  10.8 MiB/s 00:01 [####################################################################] 100%
 tesseract-data-eng-2:4.1.0-5-any                                                       9.0 MiB  10.8 MiB/s 00:01 [####################################################################] 100%
 imagemagick-7.1.2.27-1-x86_64                                                          8.9 MiB  10.7 MiB/s 00:01 [####################################################################] 100%
 gmic-4.0.3-2-x86_64        8.7 MiB  10.7 MiB/s 00:01 [####################################################################] 100%
 qbittorrent-5.2.3-3-x86_64                                                             8.2 MiB  10.7 MiB/s 00:01 [####################################################################] 100%
 breeze-icons-6.28.0-1-x86_64                                                           7.9 MiB  10.7 MiB/s 00:01 [####################################################################] 100%
 kwin-x11-6.7.3-1-x86_64        7.8 MiB  10.7 MiB/s 00:01 [####################################################################] 100%
 vim-runtime-9.2.0804-1-x86_64                                                          7.6 MiB  10.7 MiB/s 00:01 [####################################################################] 100%
 qemu-system-x86-11.0.2-4-x86_64                                                        6.3 MiB  10.6 MiB/s 00:01 [####################################################################] 100%
 boost-libs-1.91.0-2-x86_64                                                             6.1 MiB  10.6 MiB/s 00:01 [####################################################################] 100%
 vulkan-intel-1:26.1.5-1-x86_64                                                         4.8 MiB  10.5 MiB/s 00:00 [####################################################################] 100%
 lib32-vulkan-intel-1:26.1.5-1-x86_64                                                   4.8 MiB  10.5 MiB/s 00:00 [####################################################################] 100%
 ruby-3.4.10-1-x86_64        4.2 MiB  10.4 MiB/s 00:00 [####################################################################] 100%
 libguestfs-1.60.1-1-x86_64                                                             3.8 MiB  10.3 MiB/s 00:00 [####################################################################] 100%
 glycin-2.1.5-2-x86_64        3.8 MiB  10.4 MiB/s 00:00 [####################################################################] 100%
 networkmanager-1.56.1-2-x86_64                                                         3.7 MiB  10.3 MiB/s 00:00 [####################################################################] 100%
 kio-6.28.0-1-x86_64        3.7 MiB  10.4 MiB/s 00:00 [####################################################################] 100%
 python-grpcio-1.82.1-1-x86_64                                                          3.7 MiB  10.4 MiB/s 00:00 [####################################################################] 100%
 stress-ng-0.21.04-2-x86_64                                                             3.7 MiB  10.3 MiB/s 00:00 [####################################################################] 100%
 netpbm-10.86.50-2-x86_64                                                               3.7 MiB  10.4 MiB/s 00:00 [####################################################################] 100%
 tesseract-data-osd-2:4.1.0-5-any                                                       3.6 MiB  10.3 MiB/s 00:00 [####################################################################] 100%
 libtorrent-rasterbar-1:2.1.0-3-x86_64                                                  3.6 MiB  10.3 MiB/s 00:00 [####################################################################] 100%
 kdeplasma-addons-6.7.3-1-x86_64                                                        3.5 MiB  10.3 MiB/s 00:00 [####################################################################] 100%
 vulkan-radeon-1:26.1.5-1-x86_64                                                        3.4 MiB  10.3 MiB/s 00:00 [####################################################################] 100%
 lib32-vulkan-radeon-1:26.1.5-1-x86_64                                                  3.4 MiB  10.3 MiB/s 00:00 [####################################################################] 100%
 libqalculate-5.12.0-1-x86_64                                                           3.2 MiB  10.3 MiB/s 00:00 [####################################################################] 100%
 gst-plugins-bad-libs-1.28.5-2-x86_64                                                   3.2 MiB  10.1 MiB/s 00:00 [####################################################################] 100%
 libvips-8.18.4-2-x86_64        3.0 MiB  10.2 MiB/s 00:00 [####################################################################] 100%
 coreutils-9.11-2-x86_64        2.9 MiB  10.2 MiB/s 00:00 [####################################################################] 100%
 ktexteditor-6.28.0-1-x86_64                                                            2.9 MiB  10.2 MiB/s 00:00 [####################################################################] 100%
 gnupg-2.4.9-2-x86_64        2.9 MiB  10.2 MiB/s 00:00 [####################################################################] 100%
 graphicsmagick-1.3.47-2-x86_64                                                         2.8 MiB  10.1 MiB/s 00:00 [####################################################################] 100%
 freerdp-2:3.30.0-1-x86_64                                                              2.7 MiB  10.1 MiB/s 00:00 [####################################################################] 100%
 rdma-core-64.0-1-x86_64        2.7 MiB  10.1 MiB/s 00:00 [####################################################################] 100%
 vim-9.2.0804-1-x86_64        2.5 MiB  10.1 MiB/s 00:00 [####################################################################] 100%
 libplasma-6.7.3-1-x86_64                                                               2.5 MiB  10.1 MiB/s 00:00 [####################################################################] 100%
 gst-plugins-base-libs-1.28.5-2-x86_64                                                  2.5 MiB  5.10 MiB/s 00:00 [####################################################################] 100%
 gst-plugins-good-1.28.5-2-x86_64                                                       2.3 MiB  9.99 MiB/s 00:00 [####################################################################] 100%
 zsh-5.9.2-1-x86_64        2.3 MiB  9.97 MiB/s 00:00 [####################################################################] 100%
 kirigami-addons-1.13.1-1-x86_64                                                        2.2 MiB  9.97 MiB/s 00:00 [####################################################################] 100%
 qemu-img-11.0.2-4-x86_64                                                               2.2 MiB  9.96 MiB/s 00:00 [####################################################################] 100%
 kwidgetsaddons-6.28.0-1-x86_64                                                         2.2 MiB  9.95 MiB/s 00:00 [####################################################################] 100%
 openucx-1.20.1-2-x86_64        2.2 MiB  9.91 MiB/s 00:00 [####################################################################] 100%
 gstreamer-1.28.5-2-x86_64                                                              2.1 MiB  9.87 MiB/s 00:00 [####################################################################] 100%
 libcamera-ipa-0.7.2-3-x86_64                                                           2.1 MiB  9.88 MiB/s 00:00 [####################################################################] 100%
 spectacle-1:6.7.3-1-x86_64                                                             2.1 MiB  9.87 MiB/s 00:00 [####################################################################] 100%
 ktextaddons-2.1.1-1-x86_64                                                             2.1 MiB  9.85 MiB/s 00:00 [####################################################################] 100%
 plasma-nm-6.7.3-1-x86_64                                                               2.0 MiB  9.86 MiB/s 00:00 [####################################################################] 100%
 svt-av1-4.2.0-1-x86_64                                                              2022.6 KiB  9.83 MiB/s 00:00 [####################################################################] 100%
 ocean-sound-theme-6.7.3-1-any                                                       1978.5 KiB  9.81 MiB/s 00:00 [####################################################################] 100%
 qemu-common-11.0.2-4-x86_64                                                         1935.7 KiB  9.74 MiB/s 00:00 [####################################################################] 100%
 libjxl-0.12.0-1-x86_64                                                              1902.0 KiB  9.72 MiB/s 00:00 [####################################################################] 100%
 kscreen-6.7.3-1-x86_64                                                              1897.4 KiB  9.75 MiB/s 00:00 [####################################################################] 100%
 oxygen-sounds-6.7.3-1-any                                                           1890.7 KiB  9.67 MiB/s 00:00 [####################################################################] 100%
 poppler-26.07.0-1-x86_64                                                            1848.9 KiB  9.71 MiB/s 00:00 [####################################################################] 100%
 npm-12.0.1-1-any        1784.1 KiB  9.68 MiB/s 00:00 [####################################################################] 100%
 nss-3.126-1-x86_64        1736.0 KiB  9.63 MiB/s 00:00 [####################################################################] 100%
 ki18n-6.28.0-1-x86_64                                                               1720.9 KiB  9.66 MiB/s 00:00 [####################################################################] 100%
 tesseract-5.5.2-1-x86_64                                                            1690.6 KiB  9.60 MiB/s 00:00 [####################################################################] 100%
 powerdevil-6.7.3-1-x86_64                                                           1632.3 KiB  9.55 MiB/s 00:00 [####################################################################] 100%
 thunar-4.20.9-1-x86_64                                                              1600.9 KiB  9.53 MiB/s 00:00 [####################################################################] 100%
 discover-6.7.3-1-x86_64                                                             1590.8 KiB  9.47 MiB/s 00:00 [####################################################################] 100%
 gawk-5.4.1-1-x86_64        1516.7 KiB  9.43 MiB/s 00:00 [####################################################################] 100%
 openssh-10.4p1-3-x86_64                                                             1451.3 KiB  9.39 MiB/s 00:00 [####################################################################] 100%
 ripgrep-15.2.0-1-x86_64                                                             1424.2 KiB  9.40 MiB/s 00:00 [####################################################################] 100%
 syslinux-6.04.pre3.r3.g05ac953c-5-x86_64                                            1408.3 KiB  9.36 MiB/s 00:00 [####################################################################] 100%
 btrfs-progs-7.1-1-x86_64                                                            1310.8 KiB  9.28 MiB/s 00:00 [####################################################################] 100%
 breeze-cursors-6.7.3-1-x86_64                                                       1270.9 KiB  9.19 MiB/s 00:00 [####################################################################] 100%
 kirigami-6.28.0-1-x86_64                                                            1270.8 KiB  9.26 MiB/s 00:00 [####################################################################] 100%
 syntax-highlighting-6.28.1-1-x86_64                                                 1232.1 KiB  9.18 MiB/s 00:00 [####################################################################] 100%
 plasma5support-6.7.3-1-x86_64                                                       1222.7 KiB  9.18 MiB/s 00:00 [####################################################################] 100%
 leptonica-1.87.0-1-x86_64                                                           1221.2 KiB  9.17 MiB/s 00:00 [####################################################################] 100%
 virt-install-5.1.0-4-any                                                            1215.0 KiB  9.13 MiB/s 00:00 [####################################################################] 100%
 man-db-2.13.1-2-x86_64                                                              1176.3 KiB  9.12 MiB/s 00:00 [####################################################################] 100%
 gst-plugins-bad-1.28.5-2-x86_64                                                     1164.4 KiB  9.10 MiB/s 00:00 [####################################################################] 100%
 python-dropbox-12.2.1-1-any                                                         1158.0 KiB  8.97 MiB/s 00:00 [####################################################################] 100%
 rpm-tools-6.0.1-2-x86_64                                                            1147.3 KiB  9.04 MiB/s 00:00 [####################################################################] 100%
 plymouth-26.134.222-3-x86_64                                                        1131.3 KiB  8.98 MiB/s 00:00 [####################################################################] 100%
 kunitconversion-6.28.0-1-x86_64                                                     1118.2 KiB  8.95 MiB/s 00:00 [####################################################################] 100%
 ruby-rbs-3.9.2-1-x86_64                                                             1070.9 KiB  8.94 MiB/s 00:00 [####################################################################] 100%
 plasma-welcome-6.7.3-1-x86_64                                                       1049.8 KiB  8.84 MiB/s 00:00 [####################################################################] 100%
 kmenuedit-6.7.3-1-x86_64                                                            1042.0 KiB  8.85 MiB/s 00:00 [####################################################################] 100%
 oxygen-cursors-6.7.3-1-x86_64                                                       1033.3 KiB  8.85 MiB/s 00:00 [####################################################################] 100%
 openconnect-1:9.21-1-x86_64                                                          972.7 KiB  8.80 MiB/s 00:00 [####################################################################] 100%
 python-sentry_sdk-2.66.0-1-any                                                       965.2 KiB  8.73 MiB/s 00:00 [####################################################################] 100%
 kinfocenter-6.7.3-1-x86_64                                                           962.0 KiB  8.70 MiB/s 00:00 [####################################################################] 100%
 libisl-0.28-1-x86_64        957.9 KiB  8.58 MiB/s 00:00 [####################################################################] 100%
 gimp-plugin-gmic-4.0.3-2-x86_64                                                      953.8 KiB  8.71 MiB/s 00:00 [####################################################################] 100%
 perl-dbi-1.651-1-x86_64                                                              951.9 KiB  8.69 MiB/s 00:00 [####################################################################] 100%
 libnm-1.56.1-2-x86_64        927.9 KiB  8.63 MiB/s 00:00 [####################################################################] 100%
 libgfortran-16.1.1+r346+g4e03491b401d-4-x86_64                                       926.5 KiB  8.62 MiB/s 00:00 [####################################################################] 100%
 rpm-sequoia-1.10.2-2-x86_64                                                          925.3 KiB  8.52 MiB/s 00:00 [####################################################################] 100%
 kde-cli-tools-6.7.3-1-x86_64                                                         908.5 KiB  8.61 MiB/s 00:00 [####################################################################] 100%
 libstdc++-16.1.1+r346+g4e03491b401d-4-x86_64                                         862.4 KiB  8.59 MiB/s 00:00 [####################################################################] 100%
 kxmlgui-6.28.0-1-x86_64                                                              853.7 KiB  8.51 MiB/s 00:00 [####################################################################] 100%
 ostree-2026.2-1-x86_64                                                               837.1 KiB  8.52 MiB/s 00:00 [####################################################################] 100%
 wacomtablet-6.7.3-1-x86_64                                                           836.8 KiB  8.42 MiB/s 00:00 [####################################################################] 100%
 libnbd-1.24.3-1-x86_64                                                               820.8 KiB  8.35 MiB/s 00:00 [####################################################################] 100%
 kcoreaddons-6.28.0-1-x86_64                                                          765.8 KiB  8.31 MiB/s 00:00 [####################################################################] 100%
 shared-mime-info-2.5.1-2-x86_64                                                      765.4 KiB  8.30 MiB/s 00:00 [####################################################################] 100%
 drkonqi-6.7.3-1-x86_64                                                               723.0 KiB  8.12 MiB/s 00:00 [####################################################################] 100%
 knewstuff-6.28.0-1-x86_64                                                            707.8 KiB  8.13 MiB/s 00:00 [####################################################################] 100%
 pipewire-1:1.6.8-1-x86_64                                                            705.4 KiB  8.20 MiB/s 00:00 [####################################################################] 100%
 wget-1.25.0-6-x86_64        704.6 KiB  8.09 MiB/s 00:00 [####################################################################] 100%
 libksysguard-6.7.3-1-x86_64                                                          704.5 KiB  8.09 MiB/s 00:00 [####################################################################] 100%
 libcamera-0.7.2-3-x86_64                                                             703.9 KiB  8.09 MiB/s 00:00 [####################################################################] 100%
 plasma-sdk-6.7.3-1-x86_64                                                            703.2 KiB  8.08 MiB/s 00:00 [####################################################################] 100%
 bluez-5.87-2-x86_64        679.7 KiB  8.00 MiB/s 00:00 [####################################################################] 100%
 xdg-desktop-portal-kde-6.7.3-1-x86_64                                                674.2 KiB  8.03 MiB/s 00:00 [####################################################################] 100%
 dav1d-1.5.4-1-x86_64        672.8 KiB  8.11 MiB/s 00:00 [####################################################################] 100%
 bluedevil-1:6.7.3-1-x86_64                                                           667.6 KiB  8.05 MiB/s 00:00 [####################################################################] 100%
 virt-manager-5.1.0-4-any                                                             656.1 KiB  7.91 MiB/s 00:00 [####################################################################] 100%
 kimageformats-6.28.1-1-x86_64                                                        650.8 KiB  7.94 MiB/s 00:00 [####################################################################] 100%
 kwallet-6.28.0-1-x86_64                                                              602.2 KiB  7.64 MiB/s 00:00 [####################################################################] 100%
 kcalendarcore-6.28.0-1-x86_64                                                        588.9 KiB  7.57 MiB/s 00:00 [####################################################################] 100%
 print-manager-1:6.7.3-1-x86_64                                                       583.1 KiB  7.70 MiB/s 00:00 [####################################################################] 100%
 baloo-6.28.0-1-x86_64        581.8 KiB  7.78 MiB/s 00:00 [####################################################################] 100%
 imlib2-1.12.6-2-x86_64                                                               577.8 KiB  7.73 MiB/s 00:00 [####################################################################] 100%
 taglib-2.3.1-1-x86_64        562.0 KiB  7.62 MiB/s 00:00 [####################################################################] 100%
 qqc2-desktop-style-6.28.0-1-x86_64                                                   554.2 KiB  7.52 MiB/s 00:00 [####################################################################] 100%
 srt-1.5.6-1-x86_64        546.5 KiB  7.52 MiB/s 00:00 [####################################################################] 100%
 kconfig-6.28.0-1-x86_64                                                              529.8 KiB  7.50 MiB/s 00:00 [####################################################################] 100%
 plasma-systemmonitor-6.7.3-1-x86_64                                                  528.6 KiB  7.48 MiB/s 00:00 [####################################################################] 100%
 libp11-kit-0.26.4-1-x86_64                                                           526.6 KiB  7.45 MiB/s 00:00 [####################################################################] 100%
 findutils-4.11.0-1-x86_64                                                            526.5 KiB  7.45 MiB/s 00:00 [####################################################################] 100%
 linux618-virtualbox-host-modules-7.2.14-1-x86_64                                     525.7 KiB  7.33 MiB/s 00:00 [####################################################################] 100%
 libasan-16.1.1+r346+g4e03491b401d-4-x86_64                                           521.4 KiB  7.49 MiB/s 00:00 [####################################################################] 100%
 libraw-0.22.2-1-x86_64                                                               520.3 KiB  7.47 MiB/s 00:00 [####################################################################] 100%
 libpipewire-1:1.6.8-1-x86_64                                                         509.7 KiB  7.32 MiB/s 00:00 [####################################################################] 100%
 plasma-firewall-6.7.3-1-x86_64                                                       503.9 KiB  7.24 MiB/s 00:00 [####################################################################] 100%
 plasma-pa-6.7.3-1-x86_64                                                             498.8 KiB  7.38 MiB/s 00:00 [####################################################################] 100%
 kdoctools-6.28.0-1-x86_64                                                            489.9 KiB  7.25 MiB/s 00:00 [####################################################################] 100%
 linux612-virtualbox-host-modules-7.2.14-1-x86_64                                     487.8 KiB  7.22 MiB/s 00:00 [####################################################################] 100%
 solid-6.28.0-1-x86_64        469.1 KiB  6.84 MiB/s 00:00 [####################################################################] 100%
 purpose-6.28.0-1-x86_64                                                              460.5 KiB  7.14 MiB/s 00:00 [####################################################################] 100%
 libtsan-16.1.1+r346+g4e03491b401d-4-x86_64                                           459.8 KiB  7.13 MiB/s 00:00 [####################################################################] 100%
 qqc2-breeze-style-6.7.3-1-x86_64                                                     459.3 KiB  7.12 MiB/s 00:00 [####################################################################] 100%
 qemu-tools-11.0.2-4-x86_64                                                           451.5 KiB  7.00 MiB/s 00:00 [####################################################################] 100%
 lib32-p11-kit-0.26.4-1-x86_64                                                        450.4 KiB  7.09 MiB/s 00:00 [####################################################################] 100%
 python-stone-3.5.3-1-any                                                             433.4 KiB  6.94 MiB/s 00:00 [####################################################################] 100%
 libtool-2.6.2-1-x86_64                                                               429.1 KiB  6.87 MiB/s 00:00 [####################################################################] 100%
 networkmanager-qt-6.28.0-1-x86_64                                                    425.5 KiB  6.92 MiB/s 00:00 [####################################################################] 100%
 fontconfig-2:2.18.2-1-x86_64                                                         405.3 KiB  6.82 MiB/s 00:00 [####################################################################] 100%
 onetbb-2023.1.0-1-x86_64                                                             400.4 KiB  6.74 MiB/s 00:00 [####################################################################] 100%
 sonnet-6.28.0-1-x86_64                                                               396.6 KiB  6.80 MiB/s 00:00 [####################################################################] 100%
 ca-certificates-mozilla-3.126-1-x86_64                                               382.4 KiB  6.55 MiB/s 00:00 [####################################################################] 100%
 nettle3-3.10.2-2-x86_64                                                              374.3 KiB  1503 KiB/s 00:00 [####################################################################] 100%
 systemsettings-6.7.3-1-x86_64                                                        372.3 KiB  6.61 MiB/s 00:00 [####################################################################] 100%
 poppler-glib-26.07.0-1-x86_64                                                        367.5 KiB  6.53 MiB/s 00:00 [####################################################################] 100%
 qemu-pr-helper-11.0.2-4-x86_64                                                       366.5 KiB  6.39 MiB/s 00:00 [####################################################################] 100%
 kconfigwidgets-6.28.0-1-x86_64                                                       362.4 KiB  6.43 MiB/s 00:00 [####################################################################] 100%
 perl-alien-build-2.84-5-any                                                          354.2 KiB  6.41 MiB/s 00:00 [####################################################################] 100%
 libkscreen-6.7.3-1-x86_64                                                            351.5 KiB  6.36 MiB/s 00:00 [####################################################################] 100%
 luajit-2.1.1784580905+2460b3f-1-x86_64                                               341.0 KiB  6.28 MiB/s 00:00 [####################################################################] 100%
 bluez-qt-6.28.0-1-x86_64                                                             340.2 KiB  6.27 MiB/s 00:00 [####################################################################] 100%
 kcontacts-1:6.28.0-1-x86_64                                                          336.3 KiB  6.32 MiB/s 00:00 [####################################################################] 100%
 kuserfeedback-6.28.0-1-x86_64                                                        335.9 KiB  6.31 MiB/s 00:00 [####################################################################] 100%
 ppp-2.5.3-1-x86_64        333.7 KiB  6.39 MiB/s 00:00 [####################################################################] 100%
 ktexttemplate-6.28.0-1-x86_64                                                        332.4 KiB  6.37 MiB/s 00:00 [####################################################################] 100%
 plasma-vault-6.7.3-1-x86_64                                                          327.6 KiB  6.15 MiB/s 00:00 [####################################################################] 100%
 qgpgme-2.2.0-1-x86_64        325.3 KiB  6.23 MiB/s 00:00 [####################################################################] 100%
 kcmutils-6.28.0-1-x86_64                                                             314.6 KiB  6.02 MiB/s 00:00 [####################################################################] 100%
 kholidays-1:6.28.0-1-x86_64                                                          312.9 KiB  6.11 MiB/s 00:00 [####################################################################] 100%
 lame-4.0-1-x86_64        312.2 KiB  6.10 MiB/s 00:00 [####################################################################] 100%
 oxygen5-6.7.3-1-x86_64                                                               310.5 KiB  6.06 MiB/s 00:00 [####################################################################] 100%
 ktextwidgets-6.28.0-1-x86_64                                                         309.2 KiB  6.04 MiB/s 00:00 [####################################################################] 100%
 tzdata-2026c-1-x86_64        304.9 KiB  6.08 MiB/s 00:00 [####################################################################] 100%
 ksystemstats-6.7.3-1-x86_64                                                          294.2 KiB  5.86 MiB/s 00:00 [####################################################################] 100%
 libevent-2.1.13-2-x86_64                                                             291.4 KiB  5.93 MiB/s 00:00 [####################################################################] 100%
 ntfsprogs-2026.7.7-1-x86_64                                                          291.3 KiB  5.93 MiB/s 00:00 [####################################################################] 100%
 libdovi-3.4.0-1-x86_64                                                               283.0 KiB  5.88 MiB/s 00:00 [####################################################################] 100%
 kfilemetadata-6.28.0-1-x86_64                                                        280.0 KiB  5.70 MiB/s 00:00 [####################################################################] 100%
 ruby-net-imap-0.5.15-1-any                                                           275.7 KiB  5.73 MiB/s 00:00 [####################################################################] 100%
 libhwasan-16.1.1+r346+g4e03491b401d-4-x86_64                                         275.1 KiB  5.72 MiB/s 00:00 [####################################################################] 100%
 poppler-qt6-26.07.0-1-x86_64                                                         268.2 KiB  5.57 MiB/s 00:00 [####################################################################] 100%
 kscreenlocker-6.7.3-1-x86_64                                                         263.5 KiB  5.59 MiB/s 00:00 [####################################################################] 100%
 libssh-0.12.1-1-x86_64                                                               260.3 KiB  5.53 MiB/s 00:00 [####################################################################] 100%
 libssh2-1.11.1-6-x86_64                                                              259.3 KiB  5.51 MiB/s 00:00 [####################################################################] 100%
 p11-kit-0.26.4-1-x86_64                                                              255.6 KiB  5.55 MiB/s 00:00 [####################################################################] 100%
 zbar-0.23.93-7-x86_64        254.7 KiB  5.53 MiB/s 00:00 [####################################################################] 100%
 kwindowsystem-6.28.0-1-x86_64                                                        248.1 KiB  5.38 MiB/s 00:00 [####################################################################] 100%
 kservice-6.28.0-1-x86_64                                                             245.6 KiB  5.45 MiB/s 00:00 [####################################################################] 100%
 kwayland-6.7.3-1-x86_64                                                              245.5 KiB  5.45 MiB/s 00:00 [####################################################################] 100%
 modemmanager-qt-6.28.0-1-x86_64                                                      236.5 KiB  5.37 MiB/s 00:00 [####################################################################] 100%
 libgomp-16.1.1+r346+g4e03491b401d-4-x86_64                                           230.8 KiB  5.24 MiB/s 00:00 [####################################################################] 100%
 liblsan-16.1.1+r346+g4e03491b401d-4-x86_64                                           228.3 KiB  5.19 MiB/s 00:00 [####################################################################] 100%
 socat-1.8.1.3-1-x86_64                                                               227.3 KiB  5.29 MiB/s 00:00 [####################################################################] 100%
 libntfs-3g-2026.7.7-1-x86_64                                                         226.8 KiB  4.71 MiB/s 00:00 [####################################################################] 100%
 syndication-6.28.0-1-x86_64                                                          223.5 KiB  5.20 MiB/s 00:00 [####################################################################] 100%
 krdp-6.7.3-1-x86_64        221.8 KiB  5.04 MiB/s 00:00 [####################################################################] 100%
 gst-plugins-base-1.28.5-2-x86_64                                                     217.7 KiB  5.06 MiB/s 00:00 [####################################################################] 100%
 kguiaddons-6.28.0-1-x86_64                                                           217.4 KiB  5.05 MiB/s 00:00 [####################################################################] 100%
 krunner-6.28.0-1-x86_64                                                              215.8 KiB  5.02 MiB/s 00:00 [####################################################################] 100%
 cpupower-7.1.4-1-x86_64                                                              212.4 KiB  5.06 MiB/s 00:00 [####################################################################] 100%
 flatpak-kcm-6.7.3-1-x86_64                                                           211.9 KiB  4.93 MiB/s 00:00 [####################################################################] 100%
 libubsan-16.1.1+r346+g4e03491b401d-4-x86_64                                          206.6 KiB  5.04 MiB/s 00:00 [####################################################################] 100%
 attica-6.28.0-1-x86_64                                                               200.3 KiB  4.89 MiB/s 00:00 [####################################################################] 100%
 kactivitymanagerd-6.7.3-1-x86_64                                                     197.8 KiB  4.83 MiB/s 00:00 [####################################################################] 100%
 karchive-6.28.0-1-x86_64                                                             196.4 KiB  4.92 MiB/s 00:00 [####################################################################] 100%
 breeze5-6.7.3-1-x86_64                                                               195.6 KiB  4.90 MiB/s 00:00 [####################################################################] 100%
 kpipewire-6.7.3-1-x86_64                                                             194.0 KiB  4.74 MiB/s 00:00 [####################################################################] 100%
 breeze-gtk-6.7.3-1-any                                                               192.3 KiB  4.69 MiB/s 00:00 [####################################################################] 100%
 kjobwidgets-6.28.0-1-x86_64                                                          191.5 KiB  4.80 MiB/s 00:00 [####################################################################] 100%
 kpackage-6.28.0-1-x86_64                                                             189.0 KiB  4.73 MiB/s 00:00 [####################################################################] 100%
 kquickcharts-6.28.0-1-x86_64                                                         188.5 KiB  4.72 MiB/s 00:00 [####################################################################] 100%
 kdeclarative-6.28.0-1-x86_64                                                         187.0 KiB  4.68 MiB/s 00:00 [####################################################################] 100%
 plasma-browser-integration-6.7.3-1-x86_64                                            186.7 KiB  4.56 MiB/s 00:00 [####################################################################] 100%
 kpeople-6.28.0-1-x86_64                                                              185.1 KiB  4.63 MiB/s 00:00 [####################################################################] 100%
 libwacom-2.19.1-1-x86_64                                                             184.7 KiB  4.62 MiB/s 00:00 [####################################################################] 100%
 gst-plugins-ugly-1.28.5-2-x86_64                                                     183.9 KiB  4.73 MiB/s 00:00 [####################################################################] 100%
 kparts-6.28.0-1-x86_64                                                               181.0 KiB  4.65 MiB/s 00:00 [####################################################################] 100%
 htop-3.5.2-1-x86_64        177.4 KiB  4.44 MiB/s 00:00 [####################################################################] 100%
 dvdauthor-0.7.2-15-x86_64                                                            174.9 KiB  4.49 MiB/s 00:00 [####################################################################] 100%
 kiconthemes-6.28.0-1-x86_64                                                          173.7 KiB  4.46 MiB/s 00:00 [####################################################################] 100%
 libquadmath-16.1.1+r346+g4e03491b401d-4-x86_64                                       166.4 KiB  4.39 MiB/s 00:00 [####################################################################] 100%
 kmime-1:6.28.0-1-x86_64                                                              165.6 KiB  4.25 MiB/s 00:00 [####################################################################] 100%
 knotifications-6.28.0-1-x86_64                                                       164.2 KiB  4.33 MiB/s 00:00 [####################################################################] 100%
 lib32-fontconfig-2:2.18.2-1-x86_64                                                   163.8 KiB  4.32 MiB/s 00:00 [####################################################################] 100%
 kitemmodels-6.28.0-1-x86_64                                                          161.6 KiB  4.38 MiB/s 00:00 [####################################################################] 100%
 plasma-disks-6.7.3-1-x86_64                                                          160.3 KiB  4.12 MiB/s 00:00 [####################################################################] 100%
 ksvg-6.28.0-1-x86_64        159.4 KiB  4.21 MiB/s 00:00 [####################################################################] 100%
 kcodecs-6.28.0-1-x86_64                                                              159.3 KiB  4.09 MiB/s 00:00 [####################################################################] 100%
 sddm-kcm-6.7.3-1-x86_64                                                              158.9 KiB  4.31 MiB/s 00:00 [####################################################################] 100%
 python-grpcio-tools-1.82.1-1-x86_64                                                  157.9 KiB  4.17 MiB/s 00:00 [####################################################################] 100%
 aurorae-6.7.3-1-x86_64                                                               155.5 KiB  4.10 MiB/s 00:00 [####################################################################] 100%
 kgamma-6.7.3-1-x86_64        155.2 KiB  4.21 MiB/s 00:00 [####################################################################] 100%
 kstatusnotifieritem-6.28.0-1-x86_64                                                  150.9 KiB  4.09 MiB/s 00:00 [####################################################################] 100%
 plasma-thunderbolt-6.7.3-1-x86_64                                                    143.1 KiB  3.99 MiB/s 00:00 [####################################################################] 100%
 libdvdread-7.1.1-1-x86_64                                                            141.1 KiB  4.05 MiB/s 00:00 [####################################################################] 100%
 ruby-nkf-0.3.0-1-x86_64                                                              140.9 KiB  3.93 MiB/s 00:00 [####################################################################] 100%
 kglobalacceld-6.7.3-1-x86_64                                                         132.6 KiB  3.93 MiB/s 00:00 [####################################################################] 100%
 libmatroska-1.7.2-2-x86_64                                                           132.3 KiB  3.80 MiB/s 00:00 [####################################################################] 100%
 glycin-gtk4-2.1.5-2-x86_64                                                           131.9 KiB  3.79 MiB/s 00:00 [####################################################################] 100%
 plasma-integration-6.7.3-1-x86_64                                                    131.6 KiB  3.78 MiB/s 00:00 [####################################################################] 100%
 kcompletion-6.28.0-1-x86_64                                                          130.9 KiB  3.76 MiB/s 00:00 [####################################################################] 100%
 kitemviews-6.28.0-1-x86_64                                                           130.4 KiB  3.86 MiB/s 00:00 [####################################################################] 100%
 kbookmarks-6.28.0-1-x86_64                                                           128.4 KiB  3.69 MiB/s 00:00 [####################################################################] 100%
 ruby-minitest-5.27.0-1-any                                                           128.0 KiB  3.68 MiB/s 00:00 [####################################################################] 100%
 plasma-activities-6.7.3-1-x86_64                                                     125.3 KiB  3.71 MiB/s 00:00 [####################################################################] 100%
 kauth-6.28.0-1-x86_64        121.6 KiB  3.60 MiB/s 00:00 [####################################################################] 100%
 plasma5-integration-6.7.3-1-x86_64                                                   120.4 KiB  3.46 MiB/s 00:00 [####################################################################] 100%
 lib32-libssh2-1.11.1-4-x86_64                                                        119.9 KiB  3.55 MiB/s 00:00 [####################################################################] 100%
 pkgconf-3.0.3-1-x86_64                                                               117.9 KiB  3.60 MiB/s 00:00 [####################################################################] 100%
 ruby-rake-13.4.2-1-any                                                               115.2 KiB  3.52 MiB/s 00:00 [####################################################################] 100%
 manjaro-hello-0.8.1-7-any                                                            105.7 KiB  3.33 MiB/s 00:00 [####################################################################] 100%
 networkmanager-pptp-1.2.12-8-x86_64                                                  102.6 KiB  3.23 MiB/s 00:00 [####################################################################] 100%
 gst-libav-1.28.5-2-x86_64                                                            102.2 KiB  3.22 MiB/s 00:00 [####################################################################] 100%
 milou-6.7.3-1-x86_64        101.8 KiB  3.11 MiB/s 00:00 [####################################################################] 100%
 giflib-6.1.3-2-x86_64        101.4 KiB  3.19 MiB/s 00:00 [####################################################################] 100%
 kglobalaccel-6.28.0-1-x86_64                                                         100.6 KiB  3.17 MiB/s 00:00 [####################################################################] 100%
 kdecoration-6.7.3-1-x86_64                                                            98.4 KiB  3.10 MiB/s 00:00 [####################################################################] 100%
 breeze-plymouth-6.7.3-1-x86_64                                                        93.7 KiB  2.95 MiB/s 00:00 [####################################################################] 100%
 plasma-activities-stats-6.7.3-1-x86_64                                                93.2 KiB  2.94 MiB/s 00:00 [####################################################################] 100%
 bluez-libs-5.87-2-x86_64                                                              92.8 KiB  3.02 MiB/s 00:00 [####################################################################] 100%
 lib32-libva-2.24.1-1-x86_64                                                           92.5 KiB  2.91 MiB/s 00:00 [####################################################################] 100%
 kdnssd-6.28.0-1-x86_64        92.2 KiB  2.90 MiB/s 00:00 [####################################################################] 100%
 ruby-test-unit-3.7.8-1-any                                                            90.2 KiB  2.75 MiB/s 00:00 [####################################################################] 100%
 kde-gtk-config-6.7.3-1-x86_64                                                         88.7 KiB  2.89 MiB/s 00:00 [####################################################################] 100%
 prison-6.28.0-1-x86_64        85.9 KiB  2.80 MiB/s 00:00 [####################################################################] 100%
 threadweaver-6.28.0-1-x86_64                                                          81.6 KiB  2.66 MiB/s 00:00 [####################################################################] 100%
 libgcc-16.1.1+r346+g4e03491b401d-4-x86_64                                             80.0 KiB  2.60 MiB/s 00:00 [####################################################################] 100%
 plymouth-kcm-6.7.3-1-x86_64                                                           78.6 KiB  2.65 MiB/s 00:00 [####################################################################] 100%
 frameworkintegration-6.28.0-1-x86_64                                                  77.6 KiB  2.61 MiB/s 00:00 [####################################################################] 100%
 kdesu-6.28.0-1-x86_64        76.4 KiB  2.57 MiB/s 00:00 [####################################################################] 100%
 cdparanoia-10.2-10-x86_64                                                             75.3 KiB  2.54 MiB/s 00:00 [####################################################################] 100%
 kdbusaddons-6.28.0-1-x86_64                                                           74.9 KiB  2.52 MiB/s 00:00 [####################################################################] 100%
 polkit-kde-agent-6.7.3-1-x86_64                                                       74.1 KiB  2.50 MiB/s 00:00 [####################################################################] 100%
 perl-http-message-7.03-1-any                                                          70.6 KiB  2.46 MiB/s 00:00 [####################################################################] 100%
 qt-sudo-2.4.1-1-x86_64        68.8 KiB  2.24 MiB/s 00:00 [####################################################################] 100%
 knighttime-6.7.3-1-x86_64                                                             66.1 KiB  2.31 MiB/s 00:00 [####################################################################] 100%
 knotifyconfig-6.28.0-1-x86_64                                                         64.6 KiB  2.18 MiB/s 00:00 [####################################################################] 100%
 kded-6.28.0-1-x86_64        64.0 KiB  2.23 MiB/s 00:00 [####################################################################] 100%
 ntfs-3g-2026.7.7-1-x86_64                                                             63.3 KiB  2.21 MiB/s 00:00 [####################################################################] 100%
 kidletime-6.28.0-1-x86_64                                                             62.1 KiB  2.17 MiB/s 00:00 [####################################################################] 100%
 vulkan-mesa-implicit-layers-1:26.1.5-1-x86_64                                         55.1 KiB  1966 KiB/s 00:00 [####################################################################] 100%
 kcolorscheme-6.28.0-1-x86_64                                                          54.4 KiB  1941 KiB/s 00:00 [####################################################################] 100%
 kpty-6.28.0-1-x86_64        53.7 KiB  1852 KiB/s 00:00 [####################################################################] 100%
 lib32-vulkan-mesa-implicit-layers-1:26.1.5-1-x86_64                                   53.5 KiB  1672 KiB/s 00:00 [####################################################################] 100%
 libffi-3.7.1-1-x86_64        52.8 KiB  1957 KiB/s 00:00 [####################################################################] 100%
 python-platformdirs-4.11.0-1-any                                                      49.0 KiB  1814 KiB/s 00:00 [####################################################################] 100%
 qemu-hw-display-qxl-11.0.2-4-x86_64                                                   41.8 KiB  1608 KiB/s 00:00 [####################################################################] 100%
 fdkaac-1.0.8-1-x86_64        40.8 KiB  1512 KiB/s 00:00 [####################################################################] 100%
 kwayland-integration-6.7.3-1-x86_64                                                   40.1 KiB  1543 KiB/s 00:00 [####################################################################] 100%
 layer-shell-qt-6.7.3-1-x86_64                                                         37.6 KiB  1447 KiB/s 00:00 [####################################################################] 100%
 libobjc-16.1.1+r346+g4e03491b401d-4-x86_64                                            37.5 KiB  1444 KiB/s 00:00 [####################################################################] 100%
 ksshaskpass-6.7.3-1-x86_64                                                            37.0 KiB  1425 KiB/s 00:00 [####################################################################] 100%
 qemu-hw-display-virtio-gpu-11.0.2-4-x86_64                                            37.0 KiB  1481 KiB/s 00:00 [####################################################################] 100%
 qemu-ui-spice-core-11.0.2-4-x86_64                                                    34.7 KiB  1334 KiB/s 00:00 [####################################################################] 100%
 qemu-hw-usb-redirect-11.0.2-4-x86_64                                                  34.5 KiB  1327 KiB/s 00:00 [####################################################################] 100%
 networkmanager-vpn-plugin-pptp-1.2.12-8-x86_64                                        31.7 KiB  1220 KiB/s 00:00 [####################################################################] 100%
 qemu-hw-usb-host-11.0.2-4-x86_64                                                      30.1 KiB  1159 KiB/s 00:00 [####################################################################] 100%
 kcrash-6.28.0-1-x86_64        30.0 KiB  1198 KiB/s 00:00 [####################################################################] 100%
 qemu-hw-display-virtio-gpu-gl-11.0.2-4-x86_64                                         28.5 KiB  1097 KiB/s 00:00 [####################################################################] 100%
 ruby-erb-4.0.4.1-1-x86_64                                                             27.0 KiB  1082 KiB/s 00:00 [####################################################################] 100%
 qemu-block-ssh-11.0.2-4-x86_64                                                        25.9 KiB  1036 KiB/s 00:00 [####################################################################] 100%
 qemu-system-x86-firmware-11.0.2-4-x86_64                                              25.4 KiB  1016 KiB/s 00:00 [####################################################################] 100%
 qemu-ui-opengl-11.0.2-4-x86_64                                                        25.3 KiB  1013 KiB/s 00:00 [####################################################################] 100%
 xorg-xmodmap-1.0.12-1-x86_64                                                          23.7 KiB   988 KiB/s 00:00 [####################################################################] 100%
 qemu-hw-usb-smartcard-11.0.2-4-x86_64                                                 23.6 KiB   983 KiB/s 00:00 [####################################################################] 100%
 xorg-mkfontscale-1.2.4-2-x86_64                                                       23.5 KiB   811 KiB/s 00:00 [####################################################################] 100%
 qemu-ui-curses-11.0.2-4-x86_64                                                        23.4 KiB   936 KiB/s 00:00 [####################################################################] 100%
 qemu-block-curl-11.0.2-4-x86_64                                                       23.1 KiB   926 KiB/s 00:00 [####################################################################] 100%
 qemu-block-nfs-11.0.2-4-x86_64                                                        22.5 KiB   940 KiB/s 00:00 [####################################################################] 100%
 xorg-xrdb-1.2.3-1-x86_64                                                              20.7 KiB   864 KiB/s 00:00 [####################################################################] 100%
 lib32-libffi-3.7.1-1-x86_64                                                           20.3 KiB   847 KiB/s 00:00 [####################################################################] 100%
 b43-fwcutter-020-1-x86_64                                                             19.9 KiB   829 KiB/s 00:00 [####################################################################] 100%
 xorg-xset-1.2.6-1-x86_64                                                              19.6 KiB   784 KiB/s 00:00 [####################################################################] 100%
 qemu-chardev-spice-11.0.2-4-x86_64                                                    19.0 KiB   791 KiB/s 00:00 [####################################################################] 100%
 kwrited-6.7.3-1-x86_64        18.4 KiB   768 KiB/s 00:00 [####################################################################] 100%
 qemu-hw-display-virtio-vga-11.0.2-4-x86_64                                            18.0 KiB   720 KiB/s 00:00 [####################################################################] 100%
 lib32-libltdl-2.6.2-1-x86_64                                                          17.9 KiB   714 KiB/s 00:00 [####################################################################] 100%
 qemu-audio-spice-11.0.2-4-x86_64                                                      17.8 KiB   741 KiB/s 00:00 [####################################################################] 100%
 qemu-ui-spice-app-11.0.2-4-x86_64                                                     17.7 KiB   707 KiB/s 00:00 [####################################################################] 100%
 qemu-hw-display-virtio-gpu-pci-11.0.2-4-x86_64                                        16.7 KiB   668 KiB/s 00:00 [####################################################################] 100%
 qemu-hw-s390x-virtio-gpu-ccw-11.0.2-4-x86_64                                          16.1 KiB   671 KiB/s 00:00 [####################################################################] 100%
 qemu-hw-display-virtio-vga-gl-11.0.2-4-x86_64                                         16.0 KiB   640 KiB/s 00:00 [####################################################################] 100%
 qemu-block-dmg-11.0.2-4-x86_64                                                        15.9 KiB   637 KiB/s 00:00 [####################################################################] 100%
 qemu-hw-display-virtio-gpu-pci-gl-11.0.2-4-x86_64                                     15.8 KiB   631 KiB/s 00:00 [####################################################################] 100%
 qemu-base-11.0.2-4-x86_64                                                             14.8 KiB   594 KiB/s 00:00 [####################################################################] 100%
 libatomic-16.1.1+r346+g4e03491b401d-4-x86_64                                          14.3 KiB   595 KiB/s 00:00 [####################################################################] 100%
 kwallet-pam-6.7.3-1-x86_64                                                            13.1 KiB   570 KiB/s 00:00 [####################################################################] 100%
 perl-http-date-6.08-1-any                                                             10.5 KiB   455 KiB/s 00:00 [####################################################################] 100%
 ruby-bundled-gems-3.4.10-1-x86_64                                                      5.1 KiB   220 KiB/s 00:00 [####################################################################] 100%
 ruby-default-gems-3.4.10-1-x86_64                                                      4.9 KiB   213 KiB/s 00:00 [####################################################################] 100%
 ruby-stdlib-3.4.10-1-x86_64                                                            4.9 KiB   213 KiB/s 00:00 [####################################################################] 100%
 gcc-libs-16.1.1+r346+g4e03491b401d-4-x86_64                                            2.6 KiB   115 KiB/s 00:00 [####################################################################] 100%
 Total (352/352)        1909.8 MiB  9.92 MiB/s 03:12 [####################################################################] 100%
(352/352) checking keys in keyring        [####################################################################] 100%
(352/352) checking package integrity        [####################################################################] 100%
(352/352) loading package files        [####################################################################] 100%
(352/352) checking for file conflicts        [####################################################################] 100%
error: failed to commit transaction (conflicting files)
opencv: /usr/bin/opencv_annotation exists in filesystem
opencv: /usr/bin/opencv_model_diagnostics exists in filesystem
opencv: /usr/bin/opencv_version exists in filesystem
opencv: /usr/bin/opencv_visualisation exists in filesystem
opencv: /usr/bin/opencv_waldboost_detector exists in filesystem
opencv: /usr/include/opencv5/opencv2/alphamat.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/bgsegm.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/bioinspired.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/bioinspired/bioinspired.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/bioinspired/retina.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/bioinspired/retinafasttonemapping.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/bioinspired/transientareassegmentationmodule.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/calib.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/calib3d.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/ccalib.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/ccalib/multicalib.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/ccalib/omnidir.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/ccalib/randpattern.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/affine.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/async.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/base.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/bindings_utils.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/bufferpool.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/check.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/core.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/cuda.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/cuda.inl.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/cuda/block.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/cuda/border_interpolate.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/cuda/color.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/cuda/common.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/cuda/cuda_compat.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/cuda/datamov_utils.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/cuda/detail/color_detail.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/cuda/detail/reduce.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/cuda/detail/reduce_key_val.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/cuda/detail/transform_detail.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/cuda/detail/type_traits_detail.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/cuda/detail/vec_distance_detail.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/cuda/dynamic_smem.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/cuda/emulation.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/cuda/filters.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/cuda/funcattrib.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/cuda/functional.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/cuda/limits.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/cuda/reduce.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/cuda/saturate_cast.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/cuda/scan.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/cuda/simd_functions.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/cuda/transform.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/cuda/type_traits.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/cuda/utility.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/cuda/vec_distance.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/cuda/vec_math.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/cuda/vec_traits.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/cuda/warp.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/cuda/warp_reduce.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/cuda/warp_shuffle.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/cuda_stream_accessor.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/cuda_types.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/cv_cpu_dispatch.h exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/cv_cpu_helper.h exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/cvdef.h exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/cvstd.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/cvstd.inl.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/cvstd_wrapper.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/detail/async_promise.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/detail/dispatch_helper.impl.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/detail/exception_ptr.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/directx.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/dualquaternion.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/dualquaternion.inl.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/eigen.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/exception.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/fast_math.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/fwddecl.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/hal/hal.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/hal/interface.h exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/hal/intrin.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/hal/intrin_avx.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/hal/intrin_avx512.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/hal/intrin_cpp.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/hal/intrin_forward.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/hal/intrin_lasx.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/hal/intrin_legacy_ops.h exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/hal/intrin_lsx.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/hal/intrin_math.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/hal/intrin_msa.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/hal/intrin_neon.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/hal/intrin_rvv071.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/hal/intrin_rvv_scalable.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/hal/intrin_sse.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/hal/intrin_sse_em.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/hal/intrin_vsx.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/hal/intrin_wasm.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/hal/msa_macros.h exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/hal/simd_utils.impl.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/mat.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/mat.inl.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/matx.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/matx.inl.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/neon_utils.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/ocl.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/ocl_genbase.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/opencl/ocl_defs.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/opencl/opencl_info.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/opencl/opencl_svm.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/opencl/runtime/autogenerated/opencl_clblas.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/opencl/runtime/autogenerated/opencl_clfft.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/opencl/runtime/autogenerated/opencl_core.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/opencl/runtime/autogenerated/opencl_core_wrappers.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/opencl/runtime/autogenerated/opencl_gl.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/opencl/runtime/autogenerated/opencl_gl_wrappers.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/opencl/runtime/opencl_clblas.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/opencl/runtime/opencl_clfft.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/opencl/runtime/opencl_core.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/opencl/runtime/opencl_core_wrappers.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/opencl/runtime/opencl_gl.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/opencl/runtime/opencl_gl_wrappers.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/opencl/runtime/opencl_svm_20.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/opencl/runtime/opencl_svm_definitions.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/opencl/runtime/opencl_svm_hsa_extension.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/opengl.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/operations.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/optim.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/parallel/backend/parallel_for.openmp.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/parallel/backend/parallel_for.tbb.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/parallel/parallel_backend.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/persistence.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/quaternion.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/quaternion.inl.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/saturate.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/simd_intrinsics.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/softfloat.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/traits.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/types.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/utility.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/utils/allocator_stats.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/utils/allocator_stats.impl.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/utils/filesystem.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/utils/fp_control_utils.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/utils/instrumentation.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/utils/logger.defines.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/utils/logger.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/utils/logtag.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/utils/tls.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/utils/trace.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/va_intel.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/version.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core/vsx_utils.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/core_detect.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/cvconfig.h exists in filesystem
opencv: /usr/include/opencv5/opencv2/cvv.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/cvv/call_meta_data.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/cvv/cvv.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/cvv/debug_mode.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/cvv/dmatch.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/cvv/filter.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/cvv/final_show.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/cvv/show_image.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/datasets/ar_hmdb.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/datasets/ar_sports.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/datasets/dataset.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/datasets/fr_adience.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/datasets/fr_lfw.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/datasets/gr_chalearn.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/datasets/gr_skig.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/datasets/hpe_humaneva.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/datasets/hpe_parse.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/datasets/ir_affine.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/datasets/ir_robot.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/datasets/is_bsds.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/datasets/is_weizmann.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/datasets/msm_epfl.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/datasets/msm_middlebury.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/datasets/or_imagenet.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/datasets/or_mnist.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/datasets/or_pascal.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/datasets/or_sun.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/datasets/pd_caltech.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/datasets/pd_inria.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/datasets/slam_kitti.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/datasets/slam_tumindoor.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/datasets/sr_bsds.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/datasets/sr_div2k.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/datasets/sr_general100.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/datasets/tr_chars.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/datasets/tr_icdar.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/datasets/tr_svt.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/datasets/track_alov.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/datasets/track_vot.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/datasets/util.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/dnn.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/dnn/all_layers.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/dnn/dict.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/dnn/dnn.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/dnn/dnn.inl.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/dnn/layer.details.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/dnn/layer.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/dnn/shape_utils.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/dnn/utils/debug_utils.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/dnn/utils/inference_engine.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/dnn/version.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/dnn_superres.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/dpm.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/face.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/face/bif.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/face/face_alignment.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/face/facemark.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/face/facemarkAAM.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/face/facemarkLBF.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/face/facemark_train.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/face/facerec.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/face/mace.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/face/predict_collector.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/features.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/features/features.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/features/hal/interface.h exists in filesystem
opencv: /usr/include/opencv5/opencv2/features2d.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/flann.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/flann/all_indices.h exists in filesystem
opencv: /usr/include/opencv5/opencv2/flann/allocator.h exists in filesystem
opencv: /usr/include/opencv5/opencv2/flann/any.h exists in filesystem
opencv: /usr/include/opencv5/opencv2/flann/autotuned_index.h exists in filesystem
opencv: /usr/include/opencv5/opencv2/flann/composite_index.h exists in filesystem
opencv: /usr/include/opencv5/opencv2/flann/config.h exists in filesystem
opencv: /usr/include/opencv5/opencv2/flann/defines.h exists in filesystem
opencv: /usr/include/opencv5/opencv2/flann/dist.h exists in filesystem
opencv: /usr/include/opencv5/opencv2/flann/dummy.h exists in filesystem
opencv: /usr/include/opencv5/opencv2/flann/dynamic_bitset.h exists in filesystem
opencv: /usr/include/opencv5/opencv2/flann/flann.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/flann/flann_base.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/flann/general.h exists in filesystem
opencv: /usr/include/opencv5/opencv2/flann/ground_truth.h exists in filesystem
opencv: /usr/include/opencv5/opencv2/flann/heap.h exists in filesystem
opencv: /usr/include/opencv5/opencv2/flann/hierarchical_clustering_index.h exists in filesystem
opencv: /usr/include/opencv5/opencv2/flann/index_testing.h exists in filesystem
opencv: /usr/include/opencv5/opencv2/flann/kdtree_index.h exists in filesystem
opencv: /usr/include/opencv5/opencv2/flann/kdtree_single_index.h exists in filesystem
opencv: /usr/include/opencv5/opencv2/flann/kmeans_index.h exists in filesystem
opencv: /usr/include/opencv5/opencv2/flann/linear_index.h exists in filesystem
opencv: /usr/include/opencv5/opencv2/flann/logger.h exists in filesystem
opencv: /usr/include/opencv5/opencv2/flann/lsh_index.h exists in filesystem
opencv: /usr/include/opencv5/opencv2/flann/lsh_table.h exists in filesystem
opencv: /usr/include/opencv5/opencv2/flann/matrix.h exists in filesystem
opencv: /usr/include/opencv5/opencv2/flann/miniflann.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/flann/nn_index.h exists in filesystem
opencv: /usr/include/opencv5/opencv2/flann/object_factory.h exists in filesystem
opencv: /usr/include/opencv5/opencv2/flann/params.h exists in filesystem
opencv: /usr/include/opencv5/opencv2/flann/random.h exists in filesystem
opencv: /usr/include/opencv5/opencv2/flann/result_set.h exists in filesystem
opencv: /usr/include/opencv5/opencv2/flann/sampling.h exists in filesystem
opencv: /usr/include/opencv5/opencv2/flann/saving.h exists in filesystem
opencv: /usr/include/opencv5/opencv2/flann/simplex_downhill.h exists in filesystem
opencv: /usr/include/opencv5/opencv2/flann/timer.h exists in filesystem
opencv: /usr/include/opencv5/opencv2/freetype.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/fuzzy.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/fuzzy/fuzzy_F0_math.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/fuzzy/fuzzy_F1_math.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/fuzzy/fuzzy_image.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/fuzzy/types.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/gapi.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/gapi/core.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/gapi/cpu/core.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/gapi/cpu/gcpukernel.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/gapi/cpu/imgproc.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/gapi/cpu/ot.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/gapi/cpu/stereo.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/gapi/cpu/video.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/gapi/fluid/core.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/gapi/fluid/gfluidbuffer.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/gapi/fluid/gfluidkernel.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/gapi/fluid/imgproc.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/gapi/garg.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/gapi/garray.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/gapi/gasync_context.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/gapi/gcall.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/gapi/gcommon.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/gapi/gcompiled.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/gapi/gcompiled_async.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/gapi/gcompoundkernel.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/gapi/gcomputation.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/gapi/gcomputation_async.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/gapi/gframe.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/gapi/gkernel.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/gapi/gmat.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/gapi/gmetaarg.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/gapi/gopaque.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/gapi/gproto.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/gapi/gpu/core.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/gapi/gpu/ggpukernel.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/gapi/gpu/imgproc.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/gapi/gscalar.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/gapi/gstreaming.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/gapi/gtransform.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/gapi/gtype_traits.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/gapi/gtyped.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/gapi/imgproc.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/gapi/infer.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/gapi/infer/bindings_ie.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/gapi/infer/bindings_onnx.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/gapi/infer/bindings_ov.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/gapi/infer/ie.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/gapi/infer/onnx.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/gapi/infer/ov.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/gapi/infer/parsers.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/gapi/infer/workload_type.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/gapi/media.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/gapi/oak/infer.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/gapi/oak/oak.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/gapi/ocl/core.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/gapi/ocl/goclkernel.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/gapi/ocl/imgproc.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/gapi/opencv_includes.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/gapi/operators.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/gapi/ot.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/gapi/own/assert.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/gapi/own/convert.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/gapi/own/cvdefs.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/gapi/own/exports.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/gapi/own/mat.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/gapi/own/saturate.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/gapi/own/scalar.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/gapi/own/types.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/gapi/plaidml/core.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/gapi/plaidml/gplaidmlkernel.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/gapi/plaidml/plaidml.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/gapi/pysrc/python_stream_source.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/gapi/python/python.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/gapi/render.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/gapi/render/render.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/gapi/render/render_types.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/gapi/rmat.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/gapi/s11n.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/gapi/s11n/base.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/gapi/stereo.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/gapi/streaming/cap.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/gapi/streaming/desync.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/gapi/streaming/format.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/gapi/streaming/gstreamer/gstreamerpipeline.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/gapi/streaming/gstreamer/gstreamersource.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/gapi/streaming/meta.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/gapi/streaming/onevpl/accel_types.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/gapi/streaming/onevpl/cfg_params.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/gapi/streaming/onevpl/data_provider_interface.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/gapi/streaming/onevpl/default.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/gapi/streaming/onevpl/device_selector_interface.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/gapi/streaming/onevpl/source.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/gapi/streaming/queue_source.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/gapi/streaming/source.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/gapi/streaming/sync.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/gapi/util/any.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/gapi/util/compiler_hints.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/gapi/util/copy_through_move.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/gapi/util/optional.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/gapi/util/throw.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/gapi/util/type_traits.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/gapi/util/util.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/gapi/util/variant.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/gapi/video.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/geometry.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/geometry/2d.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/geometry/3d.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/geometry/detail/gcgraph.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/geometry/detail/optimizer.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/geometry/mst.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/geometry/segment.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/hdf.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/hdf/hdf5.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/hfs.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/highgui.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/highgui/highgui.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/highgui/highgui_winrt.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/img_hash.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/img_hash/average_hash.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/img_hash/block_mean_hash.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/img_hash/color_moment_hash.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/img_hash/img_hash_base.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/img_hash/marr_hildreth_hash.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/img_hash/phash.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/img_hash/radial_variance_hash.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/imgcodecs.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/imgcodecs/imgcodecs.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/imgcodecs/ios.h exists in filesystem
opencv: /usr/include/opencv5/opencv2/imgcodecs/macosx.h exists in filesystem
opencv: /usr/include/opencv5/opencv2/imgproc.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/imgproc/bindings.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/imgproc/hal/hal.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/imgproc/hal/interface.h exists in filesystem
opencv: /usr/include/opencv5/opencv2/imgproc/imgproc.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/intensity_transform.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/line_descriptor.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/line_descriptor/descriptor.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/ml.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/ml/ml.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/ml/ml.inl.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/objdetect.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/objdetect/aruco_board.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/objdetect/aruco_detector.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/objdetect/aruco_dictionary.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/objdetect/barcode.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/objdetect/charuco_detector.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/objdetect/face.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/objdetect/graphical_code_detector.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/objdetect/mcc_checker_detector.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/objdetect/objdetect.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/opencv.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/opencv_modules.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/optflow.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/optflow/motempl.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/optflow/pcaflow.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/optflow/rlofflow.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/optflow/sparse_matching_gpc.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/phase_unwrapping.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/phase_unwrapping/histogramphaseunwrapping.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/phase_unwrapping/phase_unwrapping.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/photo.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/photo/ccm.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/photo/cuda.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/photo/legacy/constants_c.h exists in filesystem
opencv: /usr/include/opencv5/opencv2/photo/photo.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/photo/segmentation.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/plot.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/ptcloud.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/ptcloud/depth.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/ptcloud/detail/kinfu_frame.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/ptcloud/detail/pose_graph.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/ptcloud/detail/submap.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/ptcloud/odometry.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/ptcloud/odometry_frame.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/ptcloud/odometry_settings.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/ptcloud/volume.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/ptcloud/volume_settings.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/quality.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/quality/quality_utils.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/quality/qualitybase.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/quality/qualitybrisque.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/quality/qualitygmsd.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/quality/qualitymse.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/quality/qualitypsnr.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/quality/qualityssim.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/rapid.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/reg/map.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/reg/mapaffine.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/reg/mapper.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/reg/mappergradaffine.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/reg/mappergradeuclid.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/reg/mappergradproj.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/reg/mappergradshift.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/reg/mappergradsimilar.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/reg/mapperpyramid.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/reg/mapprojec.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/reg/mapshift.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/rgbd.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/rgbd/colored_kinfu.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/rgbd/dynafu.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/rgbd/kinfu.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/rgbd/large_kinfu.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/rgbd/linemod.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/saliency.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/saliency/saliencyBaseClasses.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/saliency/saliencySpecializedClasses.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/shape.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/shape/emdL1.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/shape/hist_cost.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/shape/shape.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/shape/shape_distance.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/shape/shape_transformer.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/signal.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/signal/signal_resample.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/stereo.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/stitching.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/stitching/detail/autocalib.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/stitching/detail/blenders.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/stitching/detail/camera.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/stitching/detail/exposure_compensate.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/stitching/detail/matchers.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/stitching/detail/motion_estimators.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/stitching/detail/seam_finders.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/stitching/detail/timelapsers.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/stitching/detail/util.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/stitching/detail/util_inl.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/stitching/detail/warpers.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/stitching/detail/warpers_inl.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/stitching/warpers.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/structured_light.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/structured_light/graycodepattern.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/structured_light/sinusoidalpattern.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/structured_light/structured_light.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/superres.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/superres/optical_flow.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/surface_matching.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/surface_matching/icp.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/surface_matching/pose_3d.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/surface_matching/ppf_helpers.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/surface_matching/ppf_match_3d.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/surface_matching/t_hash_int.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/text.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/text/erfilter.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/text/ocr.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/text/swt_text_detection.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/text/textDetector.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/tracking.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/tracking/feature.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/tracking/kalman_filters.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/tracking/onlineBoosting.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/tracking/tldDataset.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/tracking/tracking.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/tracking/tracking_by_matching.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/tracking/tracking_internals.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/tracking/tracking_legacy.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/tracking/twist.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/video.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/video/background_segm.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/video/detail/tracking.detail.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/video/legacy/constants_c.h exists in filesystem
opencv: /usr/include/opencv5/opencv2/video/tracking.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/video/video.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/videoio.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/videoio/registry.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/videoio/videoio.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/videostab.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/videostab/deblurring.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/videostab/fast_marching.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/videostab/fast_marching_inl.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/videostab/frame_source.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/videostab/global_motion.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/videostab/inpainting.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/videostab/log.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/videostab/motion_core.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/videostab/motion_stabilizing.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/videostab/optical_flow.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/videostab/outlier_rejection.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/videostab/ring_buffer.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/videostab/stabilizer.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/videostab/wobble_suppression.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/viz.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/viz/types.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/viz/viz3d.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/viz/vizcore.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/viz/widget_accessor.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/viz/widgets.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/wechat_qrcode.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/xfeatures2d.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/xfeatures2d/cuda.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/xfeatures2d/nonfree.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/ximgproc.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/ximgproc/brightedges.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/ximgproc/color_match.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/ximgproc/deriche_filter.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/ximgproc/disparity_filter.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/ximgproc/edge_drawing.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/ximgproc/edge_filter.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/ximgproc/edgeboxes.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/ximgproc/edgepreserving_filter.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/ximgproc/estimated_covariance.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/ximgproc/fast_hough_transform.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/ximgproc/fast_line_detector.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/ximgproc/find_ellipses.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/ximgproc/fourier_descriptors.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/ximgproc/lsc.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/ximgproc/paillou_filter.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/ximgproc/peilin.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/ximgproc/radon_transform.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/ximgproc/ridgefilter.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/ximgproc/run_length_morphology.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/ximgproc/scansegment.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/ximgproc/seeds.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/ximgproc/segmentation.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/ximgproc/slic.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/ximgproc/sparse_match_interpolator.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/ximgproc/structured_edge_detection.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/ximgproc/weighted_median_filter.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/xobjdetect.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/xobjdetect/detection_based_tracker.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/xphoto.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/xphoto/bm3d_image_denoising.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/xphoto/dct_image_denoising.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/xphoto/inpainting.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/xphoto/oilpainting.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/xphoto/tonemap.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/xphoto/white_balance.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/xstereo.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/xstereo/descriptor.hpp exists in filesystem
opencv: /usr/include/opencv5/opencv2/xstereo/quasi_dense_stereo.hpp exists in filesystem
opencv: /usr/lib/cmake/opencv5/OpenCVConfig-version.cmake exists in filesystem
opencv: /usr/lib/cmake/opencv5/OpenCVConfig.cmake exists in filesystem
opencv: /usr/lib/cmake/opencv5/OpenCVModules-release.cmake exists in filesystem
opencv: /usr/lib/cmake/opencv5/OpenCVModules.cmake exists in filesystem
opencv: /usr/lib/libopencv_alphamat.so exists in filesystem
opencv: /usr/lib/libopencv_alphamat.so.5.0.0 exists in filesystem
opencv: /usr/lib/libopencv_alphamat.so.500 exists in filesystem
opencv: /usr/lib/libopencv_bgsegm.so exists in filesystem
opencv: /usr/lib/libopencv_bgsegm.so.5.0.0 exists in filesystem
opencv: /usr/lib/libopencv_bgsegm.so.500 exists in filesystem
opencv: /usr/lib/libopencv_bioinspired.so exists in filesystem
opencv: /usr/lib/libopencv_bioinspired.so.5.0.0 exists in filesystem
opencv: /usr/lib/libopencv_bioinspired.so.500 exists in filesystem
opencv: /usr/lib/libopencv_calib.so exists in filesystem
opencv: /usr/lib/libopencv_calib.so.5.0.0 exists in filesystem
opencv: /usr/lib/libopencv_calib.so.500 exists in filesystem
opencv: /usr/lib/libopencv_ccalib.so exists in filesystem
opencv: /usr/lib/libopencv_ccalib.so.5.0.0 exists in filesystem
opencv: /usr/lib/libopencv_ccalib.so.500 exists in filesystem
opencv: /usr/lib/libopencv_core.so exists in filesystem
opencv: /usr/lib/libopencv_core.so.5.0.0 exists in filesystem
opencv: /usr/lib/libopencv_core.so.500 exists in filesystem
opencv: /usr/lib/libopencv_cvv.so exists in filesystem
opencv: /usr/lib/libopencv_cvv.so.5.0.0 exists in filesystem
opencv: /usr/lib/libopencv_cvv.so.500 exists in filesystem
opencv: /usr/lib/libopencv_datasets.so exists in filesystem
opencv: /usr/lib/libopencv_datasets.so.5.0.0 exists in filesystem
opencv: /usr/lib/libopencv_datasets.so.500 exists in filesystem
opencv: /usr/lib/libopencv_dnn.so exists in filesystem
opencv: /usr/lib/libopencv_dnn.so.5.0.0 exists in filesystem
opencv: /usr/lib/libopencv_dnn.so.500 exists in filesystem
opencv: /usr/lib/libopencv_dnn_objdetect.so exists in filesystem
opencv: /usr/lib/libopencv_dnn_objdetect.so.5.0.0 exists in filesystem
opencv: /usr/lib/libopencv_dnn_objdetect.so.500 exists in filesystem
opencv: /usr/lib/libopencv_dnn_superres.so exists in filesystem
opencv: /usr/lib/libopencv_dnn_superres.so.5.0.0 exists in filesystem
opencv: /usr/lib/libopencv_dnn_superres.so.500 exists in filesystem
opencv: /usr/lib/libopencv_dpm.so exists in filesystem
opencv: /usr/lib/libopencv_dpm.so.5.0.0 exists in filesystem
opencv: /usr/lib/libopencv_dpm.so.500 exists in filesystem
opencv: /usr/lib/libopencv_face.so exists in filesystem
opencv: /usr/lib/libopencv_face.so.5.0.0 exists in filesystem
opencv: /usr/lib/libopencv_face.so.500 exists in filesystem
opencv: /usr/lib/libopencv_features.so exists in filesystem
opencv: /usr/lib/libopencv_features.so.5.0.0 exists in filesystem
opencv: /usr/lib/libopencv_features.so.500 exists in filesystem
opencv: /usr/lib/libopencv_flann.so exists in filesystem
opencv: /usr/lib/libopencv_flann.so.5.0.0 exists in filesystem
opencv: /usr/lib/libopencv_flann.so.500 exists in filesystem
opencv: /usr/lib/libopencv_freetype.so exists in filesystem
opencv: /usr/lib/libopencv_freetype.so.5.0.0 exists in filesystem
opencv: /usr/lib/libopencv_freetype.so.500 exists in filesystem
opencv: /usr/lib/libopencv_fuzzy.so exists in filesystem
opencv: /usr/lib/libopencv_fuzzy.so.5.0.0 exists in filesystem
opencv: /usr/lib/libopencv_fuzzy.so.500 exists in filesystem
opencv: /usr/lib/libopencv_gapi.so exists in filesystem
opencv: /usr/lib/libopencv_gapi.so.5.0.0 exists in filesystem
opencv: /usr/lib/libopencv_gapi.so.500 exists in filesystem
opencv: /usr/lib/libopencv_geometry.so exists in filesystem
opencv: /usr/lib/libopencv_geometry.so.5.0.0 exists in filesystem
opencv: /usr/lib/libopencv_geometry.so.500 exists in filesystem
opencv: /usr/lib/libopencv_hdf.so exists in filesystem
opencv: /usr/lib/libopencv_hdf.so.5.0.0 exists in filesystem
opencv: /usr/lib/libopencv_hdf.so.500 exists in filesystem
opencv: /usr/lib/libopencv_hfs.so exists in filesystem
opencv: /usr/lib/libopencv_hfs.so.5.0.0 exists in filesystem
opencv: /usr/lib/libopencv_hfs.so.500 exists in filesystem
opencv: /usr/lib/libopencv_highgui.so exists in filesystem
opencv: /usr/lib/libopencv_highgui.so.5.0.0 exists in filesystem
opencv: /usr/lib/libopencv_highgui.so.500 exists in filesystem
opencv: /usr/lib/libopencv_img_hash.so exists in filesystem
opencv: /usr/lib/libopencv_img_hash.so.5.0.0 exists in filesystem
opencv: /usr/lib/libopencv_img_hash.so.500 exists in filesystem
opencv: /usr/lib/libopencv_imgcodecs.so exists in filesystem
opencv: /usr/lib/libopencv_imgcodecs.so.5.0.0 exists in filesystem
opencv: /usr/lib/libopencv_imgcodecs.so.500 exists in filesystem
opencv: /usr/lib/libopencv_imgproc.so exists in filesystem
opencv: /usr/lib/libopencv_imgproc.so.5.0.0 exists in filesystem
rsv2@reid-galagopro:~$
Use the --overwrite="/*" option.
Teo: it just error’d out… I didn’t interrupt anything… but I did follow that fix instruction because it hosed up my GRUB…I fixed that NP, but other stuff keeps popping up.
so… it would be this:
sudo pacman -Syu --overwrite=“/*”
If there are no intervening replies, please edit your previous post instead to add further information. Cheers!
:wink:
Yes, trying to remove opencv probably won’t work because of its dependencies. So let pacman overwrite the conflicts - there might be further issues caused by the broken update.
OK… that completed. no errors that I see.
I did an pamac update and it totally rebuilt nomacs, which is a image viewer (I think) and that completed, also. I will reboot and see what happens.
OK… it’s back… no griping that I see. no errors. System looks happy to me. Should I mark this as solved, or let it stay open for a day or two? Your call.
