Hello, I’m running Manjaro KDE Ruah 21.3.7 on an HP G71 and an HP EliteDesk 800 G3. We’ve had the G71 on Linux for over a year and it has worked great. Added the G3 yesterday and the display quality is not as good as the G71. I’m referring to just normal work-related screens like Dolphin, haven’t tried to play a video and don’t play games. The colors are a bit off and the brightness is lower. It’s not terrible but it doesn’t look right; sort of like a white cover with opacity of 5%.
The comparison is on the same screen hooked up to each machine separately. The G71 has an Intel Moblile 4 Series Chipset Integrated Graphics Controller and the G3 has an Intel Graphics 630. The drivers listed as available are below.
I’ve tried to read about this stuff and one source stated that some kernels don’t support the dirvers and suggested moving “down” one in the list. The G71 is using 5.10.136.10 and the G3 5.15.60-1. Does this mean anything reagrading display quality? I’m not trying to get the G3 to look better but only the same as the G71.
Also ran:
mhwd-gpu --status
:: status
warning: could not find '/etc/X11/xorg.conf.d/90-mhwd.conf'!
inxi -G
Device-1: Intel HD Graphics 630 driver: i915 v: kernel
Display: x11 server: X.Org v: 21.1.4 driver: X: loaded: modesetting
gpu: i915 resolution: 1920x1080~60Hz
OpenGL: renderer: Mesa Intel HD Graphics 630 (KBL GT2) v: 4.6 Mesa 22.1.6
glxinfo | grep OpenGL
OpenGL vendor string: Intel
OpenGL renderer string: Mesa Intel(R) HD Graphics 630 (KBL GT2)
OpenGL core profile version string: 4.6 (Core Profile) Mesa 22.1.6
OpenGL core profile shading language version string: 4.60
OpenGL core profile profile mask: core profile
OpenGL core profile extensions:
OpenGL version string: 4.6 (Compatibility Profile) Mesa 22.1.6
OpenGL shading language version string: 4.60
OpenGL context flags: (none)
OpenGL profile mask: compatibility profile
OpenGL extensions:
OpenGL ES profile version string: OpenGL ES 3.2 Mesa 22.1.6
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.20
OpenGL ES profile extensions:
I tried selecting proprietary drivers (because installed it more than once) and it still reads that open source drivers were installed.
I should add that the G3 machine came with Windows 10 and the screen brightness and colors looked about the same as the G71 but, of course, I couldn’t compare the same software screens.
Thank you for any guidance you may be able to provide.
mhwd -l -d ✔
> PCI Device: /devices/pci0000:00/0000:00:02.0 (0300:8086:5912)
Display controller Intel Corporation HD Graphics 630
> INSTALLED:
ATTACHED: PCI
VERSION: 2018.05.04
INFO: Standard open source drivers.
PRIORITY: 2
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
CLASSIDS: 0300 0380 0302
VENDORIDS: 1002 8086 10de
> AVAILABLE:
ATTACHED: PCI
VERSION: 2018.05.04
PRIORITY: 2
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
ATTACHED: PCI
VERSION: 2020.01.13
INFO: X.org modesetting video driver.
PRIORITY: 1
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
CLASSIDS: 0300
VENDORIDS: *
ATTACHED: PCI
VERSION: 2017.03.12
INFO: X.org vesa video driver.
PRIORITY: 0
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
CLASSIDS: 0300
VENDORIDS: *
Warning: no configs for USB devices found!
