hey im no good at manjaro troubleshooting but i can ask things. i have a script im trying to run im told works fine on debian but i get an error when i try to run the script. ill post it below.
[dad@dad ~]$ /home/dad/Documents/PRUSA/Firmwa
re-pt100/Prusa-Firmware-3.9.3/PF-build.sh
Linux 64-bit found
Script path : /home/dad/Documents/PRUSA/Firmw
are-pt100/Prusa-Firmware-3.9.3
OS :
OS type : linux
Ardunio IDE : 1.8.5
Build env : 1.0.6
Board : prusa_einsy_rambo
Package name: PrusaResearch
Board v. : 1.0.3
Specific Lib: PrusaLibrary
Unzipping Prusa Firmware build environment…
/home/dad/Documents/PRUSA/Firmware-pt100/Prus
a-Firmware-3.9.3/PF-build.sh: line 389: unzip
: command not found
sudo /home/dad/Documents/PRUSA/F
irmware-pt100/Prusa-Firmware-3.9.3/PF-build.s
h
Linux 64-bit found
a-Firmware-3.9.3/PF-build.sh: line 205: type:
python: not found
Missing 'python' which is important to run th
is script
As Python 2.x will not be maintained from 202
0 please,
install it with the command 'sudo apt-get ins
tall python3'.
Check which version of Python3 has been insta
lled using 'ls /usr/bin/python3*'
Use 'sudo ln -sf /usr/bin/python3.x /usr/bin/
python' (where 'x' is your version number) to
make it default.
ok i realised you used pamac and not pacman so is that the standard for manjaro?
i got the python error to work and ran the script. now i have this error is this at all related to this topic or should i search around?
h
Linux 64-bit found
OS :
OS type : linux
Ardunio IDE : 1.8.5
Build env : 1.0.6
Board v. : 1.0.3
Unzipping Prusa Firmware build environment...
Archive: PF-build-env-WinLin-1.0.6.zip
inflating: ../PF-build-env-1.0.6/1.8.5-1.0.
3-linux-64/hardware/tools/avr/avr/lib/ldscrip
ts/avr6.xn
1) Firmware/variants/1_75mm_MK25S-RAMBo13a-E
3Dv6full.h
2) Firmware/variants/1_75mm_MK3-EINSy10a-E3D
v6full.h
3) Firmware/variants/1_75mm_MK2-RAMBo10a-E3D
v6full.h
4) Firmware/variants/1_75mm_MK2-RAMBo13a-E3D
v6full.h
5) Firmware/variants/1_75mm_MK25-RAMBo10a-E3
Dv6full.h
6) Firmware/variants/1_75mm_MK25S-RAMBo10a-E
3Dv6full.h
7) Firmware/variants/1_75mm_MK25-RAMBo13a-E3
Dv6full.h
8) Firmware/variants/1_75mm_MK3S-EINSy10a-E3
Dv6full.h
9) All
10) Quit
Select a variant: 8
Which lang-build do you want?
1) Multi languages
2) English only
Select a language: 1
a-Firmware-3.9.3/PF-build.sh: line 510: cd: .
./PF-build-env-1.0.6/1.8.5-1.0.3-linux-64: No
such file or directory
Pamac is Manjaro’s package manager. You can use it or Pacman, that’s up to you. Pamac can be easier to learn as the syntax is similar to Debian’s apt.
I renamed the topic title, so yes it’s related. However, since you apparently have your dependencies in order, maybe you should create an issue upstream. They’re familiar with it, we’re not.
ok thanks for that. this whole thing is to create a prusa .hex file that allows for the user to have the pt100 thermistor upgrade. you are supposed to follow the github instructions (which are not clear to me) listed above.
