Trouble Resizing Window
Hey!
I recently reinstalled Manjaro on my computer, and everything is going well, except for one detail. I’m having difficulty finding the option that allows me to easily resize windows when they are positioned side by side. I’ve explored the settings in an attempt to activate this feature (Window Adjustment/Alignment), but so far, I haven’t been successful.
inxi --admin --verbosity=1 --filter --no-host --width
  Kernel: 6.6.19-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    root=UUID=854f393d-39bd-4dd7-a203-eff9966d1263 rw quiet splash
    resume=UUID=295867fc-ab6f-4dac-abf9-c21d43aeda7b
  Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.12 info: frameworks
    v: 5.115.0 wm: kwin_wayland vt: 1 dm: SDDM Distro: Manjaro base: Arch Linux
  Info: quad core Intel Core i5-9300H [MT MCP] arch: Coffee Lake speed (MHz):
    avg: 1625 min/max: 800/4100
  Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630]
    vendor: Acer Incorporated ALI driver: i915 v: kernel arch: Gen-9.5
    process: Intel 14nm built: 2016-20 ports: active: eDP-1 empty: none
    bus-ID: 00:02.0 chip-ID: 8086:3e9b class-ID: 0300
  Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q]
    vendor: Acer Incorporated ALI driver: nvidia v: 550.54.14
    alternate: nouveau,nvidia_drm non-free: 545.xx+ status: current (as of
    2024-02; EOL~2026-12-xx) arch: Turing code: TUxxx process: TSMC 12nm FF
    built: 2018-2022 pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3
    speed: 8 GT/s ports: active: none off: HDMI-A-1 empty: none bus-ID: 01:00.0
    chip-ID: 10de:1f91 class-ID: 0300
  Device-3: Chicony HD User Facing driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:3 chip-ID: 04f2:b64f
  Display: wayland server: X.org v: 1.21.1.11 with: Xwayland v: 23.2.4
    compositor: kwin_wayland driver: X: loaded: modesetting,nvidia dri: iris
    gpu: i915,nvidia resolution: 1: 1440x900 2: 1829x1029
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 24.0.2-manjaro1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics 630 (CFL GT2)
    device-ID: 8086:3e9b memory: 15.1 GiB unified: yes display-ID: :1.0
  Local Storage: total: 1.83 TiB used: 64.4 GiB (3.4%)
  Memory: total: 16 GiB available: 15.46 GiB used: 4.98 GiB (32.2%)
  Processes: 257 Power: uptime: 8m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 6.17 GiB services: org_kde_powerdevil,
    tool: systemctl
  Packages: 1269 pm: pacman pkgs: 1258 libs: 369 tools: pamac pm: flatpak
    pkgs: 11 Compilers: clang: 16.0.6 gcc: 13.2.1 Shell: Zsh v: 5.9
    running-in: konsole inxi: 3.3.33
You can set up a shortcut key for that in System Settings → Workspace → Shortcuts → Kwin.
