I am having trouble logging in to my desktop. When I type in my password it goes to the black screen and says:
/dev/sda1: clean , 330744/61054976 files 687396/244189752 blocks
I am able to login into TTY and key in my user and password. I had a go with
sudo pacman -Syu`
the system says
error: failed retrieving file ‘core.db’ from a long list of mirrors host.
All I did before this happens was trying to rename my hostname, username, and disabling the KDE wallet from popping whenever I login.
I will appreciate if someone in this community can guide me through this problem without reinstalling the system.
