I have installed Virtualbox and originally had issue with using the wrong host file which showed errors during startup. I fixed the host file and now can run virtualbox now I get this error message when I try to launch the VM:
The virtual machine ‘Virtual Window’ has terminated unexpectedly with exit code 1 (0x1).
Result Code: | NS_ERROR_FAILURE (0x80004005) |
Component: | MachineWrap |
Interface: | IMachine {5047460a-265d-4538-b23e-ddba5fb84976} |
