Trojita doesn't save imap and smtp ports
Hello dears
I've installed the email client Trojitá and tried to configure imap port but when I just changed and checked the inbox, it comes back again and returns to the port 143.
Any idea about why it does that?
I've installed it throug pamac
bad sudo installation?
Well thanks for reading
Verify that your config files are owned by your user:group
ls -la ~/.config/flaska.net
Thank you !!
