In Tweaks, I toggle it to Area, it works, and back to Fingers, and it won’t register the triple/middle click. It appears to be system-wide, but I’ve only tried a few apps, and pasting in terminal and opening new link in FF don’t work. Toggle to Area, and these middle-click behaviors work. Toggle back to Fingers, and they fails again.
Welcome to Manjaro!
Please read this:
and post some more information so we can see what’s really going on. Now we know the symptom of the disease, but we need some more probing to know where the origin lies…
An inxi --admin --verbosity=7 --filter --no-host
would be the minimum required information… (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
P.S. If you enter a bit more details in your profile, we can also see which Desktop Environment you’re using, which CPU/GPU you have, …
You know what DE I’m using if you read my post. The CPU/GPU are irrelevant.
I have no idea why/how this works, but regressing kernel to 4.9 re-enables triple click for middle click.
Problem still exists and I confirm that using 4.9 fixes the issue.
I also realized that touchpad settings have no effect (I’m using KDE)
