Hello Manjaro community,
I’m experiencing an issue with my laptop’s keyboard backlight, specifically after opening the lid following a sleep cycle. The problem is that the keyboard backlight flashes briefly and then turns off, despite having configured the settings to keep it on.
Kernel: 6.6.0-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=31393d88-ca7c-4d57-ad07-51df3284f4ae rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 5.27.9 tk: Qt v: 5.15.11 wm: kwin_x11 vt: 2 dm: SDDM
Type: Laptop System: ASUSTeK product: GL702VM v: 1.0
serial: <superuser required>
Mobo: ASUSTeK model: GL702VM v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: GL702VM.310 date: 04/29/2019
ID-1: BAT0 charge: N/A condition: N/A volts: N/A model: N/A type: Unknown
serial: N/A status: not charging
System RAM: total: 32 GiB available: 31.29 GiB used: 3.77 GiB (12.1%)
Info: model: Intel Core i7-6700HQ bits: 64 type: MT MCP arch: Skylake-S
gen: core 6 level: v3 note: check built: 2015 process: Intel 14nm family: 6
model-id: 0x5E (94) stepping: 3 microcode: 0xF0
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 1291 high: 1400 min/max: 800/3500 scaling:
driver: intel_pstate governor: powersave cores: 1: 1241 2: 1400 3: 1315
4: 1400 5: 800 6: 1400 7: 1377 8: 1400 bogomips: 41621
smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
Type: gather_data_sampling status: Vulnerable: No microcode
vulnerable
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, STIBP: conditional,
RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA GP106BM [GeForce GTX 1060 Mobile 6GB] vendor: ASUSTeK
driver: nvidia v: 470.223.02 alternate: nouveau,nvidia_drm non-free: 545.xx+
status: current (as of 2023-11; EOL~2026-12-xx) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-2021 pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 01:00.0 chip-ID: 10de:1c60 class-ID: 0300
Device-2: IMC Networks [] driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:2 chip-ID: 13d3:5666
Display: x11 server: X.Org v: 21.1.9 with: Xwayland v: 23.2.2
compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia display-ID: :0
screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 128 s-size: 381x211mm (15.00x8.31")
s-diag: 436mm (17.15")
Monitor-1: Unknown-1 mapped: DP-4 res: 1920x1080 hz: 60 dpi: 128
size: 382x215mm (15.04x8.46") modes: 1920x1080
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
drv: swrast gbm: drv: kms_swrast surfaceless: drv: swrast x11: drv: nvidia
inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 470.223.02
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 1060/PCIe/SSE2
memory: 5.86 GiB
API: Vulkan v: 1.3.269 layers: 1 device: 0 type: discrete-gpu
name: NVIDIA GeForce GTX 1060 driver: nvidia v: 470.223.02
device-ID: 10de:1c60 surfaces: xcb,xlib
Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel alternate: snd_soc_avs bus-ID: 00:1f.3
chip-ID: 8086:a170 class-ID: 0403
Device-2: NVIDIA GP106 High Definition Audio vendor: ASUSTeK
bus-ID: 01:00.1 chip-ID: 10de:10f1 class-ID: 0403
API: ALSA v: k6.6.0-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.83 status: off with: wireplumber status: active
tools: pw-cli,wpctl
Device-1: Intel Wireless 7265 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:095a class-ID: 0280
vendor: ASUSTeK driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-3: KYE Systems (Mouse Systems) GF3000F Ethernet Adapter
driver: hid-generic,usbhid type: USB rev: 1.1 speed: 12 Mb/s lanes: 1
mode: 1.1 bus-ID: 1-6:4 chip-ID: 0458:6001 class-ID: 0301
IF-ID-1: docker0 state: down mac: <filter>
IF-ID-2: nekoray-tun state: unknown speed: 10000 Mbps duplex: full mac: N/A
IP v6: <filter> virtual: stable-privacy proto kernel_ll scope: link
Device-1: Intel Bluetooth wireless interface driver: btusb v: 0.8 type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-9:6 chip-ID: 8087:0a2a
class-ID: e001
Local Storage: total: 1.82 TiB used: 1.41 TiB (77.5%)
model: SSD 970 EVO Plus 1TB size: 931.51 GiB block-size: physical: 512 B
fw-rev: 2B2QEXM7 temp: 47.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: HGST (Hitachi) model: HTS721010A9E630
tech: HDD rpm: 7200 serial: <filter> fw-rev: A3V0 scheme: GPT
ID-1: / raw-size: 182.54 GiB size: 178.61 GiB (97.85%)
used: 38.28 GiB (21.4%) fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5
label: N/A uuid: 31393d88-ca7c-4d57-ad07-51df3284f4ae
ID-2: /boot/efi raw-size: 953 MiB size: 951.1 MiB (99.80%)
used: 316 KiB (0.0%) fs: vfat dev: /dev/nvme0n1p6 maj-min: 259:6 label: N/A
uuid: 09A3-3B22
ID-3: /home raw-size: 139.7 GiB size: 136.45 GiB (97.67%)
used: 57 GiB (41.8%) fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4 label: N/A
uuid: c1a070fd-641a-46bf-9d0f-392b5d5def66
ID-4: /mnt/nvme0n1p2 raw-size: 575.63 GiB size: 575.63 GiB (100.00%)
used: 424.81 GiB (73.8%) fs: ntfs dev: /dev/nvme0n1p2 maj-min: 259:2
label: Windows 11 uuid: 01D5C893E9C076B0
ID-5: /mnt/sda4 raw-size: 931.51 GiB size: 931.51 GiB (100.00%)
used: 923.42 GiB (99.1%) fs: ntfs dev: /dev/sda4 maj-min: 8:4
label: Repository uuid: 9A767CBB767C99A9
ID-1: swap-1 type: partition size: 32.46 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
uuid: 4badc183-3ffe-4dc1-8c35-e7d2ff44497e
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 260 MiB fs: vfat label: SYSTEM
uuid: CAC8-3BE2
Device-1: 1-4:2 info: IMC Networks [] type: video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
power: 500mA chip-ID: 13d3:5666 class-ID: 0e02 serial: <filter>
Device-2: 1-5:3 info: [] type: <vendor specific> driver: N/A interfaces: 1
rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 200mA
chip-ID: 2808:93a9 class-ID: 0000
Device-3: 1-6:4 info: KYE Systems (Mouse Systems) GF3000F Ethernet Adapter
type: mouse,keyboard driver: hid-generic,usbhid interfaces: 3 rev: 1.1
Device-4: 1-8:5 info: ASUSTek [] type: keyboard,mouse driver: asus,usbhid
interfaces: 3 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
power: 100mA chip-ID: 0b05:1837 class-ID: 0301
Device-5: 1-9:6 info: Intel Bluetooth wireless interface type: bluetooth
mode: 1.1 power: 100mA chip-ID: 8087:0a2a class-ID: e001
Hub-2: 2-0:1 info: super-speed hub ports: 8 rev: 3.0
System Temperatures: cpu: 59.0 C pch: 54.5 C mobo: N/A gpu: nvidia temp: 60 C
Fan Speeds (rpm): cpu: 2500
Processes: 307 Uptime: 16m wakeups: 1 Init: systemd v: 254 default: graphical
tool: systemctl Compilers: gcc: 13.2.1 clang: 16.0.6 Packages: 1702
pm: pacman pkgs: 1689 libs: 484 tools: pamac,yay pm: flatpak pkgs: 13
Shell: Zsh v: 5.9 running-in: konsole inxi: 3.3.31
