I have used this commands.
sudo systemctl enable fstrim.timer
sudo systemctl start fstrim.timer
And got this output
[carl@andersen ~]$ sudo systemctl start fstrim.timer
[sudo] adgangskode for carl:
[carl@andersen ~]$ systemctl status fstrim.timer
● fstrim.timer - Discard unused blocks once a week
Loaded: loaded (/usr/lib/systemd/system/fstrim.timer; enabled; vendor pres>
Active: active (waiting) since Sun 2021-03-07 14:59:50 CET; 2min 39s ago
Trigger: Mon 2021-03-08 00:55:14 CET; 9h left
Triggers: ● fstrim.service
Docs: man:fstrim
mar 07 14:59:50 andersen systemd[1]: Started Discard unused blocks once a week.
lines 1-8/8 (END)…skipping…
Loaded: loaded (/usr/lib/systemd/system/fstrim.timer; enabled; vendor preset: disabled)
Docs: man:fstrim
Will it then start every Sunday at 07 14:59:50
or Mon 2021-03-08 00:55:14 CET???
