steam.sh[2396]: Running Steam on manjarolinux 23.0.0 64-bit
steam.sh[2396]: STEAM_RUNTIME is enabled automatically
setup.sh[2471]: Steam runtime environment up-to-date!
steam.sh[2396]: Steam client's requirements are satisfied
[2023-07-16 14:44:25] Startup - updater built Jul 10 2023 23:58:24
[2023-07-16 14:44:25] Startup - Steam Client launched with: '/home/marika/.local/share/Steam/ubuntu12_32/steam'
07/16 14:44:25 Init: Installing breakpad exception handler for appid(steam)/version(1689034492)/tid(2537)
[2023-07-16 14:44:25] Loading cached metrics from disk (/home/marika/.local/share/Steam/package/steam_client_metrics.bin)
[2023-07-16 14:44:25] Using the following download hosts for Public, Realm steamglobal
[2023-07-16 14:44:25] 1. https://client-update.akamai.steamstatic.com, /, Realm 'steamglobal', weight was 1000, source = 'update_hosts_cached.vdf'
[2023-07-16 14:44:25] 2. https://cdn.cloudflare.steamstatic.com, /client/, Realm 'steamglobal', weight was 1, source = 'update_hosts_cached.vdf'
[2023-07-16 14:44:25] 3. http://media.steampowered.com, /client/, Realm 'steamglobal', weight was 1, source = 'baked in'
[2023-07-16 14:44:25] Installation wird überprüft …
[2023-07-16 14:44:25] Verification complete
Loaded SDL version 3.0.0-1782-g214d5daa3
/usr/share/themes/Adwaita-dark/gtk-2.0/main.rc:733: error: unexpected identifier 'direction', expected character '}'
/usr/share/themes/Adwaita-dark/gtk-2.0/hacks.rc:28: error: invalid string constant "normal_entry", expected valid string constant
XRRGetOutputInfo Workaround: initialized with override: 0 real: 0xf087bdb0
XRRGetCrtcInfo Workaround: initialized with override: 0 real: 0xf087a500
GetWin32Stats: display was not open yet, good
ComputeStartupMode: found registry default startup mode: 0
Switching to desktopui, since -vgui was not specified
steamwebhelper.sh[2544]: Runtime for steamwebhelper: defaulting to /home/marika/.local/share/Steam/ubuntu12_64/steam-runtime-heavy
steamwebhelper.sh[2544]: glibc >= 2.34, partially disabling sandbox until CEF supports clone3()
CAppInfoCacheReadFromDiskThread took 18 milliseconds to initialize
Failed to init SteamVR because it isn't installed
local (potentially out of sync) copy of roaming config loaded - 2485 bytes.
BRefreshApplicationsInLibrary 1: 1ms
roaming config store loaded successfully - 2485 bytes.
migrating temporary roaming config store
System startup time: 4.32 seconds
steamwebhelper.sh[2743]: Runtime for steamwebhelper: defaulting to /home/marika/.local/share/Steam/ubuntu12_64/steam-runtime-heavy
steamwebhelper.sh[2743]: glibc >= 2.34, partially disabling sandbox until CEF supports clone3()
BuildCompleteAppOverviewChange: 262 apps
RegisterForAppOverview 1: 6ms
RegisterForAppOverview 2: 7ms
steamwebhelper.sh[2867]: Runtime for steamwebhelper: defaulting to /home/marika/.local/share/Steam/ubuntu12_64/steam-runtime-heavy
steamwebhelper.sh[2867]: glibc >= 2.34, partially disabling sandbox until CEF supports clone3()
RegisterForAppOverview 1: 4ms
RegisterForAppOverview 2: 4ms
steamwebhelper.sh[3001]: Runtime for steamwebhelper: defaulting to /home/marika/.local/share/Steam/ubuntu12_64/steam-runtime-heavy
steamwebhelper.sh[3001]: glibc >= 2.34, partially disabling sandbox until CEF supports clone3()
steamwebhelper.sh[3158]: Runtime for steamwebhelper: defaulting to /home/marika/.local/share/Steam/ubuntu12_64/steam-runtime-heavy
steamwebhelper.sh[3158]: glibc >= 2.34, partially disabling sandbox until CEF supports clone3()
steamwebhelper.sh[3316]: Runtime for steamwebhelper: defaulting to /home/marika/.local/share/Steam/ubuntu12_64/steam-runtime-heavy
steamwebhelper.sh[3316]: glibc >= 2.34, partially disabling sandbox until CEF supports clone3()
steamwebhelper.sh[3517]: Runtime for steamwebhelper: defaulting to /home/marika/.local/share/Steam/ubuntu12_64/steam-runtime-heavy
steamwebhelper.sh[3517]: glibc >= 2.34, partially disabling sandbox until CEF supports clone3()
steamwebhelper.sh[3702]: Runtime for steamwebhelper: defaulting to /home/marika/.local/share/Steam/ubuntu12_64/steam-runtime-heavy
steamwebhelper.sh[3702]: glibc >= 2.34, partially disabling sandbox until CEF supports clone3()
steamwebhelper.sh[3896]: Runtime for steamwebhelper: defaulting to /home/marika/.local/share/Steam/ubuntu12_64/steam-runtime-heavy
steamwebhelper.sh[3896]: glibc >= 2.34, partially disabling sandbox until CEF supports clone3()
steamwebhelper.sh[4103]: Runtime for steamwebhelper: defaulting to /home/marika/.local/share/Steam/ubuntu12_64/steam-runtime-heavy
steamwebhelper.sh[4103]: glibc >= 2.34, partially disabling sandbox until CEF supports clone3()
steamwebhelper.sh[4324]: Runtime for steamwebhelper: defaulting to /home/marika/.local/share/Steam/ubuntu12_64/steam-runtime-heavy
steamwebhelper.sh[4324]: glibc >= 2.34, partially disabling sandbox until CEF supports clone3()
steamwebhelper.sh[4558]: Runtime for steamwebhelper: defaulting to /home/marika/.local/share/Steam/ubuntu12_64/steam-runtime-heavy
steamwebhelper.sh[4558]: glibc >= 2.34, partially disabling sandbox until CEF supports clone3()
RegisterForAppOverview 1: 5ms
RegisterForAppOverview 2: 5ms
[2023-07-16 14:46:26] Background update loop checking for update. . .
[2023-07-16 14:46:26] Suche nach verfügbaren Updates …
[2023-07-16 14:46:26] Downloading manifest: https://client-update.akamai.steamstatic.com/steam_client_ubuntu12?t=2186454702
[2023-07-16 14:46:26] Manifest download: send request
[2023-07-16 14:46:26] Manifest download: waiting for download to finish
[2023-07-16 14:46:27] Manifest download: finished
[2023-07-16 14:46:27] Download skipped: /steam_client_ubuntu12?t=2186454702 version 1689034492, installed version 1689034492, existing pending version 0
[2023-07-16 14:46:27] Nothing to do
steamwebhelper.sh[4804]: Runtime for steamwebhelper: defaulting to /home/marika/.local/share/Steam/ubuntu12_64/steam-runtime-heavy
steamwebhelper.sh[4804]: glibc >= 2.34, partially disabling sandbox until CEF supports clone3()
[2023-07-16 14:46:43] Shutdown
inxi -G ✘ 127
Device-1: NVIDIA GA106 [GeForce RTX 3060 Lite Hash Rate] driver: nvidia
v: 535.54.03
Device-2: Microdia USB Live camera driver: snd-usb-audio,uvcvideo
type: USB
Display: x11 server: X.Org v: 21.1.8 driver: X: loaded: nvidia
unloaded: modesetting gpu: nvidia resolution: 1: 1920x1080~60Hz
2: 1920x1080~60Hz
API: OpenGL v: 4.6.0 NVIDIA 535.54.03 renderer: NVIDIA GeForce RTX
3060/PCIe/SSE2
mhwd -l -d --pci ✘ 1
> PCI Device: /devices/pci0000:00/0000:00:01.3/0000:02:00.2/0000:03:07.0/0000:09:00.0 (0200:10ec:8168)
Network controller Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
> AVAILABLE:
ATTACHED: PCI
VERSION: 2016.04.20
INFO: RealTek RTL-8168 Gigabit Ethernet driver
PRIORITY: 0
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
CLASSIDS: 0200
VENDORIDS: 1186 10ec
> PCI Device: /devices/pci0000:00/0000:00:03.1/0000:0b:00.0 (0300:10de:2504)
Display controller nVidia Corporation GA106 [GeForce RTX 3060 Lite Hash Rate]
> INSTALLED:
ATTACHED: PCI
VERSION: 2023.03.23
INFO: Closed source NVIDIA drivers for linux.
PRIORITY: 5
FREEDRIVER: false
DEPENDS: -
CONFLICTS: video*nvidia*
CLASSIDS: 0300 0302
VENDORIDS: 10de
> AVAILABLE:
ATTACHED: PCI
VERSION: 2023.03.23
PRIORITY: 5
FREEDRIVER: false
DEPENDS: -
CLASSIDS: 0300 0302
VENDORIDS: 10de
ATTACHED: PCI
VERSION: 2023.03.23
PRIORITY: 4
FREEDRIVER: false
DEPENDS: -
CLASSIDS: 0300 0302
VENDORIDS: 10de
ATTACHED: PCI
VERSION: 2018.05.04
INFO: Standard open source drivers.
PRIORITY: 2
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
CLASSIDS: 0300 0380 0302
VENDORIDS: 1002 8086 10de
ATTACHED: PCI
VERSION: 2020.01.13
INFO: X.org modesetting video driver.
PRIORITY: 1
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
CLASSIDS: 0300
VENDORIDS: *
ATTACHED: PCI
VERSION: 2017.03.12
INFO: X.org vesa video driver.
PRIORITY: 0
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
CLASSIDS: 0300
VENDORIDS: *
was ich schon alles ausprobiert habe:
installing `lib32-libnm`
Installing `lib32-libudev0-shim`
deinstall ´lib32-libgudev´
Downgrade libgudev to version 237
Viele male Steam-reset
Es funktioniert dann ein mal, aber der Client ist auf Englisch und
steam play
for all Titles ist disabled, so dass ich keine Spiele starten kann.
Wenn ich eine Option ändere, startet steam wieder wie oben in der Schleife.
steam -vgui
startet ebenso aber das kann ja nicht die Lösung sein, zudem steam friends immer wieder aufpoppt.
Weitere Berichte besagen dass man ´xdg-desktop-portal-gnome’ deinstallieren soll, jedoch ist es gar nicht installiert.
alle Pakete wurden reinstalliert, xdg, steam,
.steam datei renamed, aber ich bekomm es nicht hin.
