Hi guys,
I have this very annoying transparency enabled and have no idea how to disable it.
I have translucency disabled in KDE settings, but that doesn’t help at all
Thanks
S
Hi guys,
Thanks
S
Hey mate, I belive what you may be looking for is the Transparency option within “Breeze Widget Style”
I have the same situation here.
Unfortunately the KDE team seem to have removed the option to disable menu transparency completely, after enabling it.
The “Widget Style” department is gone for good, and so is the transpareny slider:
Right, found it.
Dzienkuje
