/var/log/Xorg.0.log:
[ 57.989] (--) Log file renamed from "/var/log/Xorg.pid-1779.log" to "/var/log/Xorg.0.log"
[ 57.989]
X.Org X Server 1.20.8
[ 57.989] Build Operating System: Linux Manjaro Linux
[ 57.989] Current Operating System: Linux kuro 5.7.19-2-MANJARO #1 SMP PREEMPT Fri Aug 28 20:22:12 UTC 2020 x86_64
[ 57.989] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.7-x86_64 root=UUID=1b6ed8f9-028c-4d53-9063-eba719402614 rw quiet apparmor=1 security=apparmor resume=UUID=ea1bcbd2-d92a-4411-9378-2a7d5f3bca17 udev.log_priority=3
[ 57.989] Build Date: 01 August 2020 07:25:56AM
[ 57.989]
[ 57.989] Current version of pixman: 0.40.0
[ 57.989] Before reporting problems, check http://wiki.x.org
[ 57.989] Markers: (--) probed, (**) from config file, (==) default setting,
[ 57.989] (==) Log file: "/var/log/Xorg.0.log", Time: Wed Sep 9 17:16:50 2020
[ 57.989] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 57.989] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 57.990] (==) ServerLayout "layout"
[ 57.990] (**) |-->Screen "Screen0" (0)
[ 57.990] (**) | |-->Monitor "Monitor0"
[ 57.990] (**) | |-->Device "Device0"
[ 57.990] (==) Automatically adding devices
[ 57.990] (==) Automatically enabling devices
[ 57.990] (==) Automatically adding GPU devices
[ 57.990] (==) Automatically binding GPU devices
[ 57.990] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 57.990] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[ 57.990] Entry deleted from font path.
[ 57.990] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 57.990] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/100dpi".
[ 57.990] (Run 'mkfontdir' on "/usr/share/fonts/100dpi").
[ 57.990] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/75dpi".
[ 57.990] (Run 'mkfontdir' on "/usr/share/fonts/75dpi").
[ 57.990] (==) FontPath set to:
/usr/share/fonts/misc,
/usr/share/fonts/TTF
[ 57.990] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 57.990] (**) Extension "COMPOSITE" is enabled
[ 57.990] (II) The server relies on udev to provide the list of input devices.
[ 57.990] (II) Module ABI versions:
[ 57.990] X.Org ANSI C Emulation: 0.4
[ 57.990] X.Org Video Driver: 24.1
[ 57.990] X.Org XInput driver : 24.1
[ 57.990] X.Org Server Extension : 10.0
[ 57.990] (++) using VT number 1
[ 57.990] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 57.991] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 57.993] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[ 57.993] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[ 57.995] (--) PCI:*(13@0:0:0) 10de:1b06:1458:377a rev 161, Mem @ 0xf6000000/16777216, 0xe0000000/268435456, 0xf0000000/33554432, I/O @ 0x0000f000/128, BIOS @ 0x????????/131072
[ 57.995] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 57.995] (II) LoadModule: "glx"
[ 57.995] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 57.997] (II) Module glx: vendor="X.Org Foundation"
[ 57.997] compiled for 1.20.8, module version = 1.0.0
[ 57.997] ABI class: X.Org Server Extension, version 10.0
[ 57.997] (II) LoadModule: "nvidia"
[ 57.997] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 57.997] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 57.997] compiled for 1.6.99.901, module version = 1.0.0
[ 57.997] Module class: X.Org Video Driver
[ 57.997] (II) NVIDIA dlloader X Driver 440.100 Fri May 29 08:21:27 UTC 2020
[ 57.997] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 57.997] (II) Loading sub module "fb"
[ 57.997] (II) LoadModule: "fb"
[ 57.997] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 57.997] (II) Module fb: vendor="X.Org Foundation"
[ 57.997] ABI class: X.Org ANSI C Emulation, version 0.4
[ 57.997] (II) Loading sub module "wfb"
[ 57.997] (II) LoadModule: "wfb"
[ 57.997] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 57.997] (II) Module wfb: vendor="X.Org Foundation"
[ 57.997] (II) Loading sub module "ramdac"
[ 57.997] (II) LoadModule: "ramdac"
[ 57.997] (II) Module "ramdac" already built-in
[ 57.998] (**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
[ 57.998] (==) NVIDIA(0): RGB weight 888
[ 57.998] (==) NVIDIA(0): Default visual is TrueColor
[ 57.998] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 57.998] (**) Option "AllowNVIDIAGpuScreens"
[ 57.998] (II) Applying OutputClass "nvidia" options to /dev/dri/card0
[ 57.998] (**) NVIDIA(0): Option "AllowEmptyInitialConfiguration"
[ 57.998] (**) NVIDIA(0): Enabling 2D acceleration
[ 57.998] (II) Loading sub module "glxserver_nvidia"
[ 57.998] (II) LoadModule: "glxserver_nvidia"
[ 57.998] (II) Loading /usr/lib/xorg/modules/extensions/libglxserver_nvidia.so
[ 58.003] (II) Module glxserver_nvidia: vendor="NVIDIA Corporation"
[ 58.003] compiled for 1.6.99.901, module version = 1.0.0
[ 58.003] Module class: X.Org Server Extension
[ 58.003] (II) NVIDIA GLX Module 440.100 Fri May 29 08:19:01 UTC 2020
[ 58.003] (II) NVIDIA: The X server supports PRIME Render Offload.
[ 58.119] (--) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:13:0:0
[ 58.119] (--) NVIDIA(0): DFP-0
[ 58.119] (--) NVIDIA(0): DFP-1 (boot)
[ 58.119] (--) NVIDIA(0): DFP-2 (boot)
[ 58.119] (--) NVIDIA(0): DFP-3
[ 58.119] (--) NVIDIA(0): DFP-4 (boot)
[ 58.119] (--) NVIDIA(0): DFP-5
[ 58.119] (--) NVIDIA(0): DFP-6 (boot)
[ 58.119] (--) NVIDIA(0): DFP-7
[ 58.119] (II) NVIDIA(0): NVIDIA GPU GeForce GTX 1080 Ti (GP102-A) at PCI:13:0:0
[ 58.119] (II) NVIDIA(0): (GPU-0)
[ 58.119] (--) NVIDIA(0): Memory: 11534336 kBytes
[ 58.119] (--) NVIDIA(0): VideoBIOS: 86.02.39.00.6a
[ 58.119] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[ 58.119] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 58.119] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 58.119] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 58.149] (--) NVIDIA(GPU-0): Sceptre E20 (DFP-1): connected
[ 58.149] (--) NVIDIA(GPU-0): Sceptre E20 (DFP-1): Internal TMDS
[ 58.149] (--) NVIDIA(GPU-0): Sceptre E20 (DFP-1): 600.0 MHz maximum pixel clock
[ 58.149] (--) NVIDIA(GPU-0): Acer CB272 (DFP-2): connected
[ 58.149] (--) NVIDIA(GPU-0): Acer CB272 (DFP-2): Internal DisplayPort
[ 58.149] (--) NVIDIA(GPU-0): Acer CB272 (DFP-2): 1440.0 MHz maximum pixel clock
[ 58.151] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 58.151] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 58.151] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 58.151] (--) NVIDIA(GPU-0): Hisense HDMI (DFP-4): connected
[ 58.151] (--) NVIDIA(GPU-0): Hisense HDMI (DFP-4): Internal DisplayPort
[ 58.151] (--) NVIDIA(GPU-0): Hisense HDMI (DFP-4): 1440.0 MHz maximum pixel clock
[ 58.153] (--) NVIDIA(GPU-0): DFP-5: disconnected
[ 58.153] (--) NVIDIA(GPU-0): DFP-5: Internal TMDS
[ 58.154] (--) NVIDIA(GPU-0): DFP-5: 165.0 MHz maximum pixel clock
[ 58.154] (--) NVIDIA(GPU-0): Samsung C32HG7x (DFP-6): connected
[ 58.154] (--) NVIDIA(GPU-0): Samsung C32HG7x (DFP-6): Internal DisplayPort
[ 58.154] (--) NVIDIA(GPU-0): Samsung C32HG7x (DFP-6): 1440.0 MHz maximum pixel clock
[ 58.155] (--) NVIDIA(GPU-0): DFP-7: disconnected
[ 58.155] (--) NVIDIA(GPU-0): DFP-7: Internal TMDS
[ 58.155] (--) NVIDIA(GPU-0): DFP-7: 165.0 MHz maximum pixel clock
[ 58.170] (==) NVIDIA(0):
[ 58.170] (==) NVIDIA(0): No modes were requested; the default mode "nvidia-auto-select"
[ 58.170] (==) NVIDIA(0): will be used as the requested mode.
[ 58.170] (II) NVIDIA(0): Validated MetaModes:
[ 58.170] (II) NVIDIA(0): "DFP-1:nvidia-auto-select,DFP-2:nvidia-auto-select,DFP-4:nvidia-auto-select,DFP-6:nvidia-auto-select"
[ 58.170] (II) NVIDIA(0): Virtual screen size determined to be 8000 x 1440
[ 58.174] (--) NVIDIA(0): DPI set to (94, 95); computed from "UseEdidDpi" X config
[ 58.174] (--) NVIDIA(0): option
[ 58.174] (II) NVIDIA: Using 24576.00 MB of virtual memory for indirect memory
[ 58.174] (II) NVIDIA: access.
[ 58.185] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[ 58.185] (II) NVIDIA(0): may not be running or the "AcpidSocketPath" X
[ 58.185] (II) NVIDIA(0): configuration option may not be set correctly. When the
[ 58.185] (II) NVIDIA(0): ACPI event daemon is available, the NVIDIA X driver will
[ 58.185] (II) NVIDIA(0): try to use it to receive ACPI event notifications. For
[ 58.185] (II) NVIDIA(0): details, please see the "ConnectToAcpid" and
[ 58.185] (II) NVIDIA(0): "AcpidSocketPath" X configuration options in Appendix B: X
[ 58.185] (II) NVIDIA(0): Config Options in the README.
[ 58.242] (II) NVIDIA(0): Setting mode "DFP-1:nvidia-auto-select,DFP-2:nvidia-auto-select,DFP-4:nvidia-auto-select,DFP-6:nvidia-auto-select"
[ 58.444] (==) NVIDIA(0): Disabling shared memory pixmaps
[ 58.444] (==) NVIDIA(0): Backing store enabled
[ 58.444] (==) NVIDIA(0): Silken mouse disabled
[ 58.445] (**) NVIDIA(0): DPMS enabled
[ 58.445] (WW) NVIDIA(0): Option "NoLogo" is not used
[ 58.445] (II) Loading sub module "dri2"
[ 58.445] (II) LoadModule: "dri2"
[ 58.445] (II) Module "dri2" already built-in
[ 58.445] (II) NVIDIA(0): [DRI2] Setup complete
[ 58.445] (II) NVIDIA(0): [DRI2] VDPAU driver: nvidia
[ 58.445] (II) Initializing extension Generic Event Extension
[ 58.445] (II) Initializing extension SHAPE
[ 58.445] (II) Initializing extension MIT-SHM
[ 58.445] (II) Initializing extension XInputExtension
[ 58.445] (II) Initializing extension XTEST
[ 58.445] (II) Initializing extension BIG-REQUESTS
[ 58.445] (II) Initializing extension SYNC
[ 58.445] (II) Initializing extension XKEYBOARD
[ 58.445] (II) Initializing extension XC-MISC
[ 58.445] (II) Initializing extension SECURITY
[ 58.445] (II) Initializing extension XFIXES
[ 58.445] (II) Initializing extension RENDER
[ 58.445] (II) Initializing extension RANDR
[ 58.446] (II) Initializing extension COMPOSITE
[ 58.446] (II) Initializing extension DAMAGE
[ 58.446] (II) Initializing extension MIT-SCREEN-SAVER
[ 58.446] (II) Initializing extension DOUBLE-BUFFER
[ 58.446] (II) Initializing extension RECORD
[ 58.446] (II) Initializing extension DPMS
[ 58.446] (II) Initializing extension Present
[ 58.446] (II) Initializing extension DRI3
[ 58.446] (II) Initializing extension X-Resource
[ 58.446] (II) Initializing extension XVideo
[ 58.446] (II) Initializing extension XVideo-MotionCompensation
[ 58.446] (II) Initializing extension GLX
[ 58.446] (II) Indirect GLX disabled.
[ 58.446] (II) GLX: Another vendor is already registered for screen 0
[ 58.446] (II) Initializing extension XFree86-VidModeExtension
[ 58.446] (II) Initializing extension XFree86-DGA
[ 58.446] (II) Initializing extension XFree86-DRI
[ 58.446] (II) Initializing extension DRI2
[ 58.446] (II) Initializing extension NV-GLX
[ 58.446] (II) Initializing extension NV-CONTROL
[ 58.446] (II) Initializing extension XINERAMA
[ 58.472] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 58.472] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 58.472] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 58.472] (**) Power Button: Applying InputClass "system-keyboard"
[ 58.472] (**) Power Button: Applying InputClass "Keyboard Defaults"
[ 58.472] (II) LoadModule: "libinput"
[ 58.472] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 58.472] (II) Module libinput: vendor="X.Org Foundation"
[ 58.473] compiled for 1.20.8, module version = 0.30.0
[ 58.473] Module class: X.Org XInput Driver
[ 58.473] ABI class: X.Org XInput driver, version 24.1
[ 58.473] (II) Using input driver 'libinput' for 'Power Button'
[ 58.473] (**) Power Button: always reports core events
[ 58.473] (**) Option "Device" "/dev/input/event1"
[ 58.473] (**) Option "_source" "server/udev"
[ 58.473] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 58.473] (II) event1 - Power Button: device is a keyboard
[ 58.473] (II) event1 - Power Button: device removed
[ 58.516] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input1/event1"
[ 58.516] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 58.516] (**) Option "xkb_model" "pc105"
[ 58.516] (**) Option "xkb_layout" "us"
[ 58.516] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 58.536] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 58.536] (II) event1 - Power Button: device is a keyboard
[ 58.537] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[ 58.537] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 58.537] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 58.537] (**) Power Button: Applying InputClass "system-keyboard"
[ 58.537] (**) Power Button: Applying InputClass "Keyboard Defaults"
[ 58.537] (II) Using input driver 'libinput' for 'Power Button'
[ 58.537] (**) Power Button: always reports core events
[ 58.537] (**) Option "Device" "/dev/input/event0"
[ 58.537] (**) Option "_source" "server/udev"
[ 58.537] (II) event0 - Power Button: is tagged by udev as: Keyboard
[ 58.537] (II) event0 - Power Button: device is a keyboard
[ 58.538] (II) event0 - Power Button: device removed
[ 58.556] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0/event0"
[ 58.556] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
[ 58.556] (**) Option "xkb_model" "pc105"
[ 58.556] (**) Option "xkb_layout" "us"
[ 58.556] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 58.557] (II) event0 - Power Button: is tagged by udev as: Keyboard
[ 58.557] (II) event0 - Power Button: device is a keyboard
[ 58.558] (II) config/udev: Adding input device Logitech USB Receiver (/dev/input/event21)
[ 58.558] (**) Logitech USB Receiver: Applying InputClass "evdev pointer catchall"
[ 58.558] (**) Logitech USB Receiver: Applying InputClass "libinput pointer catchall"
[ 58.558] (II) Using input driver 'libinput' for 'Logitech USB Receiver'
[ 58.558] (**) Logitech USB Receiver: always reports core events
[ 58.558] (**) Option "Device" "/dev/input/event21"
[ 58.558] (**) Option "_source" "server/udev"
[ 58.614] (II) event21 - Logitech USB Receiver: is tagged by udev as: Mouse
[ 58.614] (II) event21 - Logitech USB Receiver: device is a pointer
[ 58.614] (II) event21 - Logitech USB Receiver: device removed
[ 58.676] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.3/0000:02:00.0/usb1/1-13/1-13:1.0/0003:046D:C537.0003/input/input23/event21"
[ 58.676] (II) XINPUT: Adding extended input device "Logitech USB Receiver" (type: MOUSE, id 8)
[ 58.676] (**) Option "AccelerationScheme" "none"
[ 58.676] (**) Logitech USB Receiver: (accel) selected scheme none/0
[ 58.676] (**) Logitech USB Receiver: (accel) acceleration factor: 2.000
[ 58.676] (**) Logitech USB Receiver: (accel) acceleration threshold: 4
[ 58.734] (II) event21 - Logitech USB Receiver: is tagged by udev as: Mouse
[ 58.734] (II) event21 - Logitech USB Receiver: device is a pointer
[ 58.735] (II) config/udev: Adding input device Logitech USB Receiver (/dev/input/mouse0)
[ 58.735] (II) No input driver specified, ignoring this device.
[ 58.735] (II) This device may have been added with another device file.
[ 58.736] (II) config/udev: Adding input device Logitech USB Receiver Keyboard (/dev/input/event22)
[ 58.736] (**) Logitech USB Receiver Keyboard: Applying InputClass "evdev keyboard catchall"
[ 58.736] (**) Logitech USB Receiver Keyboard: Applying InputClass "libinput keyboard catchall"
[ 58.736] (**) Logitech USB Receiver Keyboard: Applying InputClass "system-keyboard"
[ 58.736] (**) Logitech USB Receiver Keyboard: Applying InputClass "Keyboard Defaults"
[ 58.736] (II) Using input driver 'libinput' for 'Logitech USB Receiver Keyboard'
[ 58.736] (**) Logitech USB Receiver Keyboard: always reports core events
[ 58.736] (**) Option "Device" "/dev/input/event22"
[ 58.736] (**) Option "_source" "server/udev"
[ 58.737] (II) event22 - Logitech USB Receiver Keyboard: is tagged by udev as: Keyboard
[ 58.737] (II) event22 - Logitech USB Receiver Keyboard: device is a keyboard
[ 58.737] (II) event22 - Logitech USB Receiver Keyboard: device removed
[ 58.770] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.3/0000:02:00.0/usb1/1-13/1-13:1.1/0003:046D:C537.0004/input/input24/event22"
[ 58.770] (II) XINPUT: Adding extended input device "Logitech USB Receiver Keyboard" (type: KEYBOARD, id 9)
[ 58.770] (**) Option "xkb_model" "pc105"
[ 58.770] (**) Option "xkb_layout" "us"
[ 58.770] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 58.771] (II) event22 - Logitech USB Receiver Keyboard: is tagged by udev as: Keyboard
[ 58.771] (II) event22 - Logitech USB Receiver Keyboard: device is a keyboard
[ 58.772] (II) config/udev: Adding input device Logitech USB Receiver Consumer Control (/dev/input/event23)
[ 58.772] (**) Logitech USB Receiver Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 58.772] (**) Logitech USB Receiver Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 58.772] (**) Logitech USB Receiver Consumer Control: Applying InputClass "system-keyboard"
[ 58.772] (**) Logitech USB Receiver Consumer Control: Applying InputClass "Keyboard Defaults"
[ 58.772] (II) Using input driver 'libinput' for 'Logitech USB Receiver Consumer Control'
[ 58.772] (**) Logitech USB Receiver Consumer Control: always reports core events
[ 58.772] (**) Option "Device" "/dev/input/event23"
[ 58.772] (**) Option "_source" "server/udev"
[ 58.774] (II) event23 - Logitech USB Receiver Consumer Control: is tagged by udev as: Keyboard
[ 58.774] (II) event23 - Logitech USB Receiver Consumer Control: device is a keyboard
[ 58.774] (II) event23 - Logitech USB Receiver Consumer Control: device removed
[ 58.810] (II) libinput: Logitech USB Receiver Consumer Control: needs a virtual subdevice
[ 58.810] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.3/0000:02:00.0/usb1/1-13/1-13:1.1/0003:046D:C537.0004/input/input25/event23"
[ 58.810] (II) XINPUT: Adding extended input device "Logitech USB Receiver Consumer Control" (type: MOUSE, id 10)
[ 58.810] (**) Option "AccelerationScheme" "none"
[ 58.810] (**) Logitech USB Receiver Consumer Control: (accel) selected scheme none/0
[ 58.810] (**) Logitech USB Receiver Consumer Control: (accel) acceleration factor: 2.000
[ 58.810] (**) Logitech USB Receiver Consumer Control: (accel) acceleration threshold: 4
[ 58.811] (II) event23 - Logitech USB Receiver Consumer Control: is tagged by udev as: Keyboard
[ 58.811] (II) event23 - Logitech USB Receiver Consumer Control: device is a keyboard
[ 58.812] (II) config/udev: Adding input device Logitech USB Receiver System Control (/dev/input/event24)
[ 58.812] (**) Logitech USB Receiver System Control: Applying InputClass "evdev keyboard catchall"
[ 58.812] (**) Logitech USB Receiver System Control: Applying InputClass "libinput keyboard catchall"
[ 58.812] (**) Logitech USB Receiver System Control: Applying InputClass "system-keyboard"
[ 58.812] (**) Logitech USB Receiver System Control: Applying InputClass "Keyboard Defaults"
[ 58.812] (II) Using input driver 'libinput' for 'Logitech USB Receiver System Control'
[ 58.812] (**) Logitech USB Receiver System Control: always reports core events
[ 58.812] (**) Option "Device" "/dev/input/event24"
[ 58.812] (**) Option "_source" "server/udev"
[ 58.814] (II) event24 - Logitech USB Receiver System Control: is tagged by udev as: Keyboard
[ 58.814] (II) event24 - Logitech USB Receiver System Control: device is a keyboard
[ 58.814] (II) event24 - Logitech USB Receiver System Control: device removed
[ 58.850] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.3/0000:02:00.0/usb1/1-13/1-13:1.1/0003:046D:C537.0004/input/input26/event24"
[ 58.850] (II) XINPUT: Adding extended input device "Logitech USB Receiver System Control" (type: KEYBOARD, id 11)
[ 58.850] (**) Option "xkb_model" "pc105"
[ 58.850] (**) Option "xkb_layout" "us"
[ 58.850] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 58.851] (II) event24 - Logitech USB Receiver System Control: is tagged by udev as: Keyboard
[ 58.851] (II) event24 - Logitech USB Receiver System Control: device is a keyboard
[ 58.852] (II) config/udev: Adding input device Logitech USB Receiver (/dev/input/event25)
[ 58.852] (II) No input driver specified, ignoring this device.
[ 58.852] (II) This device may have been added with another device file.
[ 58.853] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event3)
[ 58.853] (II) No input driver specified, ignoring this device.
[ 58.853] (II) This device may have been added with another device file.
[ 58.853] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event4)
[ 58.853] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event5)
[ 58.854] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event6)
[ 58.854] (II) No input driver specified, ignoring this device.
[ 58.854] (II) This device may have been added with another device file.
[ 58.854] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=10 (/dev/input/event7)
[ 58.854] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=11 (/dev/input/event8)
[ 58.855] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=12 (/dev/input/event9)
[ 58.855] (II) No input driver specified, ignoring this device.
[ 58.855] (II) This device may have been added with another device file.
[ 58.855] (II) config/udev: Adding input device Afterglow Gamepad for Xbox 360 (/dev/input/event17)
[ 58.856] (II) config/udev: Adding input device Afterglow Gamepad for Xbox 360 (/dev/input/js0)
[ 58.856] (II) No input driver specified, ignoring this device.
[ 58.856] (II) This device may have been added with another device file.
[ 58.857] (II) config/udev: Adding input device Logitech G413 Silver Mechanical Gaming Keyboard (/dev/input/event18)
[ 58.857] (**) Logitech G413 Silver Mechanical Gaming Keyboard: Applying InputClass "evdev keyboard catchall"
[ 58.857] (**) Logitech G413 Silver Mechanical Gaming Keyboard: Applying InputClass "libinput keyboard catchall"
[ 58.857] (**) Logitech G413 Silver Mechanical Gaming Keyboard: Applying InputClass "system-keyboard"
[ 58.857] (**) Logitech G413 Silver Mechanical Gaming Keyboard: Applying InputClass "Keyboard Defaults"
[ 58.857] (II) Using input driver 'libinput' for 'Logitech G413 Silver Mechanical Gaming Keyboard'
[ 58.857] (**) Logitech G413 Silver Mechanical Gaming Keyboard: always reports core events
[ 58.857] (**) Option "Device" "/dev/input/event18"
[ 58.857] (**) Option "_source" "server/udev"
[ 58.858] (II) event18 - Logitech G413 Silver Mechanical Gaming Keyboard: is tagged by udev as: Keyboard
[ 58.858] (II) event18 - Logitech G413 Silver Mechanical Gaming Keyboard: device is a keyboard
[ 58.858] (II) event18 - Logitech G413 Silver Mechanical Gaming Keyboard: device removed
[ 58.876] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:0f:00.3/usb3/3-4/3-4:1.0/0003:046D:C33A.0001/input/input18/event18"
[ 58.876] (II) XINPUT: Adding extended input device "Logitech G413 Silver Mechanical Gaming Keyboard" (type: KEYBOARD, id 12)
[ 58.876] (**) Option "xkb_model" "pc105"
[ 58.876] (**) Option "xkb_layout" "us"
[ 58.876] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 58.878] (II) event18 - Logitech G413 Silver Mechanical Gaming Keyboard: is tagged by udev as: Keyboard
[ 58.878] (II) event18 - Logitech G413 Silver Mechanical Gaming Keyboard: device is a keyboard
[ 58.879] (II) config/udev: Adding input device Logitech G413 Silver Mechanical Gaming Keyboard (/dev/input/event19)
[ 58.879] (**) Logitech G413 Silver Mechanical Gaming Keyboard: Applying InputClass "evdev keyboard catchall"
[ 58.879] (**) Logitech G413 Silver Mechanical Gaming Keyboard: Applying InputClass "libinput keyboard catchall"
[ 58.879] (**) Logitech G413 Silver Mechanical Gaming Keyboard: Applying InputClass "system-keyboard"
[ 58.879] (**) Logitech G413 Silver Mechanical Gaming Keyboard: Applying InputClass "Keyboard Defaults"
[ 58.879] (II) Using input driver 'libinput' for 'Logitech G413 Silver Mechanical Gaming Keyboard'
[ 58.879] (**) Logitech G413 Silver Mechanical Gaming Keyboard: always reports core events
[ 58.879] (**) Option "Device" "/dev/input/event19"
[ 58.879] (**) Option "_source" "server/udev"
[ 58.880] (II) event19 - Logitech G413 Silver Mechanical Gaming Keyboard: is tagged by udev as: Keyboard
[ 58.881] (II) event19 - Logitech G413 Silver Mechanical Gaming Keyboard: device is a keyboard
[ 58.881] (II) event19 - Logitech G413 Silver Mechanical Gaming Keyboard: device removed
[ 58.916] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:0f:00.3/usb3/3-4/3-4:1.1/0003:046D:C33A.0002/input/input19/event19"
[ 58.916] (II) XINPUT: Adding extended input device "Logitech G413 Silver Mechanical Gaming Keyboard" (type: KEYBOARD, id 13)
[ 58.916] (**) Option "xkb_model" "pc105"
[ 58.916] (**) Option "xkb_layout" "us"
[ 58.916] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 58.918] (II) event19 - Logitech G413 Silver Mechanical Gaming Keyboard: is tagged by udev as: Keyboard
[ 58.918] (II) event19 - Logitech G413 Silver Mechanical Gaming Keyboard: device is a keyboard
[ 58.919] (II) config/udev: Adding input device Logitech G413 Silver Mechanical Gaming Keyboard Consumer Control (/dev/input/event20)
[ 58.919] (**) Logitech G413 Silver Mechanical Gaming Keyboard Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 58.919] (**) Logitech G413 Silver Mechanical Gaming Keyboard Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 58.919] (**) Logitech G413 Silver Mechanical Gaming Keyboard Consumer Control: Applying InputClass "system-keyboard"
[ 58.919] (**) Logitech G413 Silver Mechanical Gaming Keyboard Consumer Control: Applying InputClass "Keyboard Defaults"
[ 58.919] (II) Using input driver 'libinput' for 'Logitech G413 Silver Mechanical Gaming Keyboard Consumer Control'
[ 58.919] (**) Logitech G413 Silver Mechanical Gaming Keyboard Consumer Control: always reports core events
[ 58.919] (**) Option "Device" "/dev/input/event20"
[ 58.919] (**) Option "_source" "server/udev"
[ 58.920] (II) event20 - Logitech G413 Silver Mechanical Gaming Keyboard Consumer Control: is tagged by udev as: Keyboard
[ 58.920] (II) event20 - Logitech G413 Silver Mechanical Gaming Keyboard Consumer Control: device is a keyboard
[ 58.921] (II) event20 - Logitech G413 Silver Mechanical Gaming Keyboard Consumer Control: device removed
[ 58.970] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:0f:00.3/usb3/3-4/3-4:1.1/0003:046D:C33A.0002/input/input20/event20"
[ 58.970] (II) XINPUT: Adding extended input device "Logitech G413 Silver Mechanical Gaming Keyboard Consumer Control" (type: KEYBOARD, id 14)
[ 58.970] (**) Option "xkb_model" "pc105"
[ 58.970] (**) Option "xkb_layout" "us"
[ 58.970] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 58.971] (II) event20 - Logitech G413 Silver Mechanical Gaming Keyboard Consumer Control: is tagged by udev as: Keyboard
[ 58.971] (II) event20 - Logitech G413 Silver Mechanical Gaming Keyboard Consumer Control: device is a keyboard
[ 58.972] (II) config/udev: Adding input device HD-Audio Generic Front Mic (/dev/input/event10)
[ 58.972] (II) No input driver specified, ignoring this device.
[ 58.972] (II) This device may have been added with another device file.
[ 58.972] (II) config/udev: Adding input device HD-Audio Generic Rear Mic (/dev/input/event11)
[ 58.972] (II) config/udev: Adding input device HD-Audio Generic Line (/dev/input/event12)
[ 58.973] (II) config/udev: Adding input device HD-Audio Generic Line Out Front (/dev/input/event13)
[ 58.973] (II) No input driver specified, ignoring this device.
[ 58.973] (II) This device may have been added with another device file.
[ 58.973] (II) config/udev: Adding input device HD-Audio Generic Line Out Surround (/dev/input/event14)
[ 58.973] (II) config/udev: Adding input device HD-Audio Generic Line Out CLFE (/dev/input/event15)
[ 58.973] (II) config/udev: Adding input device HD-Audio Generic Front Headphone (/dev/input/event16)
[ 58.974] (II) config/udev: Adding input device PC Speaker (/dev/input/event2)
[ 58.974] (II) No input driver specified, ignoring this device.
[ 58.974] (II) This device may have been added with another device file.
[ 58.977] (**) Logitech USB Receiver Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 58.977] (**) Logitech USB Receiver Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 58.977] (**) Logitech USB Receiver Consumer Control: Applying InputClass "system-keyboard"
[ 58.977] (**) Logitech USB Receiver Consumer Control: Applying InputClass "Keyboard Defaults"
[ 58.977] (II) Using input driver 'libinput' for 'Logitech USB Receiver Consumer Control'
[ 58.978] (**) Logitech USB Receiver Consumer Control: always reports core events
[ 58.978] (**) Option "Device" "/dev/input/event23"
[ 58.978] (**) Option "_source" "_driver/libinput"
[ 58.978] (II) libinput: Logitech USB Receiver Consumer Control: is a virtual subdevice
[ 58.978] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.3/0000:02:00.0/usb1/1-13/1-13:1.1/0003:046D:C537.0004/input/input25/event23"
[ 58.978] (II) XINPUT: Adding extended input device "Logitech USB Receiver Consumer Control" (type: KEYBOARD, id 15)
[ 58.978] (**) Option "xkb_model" "pc105"
[ 58.978] (**) Option "xkb_layout" "us"
[ 58.978] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 58.978] (--) NVIDIA(GPU-0): Acer CB272 (DFP-2): connected
[ 58.978] (--) NVIDIA(GPU-0): Acer CB272 (DFP-2): Internal DisplayPort
[ 58.978] (--) NVIDIA(GPU-0): Acer CB272 (DFP-2): 1440.0 MHz maximum pixel clock
[ 58.978] (--) NVIDIA(GPU-0): Hisense HDMI (DFP-4): connected
[ 58.978] (--) NVIDIA(GPU-0): Hisense HDMI (DFP-4): Internal DisplayPort
[ 58.978] (--) NVIDIA(GPU-0): Hisense HDMI (DFP-4): 1440.0 MHz maximum pixel clock
[ 58.979] (--) NVIDIA(GPU-0): Samsung C32HG7x (DFP-6): connected
[ 58.979] (--) NVIDIA(GPU-0): Samsung C32HG7x (DFP-6): Internal DisplayPort
[ 58.979] (--) NVIDIA(GPU-0): Samsung C32HG7x (DFP-6): 1440.0 MHz maximum pixel clock
[ 58.979] (EE) Failed to open authorization file "/var/run/sddm/{97b67375-6dbd-4b94-a18c-2adfd58c2234}": No such file or directory
[ 58.983] (II) NVIDIA(0): Setting mode "DP-0: nvidia-auto-select @1920x1080 +1600+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}, DP-2: nvidia-auto-select @1920x1080 +3520+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}, DP-4: nvidia-auto-select @2560x1440 +5440+0 {ViewPortIn=2560x1440, ViewPortOut=2560x1440+0+0}"
[ 59.203] (II) NVIDIA(0): Setting mode "DP-0: nvidia-auto-select @1920x1080 +1600+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}, DP-2: nvidia-auto-select @1920x1080 +3520+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}"
[ 59.420] (II) NVIDIA(0): Setting mode "DP-0: nvidia-auto-select @1920x1080 +0+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}, DP-2: nvidia-auto-select @1920x1080 +3520+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}"
[ 59.559] (II) NVIDIA(0): Setting mode "DP-0: nvidia-auto-select @1920x1080 +0+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}, DP-2: nvidia-auto-select @1920x1080 +1920+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}"
[ 59.701] (II) NVIDIA(0): Setting mode "DP-0: nvidia-auto-select @1920x1080 +0+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}, DP-2: nvidia-auto-select @1920x1080 +1920+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}, DP-4: nvidia-auto-select @2560x1440 +3840+0 {ViewPortIn=2560x1440, ViewPortOut=2560x1440+0+0}"
[ 59.878] (II) NVIDIA(0): Setting mode "DP-2: nvidia-auto-select @1920x1080 +1920+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}, DP-4: nvidia-auto-select @2560x1440 +3840+0 {ViewPortIn=2560x1440, ViewPortOut=2560x1440+0+0}"
[ 60.016] (II) NVIDIA(0): Setting mode "DP-2: nvidia-auto-select @1920x1080 +1920+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}"
[ 60.157] (II) NVIDIA(0): Setting mode "DP-2: nvidia-auto-select @1920x1080 +0+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}"
[ 60.253] (II) NVIDIA(0): Setting mode "DP-2: nvidia-auto-select @1920x1080 +0+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}, DP-4: nvidia-auto-select @2560x1440 +1920+0 {ViewPortIn=2560x1440, ViewPortOut=2560x1440+0+0}"
[ 60.383] (II) NVIDIA(0): Setting mode "DP-4: nvidia-auto-select @2560x1440 +1920+0 {ViewPortIn=2560x1440, ViewPortOut=2560x1440+0+0}"
[ 60.460] (II) NVIDIA(0): Setting mode "NULL"
[ 60.483] (II) NVIDIA(0): Setting mode "DP-4: nvidia-auto-select @2560x1440 +0+0 {ViewPortIn=2560x1440, ViewPortOut=2560x1440+0+0}"
[ 66.836] (--) NVIDIA(GPU-0): Sceptre E20 (DFP-1): connected
[ 66.836] (--) NVIDIA(GPU-0): Sceptre E20 (DFP-1): Internal TMDS
[ 66.836] (--) NVIDIA(GPU-0): Sceptre E20 (DFP-1): 600.0 MHz maximum pixel clock
[ 66.865] (--) NVIDIA(GPU-0): Sceptre E20 (DFP-1): connected
[ 66.865] (--) NVIDIA(GPU-0): Sceptre E20 (DFP-1): Internal TMDS
[ 66.865] (--) NVIDIA(GPU-0): Sceptre E20 (DFP-1): 600.0 MHz maximum pixel clock
[ 68.322] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 68.322] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 68.322] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 68.351] (--) NVIDIA(GPU-0): Sceptre E20 (DFP-1): connected
[ 68.351] (--) NVIDIA(GPU-0): Sceptre E20 (DFP-1): Internal TMDS
[ 68.351] (--) NVIDIA(GPU-0): Sceptre E20 (DFP-1): 600.0 MHz maximum pixel clock
[ 68.351] (--) NVIDIA(GPU-0): Acer CB272 (DFP-2): connected
[ 68.351] (--) NVIDIA(GPU-0): Acer CB272 (DFP-2): Internal DisplayPort
[ 68.351] (--) NVIDIA(GPU-0): Acer CB272 (DFP-2): 1440.0 MHz maximum pixel clock
[ 68.353] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 68.353] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 68.353] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 68.354] (--) NVIDIA(GPU-0): Hisense HDMI (DFP-4): connected
[ 68.354] (--) NVIDIA(GPU-0): Hisense HDMI (DFP-4): Internal DisplayPort
[ 68.354] (--) NVIDIA(GPU-0): Hisense HDMI (DFP-4): 1440.0 MHz maximum pixel clock
[ 68.356] (--) NVIDIA(GPU-0): DFP-5: disconnected
[ 68.356] (--) NVIDIA(GPU-0): DFP-5: Internal TMDS
[ 68.356] (--) NVIDIA(GPU-0): DFP-5: 165.0 MHz maximum pixel clock
[ 68.356] (--) NVIDIA(GPU-0): Samsung C32HG7x (DFP-6): connected
[ 68.356] (--) NVIDIA(GPU-0): Samsung C32HG7x (DFP-6): Internal DisplayPort
[ 68.356] (--) NVIDIA(GPU-0): Samsung C32HG7x (DFP-6): 1440.0 MHz maximum pixel clock
[ 68.357] (--) NVIDIA(GPU-0): DFP-7: disconnected
[ 68.357] (--) NVIDIA(GPU-0): DFP-7: Internal TMDS
[ 68.357] (--) NVIDIA(GPU-0): DFP-7: 165.0 MHz maximum pixel clock
[ 68.595] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 68.595] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 68.595] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 68.624] (--) NVIDIA(GPU-0): Sceptre E20 (DFP-1): connected
[ 68.624] (--) NVIDIA(GPU-0): Sceptre E20 (DFP-1): Internal TMDS
[ 68.624] (--) NVIDIA(GPU-0): Sceptre E20 (DFP-1): 600.0 MHz maximum pixel clock
[ 68.624] (--) NVIDIA(GPU-0): Acer CB272 (DFP-2): connected
[ 68.624] (--) NVIDIA(GPU-0): Acer CB272 (DFP-2): Internal DisplayPort
[ 68.624] (--) NVIDIA(GPU-0): Acer CB272 (DFP-2): 1440.0 MHz maximum pixel clock
[ 68.627] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 68.627] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 68.627] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 68.627] (--) NVIDIA(GPU-0): Hisense HDMI (DFP-4): connected
[ 68.627] (--) NVIDIA(GPU-0): Hisense HDMI (DFP-4): Internal DisplayPort
[ 68.627] (--) NVIDIA(GPU-0): Hisense HDMI (DFP-4): 1440.0 MHz maximum pixel clock
[ 68.629] (--) NVIDIA(GPU-0): DFP-5: disconnected
[ 68.629] (--) NVIDIA(GPU-0): DFP-5: Internal TMDS
[ 68.629] (--) NVIDIA(GPU-0): DFP-5: 165.0 MHz maximum pixel clock
[ 68.629] (--) NVIDIA(GPU-0): Samsung C32HG7x (DFP-6): connected
[ 68.629] (--) NVIDIA(GPU-0): Samsung C32HG7x (DFP-6): Internal DisplayPort
[ 68.629] (--) NVIDIA(GPU-0): Samsung C32HG7x (DFP-6): 1440.0 MHz maximum pixel clock
[ 68.631] (--) NVIDIA(GPU-0): DFP-7: disconnected
[ 68.631] (--) NVIDIA(GPU-0): DFP-7: Internal TMDS
[ 68.631] (--) NVIDIA(GPU-0): DFP-7: 165.0 MHz maximum pixel clock
[ 68.667] (II) NVIDIA(0): Setting mode "DP-4: nvidia-auto-select @2560x1440 +1600+1080 {ViewPortIn=2560x1440, ViewPortOut=2560x1440+0+0}"
[ 68.712] (II) NVIDIA(0): Setting mode "HDMI-0: nvidia-auto-select @1600x900 +0+1175 {ViewPortIn=1600x900, ViewPortOut=1600x900+0+0}, DP-4: nvidia-auto-select @2560x1440 +1600+1080 {ViewPortIn=2560x1440, ViewPortOut=2560x1440+0+0}"
[ 68.794] (II) NVIDIA(0): Setting mode "HDMI-0: nvidia-auto-select @1600x900 +0+1175 {ViewPortIn=1600x900, ViewPortOut=1600x900+0+0}, DP-0: nvidia-auto-select @1080x1920 +4160+840 {ViewPortIn=1080x1920, ViewPortOut=1920x1080+0+0, Rotation=270}, DP-4: nvidia-auto-select @2560x1440 +1600+1080 {ViewPortIn=2560x1440, ViewPortOut=2560x1440+0+0}"
[ 68.994] (II) NVIDIA(0): Setting mode "HDMI-0: nvidia-auto-select @1600x900 +0+1175 {ViewPortIn=1600x900, ViewPortOut=1600x900+0+0}, DP-0: nvidia-auto-select @1080x1920 +4160+840 {ViewPortIn=1080x1920, ViewPortOut=1920x1080+0+0, Rotation=270}, DP-2: nvidia-auto-select @1920x1080 +1753+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}, DP-4: nvidia-auto-select @2560x1440 +1600+1080 {ViewPortIn=2560x1440, ViewPortOut=2560x1440+0+0}"
[ 143.196] (EE) event18 - Logitech G413 Silver Mechanical Gaming Keyboard: client bug: event processing lagging behind by 26ms, your system is too slow
[ 207.370] (EE) event18 - Logitech G413 Silver Mechanical Gaming Keyboard: client bug: event processing lagging behind by 13ms, your system is too slow
[ 216.842] (EE) event21 - Logitech USB Receiver: client bug: event processing lagging behind by 13ms, your system is too slow
[ 217.258] (EE) event21 - Logitech USB Receiver: client bug: event processing lagging behind by 11ms, your system is too slow
[ 217.442] (EE) event21 - Logitech USB Receiver: client bug: event processing lagging behind by 14ms, your system is too slow
[ 221.493] (EE) event21 - Logitech USB Receiver: client bug: event processing lagging behind by 11ms, your system is too slow
[ 614.943] (EE) event18 - Logitech G413 Silver Mechanical Gaming Keyboard: client bug: event processing lagging behind by 17ms, your system is too slow
[ 942.904] (EE) event21 - Logitech USB Receiver: client bug: event processing lagging behind by 15ms, your system is too slow
[ 943.054] (EE) event21 - Logitech USB Receiver: client bug: event processing lagging behind by 15ms, your system is too slow
[ 977.902] (EE) event21 - Logitech USB Receiver: client bug: event processing lagging behind by 13ms, your system is too slow
[ 978.162] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 978.162] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 978.162] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 978.192] (--) NVIDIA(GPU-0): Sceptre E20 (DFP-1): connected
[ 978.192] (--) NVIDIA(GPU-0): Sceptre E20 (DFP-1): Internal TMDS
[ 978.192] (--) NVIDIA(GPU-0): Sceptre E20 (DFP-1): 600.0 MHz maximum pixel clock
[ 978.193] (--) NVIDIA(GPU-0): Acer CB272 (DFP-2): connected
[ 978.193] (--) NVIDIA(GPU-0): Acer CB272 (DFP-2): Internal DisplayPort
[ 978.193] (--) NVIDIA(GPU-0): Acer CB272 (DFP-2): 1440.0 MHz maximum pixel clock
[ 978.195] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 978.195] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 978.195] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 978.195] (--) NVIDIA(GPU-0): Hisense HDMI (DFP-4): connected
[ 978.195] (--) NVIDIA(GPU-0): Hisense HDMI (DFP-4): Internal DisplayPort
[ 978.196] (--) NVIDIA(GPU-0): Hisense HDMI (DFP-4): 1440.0 MHz maximum pixel clock
[ 978.198] (--) NVIDIA(GPU-0): DFP-5: disconnected
[ 978.198] (--) NVIDIA(GPU-0): DFP-5: Internal TMDS
[ 978.198] (--) NVIDIA(GPU-0): DFP-5: 165.0 MHz maximum pixel clock
[ 978.198] (--) NVIDIA(GPU-0): Samsung C32HG7x (DFP-6): connected
[ 978.198] (--) NVIDIA(GPU-0): Samsung C32HG7x (DFP-6): Internal DisplayPort
[ 978.198] (--) NVIDIA(GPU-0): Samsung C32HG7x (DFP-6): 1440.0 MHz maximum pixel clock
[ 978.200] (--) NVIDIA(GPU-0): DFP-7: disconnected
[ 978.200] (--) NVIDIA(GPU-0): DFP-7: Internal TMDS
[ 978.200] (--) NVIDIA(GPU-0): DFP-7: 165.0 MHz maximum pixel clock
[ 979.452] (EE) event21 - Logitech USB Receiver: client bug: event processing lagging behind by 15ms, your system is too slow
[ 981.957] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 981.957] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 981.957] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 981.986] (--) NVIDIA(GPU-0): Sceptre E20 (DFP-1): connected
[ 981.986] (--) NVIDIA(GPU-0): Sceptre E20 (DFP-1): Internal TMDS
[ 981.986] (--) NVIDIA(GPU-0): Sceptre E20 (DFP-1): 600.0 MHz maximum pixel clock
[ 981.987] (--) NVIDIA(GPU-0): Acer CB272 (DFP-2): connected
[ 981.987] (--) NVIDIA(GPU-0): Acer CB272 (DFP-2): Internal DisplayPort
[ 981.987] (--) NVIDIA(GPU-0): Acer CB272 (DFP-2): 1440.0 MHz maximum pixel clock
[ 981.989] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 981.989] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 981.989] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 981.989] (--) NVIDIA(GPU-0): Hisense HDMI (DFP-4): connected
[ 981.989] (--) NVIDIA(GPU-0): Hisense HDMI (DFP-4): Internal DisplayPort
[ 981.989] (--) NVIDIA(GPU-0): Hisense HDMI (DFP-4): 1440.0 MHz maximum pixel clock
[ 981.992] (--) NVIDIA(GPU-0): DFP-5: disconnected
[ 981.992] (--) NVIDIA(GPU-0): DFP-5: Internal TMDS
[ 981.992] (--) NVIDIA(GPU-0): DFP-5: 165.0 MHz maximum pixel clock
[ 981.992] (--) NVIDIA(GPU-0): Samsung C32HG7x (DFP-6): connected
[ 981.992] (--) NVIDIA(GPU-0): Samsung C32HG7x (DFP-6): Internal DisplayPort
[ 981.992] (--) NVIDIA(GPU-0): Samsung C32HG7x (DFP-6): 1440.0 MHz maximum pixel clock
[ 981.993] (--) NVIDIA(GPU-0): DFP-7: disconnected
[ 981.993] (--) NVIDIA(GPU-0): DFP-7: Internal TMDS
[ 981.993] (--) NVIDIA(GPU-0): DFP-7: 165.0 MHz maximum pixel clock
[ 1263.112] (EE) event21 - Logitech USB Receiver: client bug: event processing lagging behind by 13ms, your system is too slow
[ 1263.195] (EE) event21 - Logitech USB Receiver: client bug: event processing lagging behind by 13ms, your system is too slow
Here’s the log just now, but I assume it’d be best to look at it after a fresh restart, or do you mean to have me try the nvidia settings refresh again, but report the log after it doesn’t boot?
Also, I’ll see if I can try to remove the script to test it.
