Not technical. Im so looking forward to using a Pinephone with KDE plasma. I am wondering what will be the preferred method of transferring photo from the phone to my Manjaro KDE laptop. A special app?
Normally, the MPT protocol ─ which is supported by every smartphone ─ should do well enough. You can install the android-file-transfer
package for a qt
-based user interface. And kdeconnect
─ which you should for good measure also install on the phone itself from the app store ─ should allow you to send SMS’s from your desktop/laptop.
