Applications which use GVFS, such as some file managers (GNOME Files, Thunar) or media players (Rhythmbox) can interact with iOS devices after installing the gvfs-afc and gvfs-gphoto2 packages. Restarting the file manager or application might be needed.
You’d probably have to use install the GVFS package. It automounts my android with that in my File Managers (Dolphin, Thunar, PCManFM)
Regarding why your phone isn’t pairing anymore… someone else will have to help with that since I don’t own an iPhone.
cool, that gvfs-gphoto2 helped!
Only thing is now, that the thumbnails of picture files in the iphone are not displayed anymore. (Preference Thumbnails set to All Files)
(on my usb stick for example thumbnails are shown)
i was having an issue earlier. I was using thunar to see my iphone. I copied everything to a new folder, and changed it back to Dolphin File Manager and the thumbnails appeared. It was an extra step but only takes 2 clicks
