Transaction fails due to adwaita-color-schemes dependency
Hello, I am unable to update a few applications due to an unable to satisfy dependency error. It is from a package called adwaita-color-schemes. I am not sure what the issue is. Log below. Any help is appreciated, thanks!
Preparing...
Refreshing AUR...
Checking qgnomeplatform-qt6 dependencies...
Cloning zoom build files...
Generating zoom information...
Checking zoom dependencies...
Cloning visual-studio-code-bin build files...
Generating visual-studio-code-bin information...
Checking visual-studio-code-bin dependencies...
Checking qgnomeplatform-qt5 dependencies...
Checking adwaita-qt6 dependencies...
Checking adwaita-color-schemes dependencies...
Warning: nano-syntax-highlighting: local (2020.10.10+10+g1aa64a8-2) is newer than extra (2020.10.10-2)
Resolving dependencies...
Checking inter-conflicts...
Building adwaita-qt...
==> Making package: adwaita-qt 1.4.2-1 (Fri 02 Aug 2024 09:50:42 AM PDT)
==> Retrieving sources...
  -> Found adwaita-qt5-1.4.2.tar.gz
    adwaita-qt5-1.4.2.tar.gz ... Passed
==> Extracting sources...
  -> Extracting adwaita-qt5-1.4.2.tar.gz with bsdtar
==> Starting build()...
CMake Warning (dev) at CMakeLists.txt:1 (project):
  cmake_minimum_required() should be called prior to this top-level project()
  call.  Please see the cmake-commands(7) manual for usage documentation of
  both commands.
This warning is for project developers.  Use -Wno-dev to suppress it.
-- The C compiler identification is GNU 14.1.1
-- The CXX compiler identification is GNU 14.1.1
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working C compiler: /usr/bin/cc - skipped
-- Detecting C compile features
-- Detecting C compile features - done
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Check for working CXX compiler: /usr/bin/c++ - skipped
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Found PkgConfig: /usr/bin/pkg-config (found version "2.1.1")
-- Found XCB: /usr/lib/libxcb.so (Required is at least version "1.10")
-- Configuring done (0.4s)
-- Generating done (0.0s)
-- Build files have been written to: /var/tmp/pamac-build-ian/adwaita-qt/src/build-qt5
[  0%] Built target adwaitaqtpriv_autogen_timestamp_deps
[  1%] Automatic MOC for target adwaitaqtpriv
[  1%] Built target adwaitaqtpriv_autogen
[  5%] Building CXX object src/lib/CMakeFiles/adwaitaqtpriv.dir/animations/adwaitaanimation.cpp.o
[  5%] Building CXX object src/lib/CMakeFiles/adwaitaqtpriv.dir/adwaitaqtpriv_autogen/mocs_compilation.cpp.o
[  7%] Building CXX object src/lib/CMakeFiles/adwaitaqtpriv.dir/animations/adwaitaanimations.cpp.o
[  9%] Building CXX object src/lib/CMakeFiles/adwaitaqtpriv.dir/animations/adwaitaanimationdata.cpp.o
[ 11%] Building CXX object src/lib/CMakeFiles/adwaitaqtpriv.dir/animations/adwaitabaseengine.cpp.o
[ 12%] Building CXX object src/lib/CMakeFiles/adwaitaqtpriv.dir/animations/adwaitabusyindicatordata.cpp.o
[ 14%] Building CXX object src/lib/CMakeFiles/adwaitaqtpriv.dir/animations/adwaitabusyindicatorengine.cpp.o
[ 16%] Building CXX object src/lib/CMakeFiles/adwaitaqtpriv.dir/animations/adwaitadialdata.cpp.o
[ 18%] Building CXX object src/lib/CMakeFiles/adwaitaqtpriv.dir/animations/adwaitadialengine.cpp.o
[ 20%] Building CXX object src/lib/CMakeFiles/adwaitaqtpriv.dir/animations/adwaitaenabledata.cpp.o
[ 22%] Building CXX object src/lib/CMakeFiles/adwaitaqtpriv.dir/animations/adwaitagenericdata.cpp.o
[ 24%] Building CXX object src/lib/CMakeFiles/adwaitaqtpriv.dir/animations/adwaitaheaderviewdata.cpp.o
[ 25%] Building CXX object src/lib/CMakeFiles/adwaitaqtpriv.dir/animations/adwaitaheaderviewengine.cpp.o
[ 27%] Building CXX object src/lib/CMakeFiles/adwaitaqtpriv.dir/animations/adwaitascrollbardata.cpp.o
[ 29%] Building CXX object src/lib/CMakeFiles/adwaitaqtpriv.dir/animations/adwaitascrollbarengine.cpp.o
[ 31%] Building CXX object src/lib/CMakeFiles/adwaitaqtpriv.dir/animations/adwaitaspinboxengine.cpp.o
[ 33%] Building CXX object src/lib/CMakeFiles/adwaitaqtpriv.dir/animations/adwaitaspinboxdata.cpp.o
[ 35%] Building CXX object src/lib/CMakeFiles/adwaitaqtpriv.dir/animations/adwaitastackedwidgetdata.cpp.o
[ 37%] Building CXX object src/lib/CMakeFiles/adwaitaqtpriv.dir/animations/adwaitastackedwidgetengine.cpp.o
[ 38%] Building CXX object src/lib/CMakeFiles/adwaitaqtpriv.dir/animations/adwaitatabbarengine.cpp.o
[ 40%] Building CXX object src/lib/CMakeFiles/adwaitaqtpriv.dir/animations/adwaitatabbardata.cpp.o
[ 42%] Building CXX object src/lib/CMakeFiles/adwaitaqtpriv.dir/animations/adwaitatoolboxengine.cpp.o
[ 44%] Building CXX object src/lib/CMakeFiles/adwaitaqtpriv.dir/animations/adwaitatransitiondata.cpp.o
[ 46%] Building CXX object src/lib/CMakeFiles/adwaitaqtpriv.dir/animations/adwaitatransitionwidget.cpp.o
[ 48%] Building CXX object src/lib/CMakeFiles/adwaitaqtpriv.dir/animations/adwaitawidgetstateengine.cpp.o
[ 50%] Building CXX object src/lib/CMakeFiles/adwaitaqtpriv.dir/animations/adwaitawidgetstatedata.cpp.o
[ 51%] Building CXX object src/lib/CMakeFiles/adwaitaqtpriv.dir/adwaitaaddeventfilter.cpp.o
[ 53%] Building CXX object src/lib/CMakeFiles/adwaitaqtpriv.dir/adwaitamnemonics.cpp.o
[ 55%] Building CXX object src/lib/CMakeFiles/adwaitaqtpriv.dir/adwaitasplitterproxy.cpp.o
[ 57%] Building CXX object src/lib/CMakeFiles/adwaitaqtpriv.dir/adwaitawidgetexplorer.cpp.o
[ 59%] Building CXX object src/lib/CMakeFiles/adwaitaqtpriv.dir/adwaitawindowmanager.cpp.o
[ 61%] Linking CXX shared library libadwaitaqtpriv.so
[ 62%] Built target adwaitaqtpriv
[ 62%] Built target adwaitaqt_autogen_timestamp_deps
[ 64%] Automatic MOC for target adwaitaqt
[ 64%] Built target adwaitaqt_autogen
[ 68%] Stylesheet variant: light
[ 68%] Stylesheet variant: dark
[ 72%] Stylesheet variant: hc-dark
[ 74%] Generating qrc_stylesheet.cpp
[ 75%] Building CXX object src/lib/CMakeFiles/adwaitaqt.dir/adwaitaqt_autogen/mocs_compilation.cpp.o
[ 77%] Building CXX object src/lib/CMakeFiles/adwaitaqt.dir/adwaita.cpp.o
[ 79%] Building CXX object src/lib/CMakeFiles/adwaitaqt.dir/adwaitacolors.cpp.o
[ 81%] Building CXX object src/lib/CMakeFiles/adwaitaqt.dir/adwaitarenderer.cpp.o
[ 83%] Building CXX object src/lib/CMakeFiles/adwaitaqt.dir/qrc_stylesheet.cpp.o
[ 85%] Linking CXX shared library libadwaitaqt.so
[ 87%] Built target adwaitaqt
[ 87%] Built target adwaita-qt_autogen_timestamp_deps
[ 88%] Automatic MOC for target adwaita-qt
[ 88%] Built target adwaita-qt_autogen
[ 92%] Building CXX object src/style/CMakeFiles/adwaita-qt.dir/adwaitahelper.cpp.o
[ 92%] Building CXX object src/style/CMakeFiles/adwaita-qt.dir/adwaita-qt_autogen/mocs_compilation.cpp.o
[ 94%] Building CXX object src/style/CMakeFiles/adwaita-qt.dir/adwaitastyle.cpp.o
[ 96%] Building CXX object src/style/CMakeFiles/adwaita-qt.dir/adwaitastyleplugin.cpp.o
[ 98%] Linking CXX shared module adwaita.so
[100%] Built target adwaita-qt
  both commands.
-- Performing Test CMAKE_HAVE_LIBC_PTHREAD
-- Performing Test CMAKE_HAVE_LIBC_PTHREAD - Success
-- Found Threads: TRUE
-- Performing Test HAVE_STDATOMIC
-- Performing Test HAVE_STDATOMIC - Success
-- Found WrapAtomic: TRUE
-- Found OpenGL: /usr/lib/libOpenGL.so
-- Found WrapOpenGL: TRUE
-- Found XKB: /usr/lib/libxkbcommon.so (found suitable version "1.7.0", minimum required is "0.5.0")
-- Found WrapVulkanHeaders: /usr/include
-- Configuring done (0.8s)
-- Build files have been written to: /var/tmp/pamac-build-ian/adwaita-qt/src/build-qt6
[  0%] Built target adwaitaqt6priv_autogen_timestamp_deps
[  1%] Automatic MOC for target adwaitaqt6priv
[  1%] Built target adwaitaqt6priv_autogen
[  5%] Building CXX object src/lib/CMakeFiles/adwaitaqt6priv.dir/animations/adwaitaanimation.cpp.o
[  5%] Building CXX object src/lib/CMakeFiles/adwaitaqt6priv.dir/adwaitaqt6priv_autogen/mocs_compilation.cpp.o
[  7%] Building CXX object src/lib/CMakeFiles/adwaitaqt6priv.dir/animations/adwaitaanimations.cpp.o
[  9%] Building CXX object src/lib/CMakeFiles/adwaitaqt6priv.dir/animations/adwaitaanimationdata.cpp.o
[ 11%] Building CXX object src/lib/CMakeFiles/adwaitaqt6priv.dir/animations/adwaitabaseengine.cpp.o
[ 12%] Building CXX object src/lib/CMakeFiles/adwaitaqt6priv.dir/animations/adwaitabusyindicatordata.cpp.o
[ 14%] Building CXX object src/lib/CMakeFiles/adwaitaqt6priv.dir/animations/adwaitabusyindicatorengine.cpp.o
[ 16%] Building CXX object src/lib/CMakeFiles/adwaitaqt6priv.dir/animations/adwaitadialdata.cpp.o
[ 18%] Building CXX object src/lib/CMakeFiles/adwaitaqt6priv.dir/animations/adwaitadialengine.cpp.o
[ 20%] Building CXX object src/lib/CMakeFiles/adwaitaqt6priv.dir/animations/adwaitaenabledata.cpp.o
[ 22%] Building CXX object src/lib/CMakeFiles/adwaitaqt6priv.dir/animations/adwaitagenericdata.cpp.o
[ 24%] Building CXX object src/lib/CMakeFiles/adwaitaqt6priv.dir/animations/adwaitaheaderviewdata.cpp.o
[ 25%] Building CXX object src/lib/CMakeFiles/adwaitaqt6priv.dir/animations/adwaitaheaderviewengine.cpp.o
[ 27%] Building CXX object src/lib/CMakeFiles/adwaitaqt6priv.dir/animations/adwaitascrollbardata.cpp.o
[ 29%] Building CXX object src/lib/CMakeFiles/adwaitaqt6priv.dir/animations/adwaitascrollbarengine.cpp.o
[ 31%] Building CXX object src/lib/CMakeFiles/adwaitaqt6priv.dir/animations/adwaitaspinboxengine.cpp.o
[ 33%] Building CXX object src/lib/CMakeFiles/adwaitaqt6priv.dir/animations/adwaitaspinboxdata.cpp.o
[ 35%] Building CXX object src/lib/CMakeFiles/adwaitaqt6priv.dir/animations/adwaitastackedwidgetdata.cpp.o
[ 37%] Building CXX object src/lib/CMakeFiles/adwaitaqt6priv.dir/animations/adwaitastackedwidgetengine.cpp.o
[ 38%] Building CXX object src/lib/CMakeFiles/adwaitaqt6priv.dir/animations/adwaitatabbarengine.cpp.o
[ 40%] Building CXX object src/lib/CMakeFiles/adwaitaqt6priv.dir/animations/adwaitatabbardata.cpp.o
[ 42%] Building CXX object src/lib/CMakeFiles/adwaitaqt6priv.dir/animations/adwaitatoolboxengine.cpp.o
[ 44%] Building CXX object src/lib/CMakeFiles/adwaitaqt6priv.dir/animations/adwaitatransitiondata.cpp.o
[ 46%] Building CXX object src/lib/CMakeFiles/adwaitaqt6priv.dir/animations/adwaitatransitionwidget.cpp.o
[ 48%] Building CXX object src/lib/CMakeFiles/adwaitaqt6priv.dir/animations/adwaitawidgetstateengine.cpp.o
[ 50%] Building CXX object src/lib/CMakeFiles/adwaitaqt6priv.dir/animations/adwaitawidgetstatedata.cpp.o
[ 51%] Building CXX object src/lib/CMakeFiles/adwaitaqt6priv.dir/adwaitaaddeventfilter.cpp.o
[ 53%] Building CXX object src/lib/CMakeFiles/adwaitaqt6priv.dir/adwaitamnemonics.cpp.o
[ 55%] Building CXX object src/lib/CMakeFiles/adwaitaqt6priv.dir/adwaitasplitterproxy.cpp.o
[ 57%] Building CXX object src/lib/CMakeFiles/adwaitaqt6priv.dir/adwaitawidgetexplorer.cpp.o
/var/tmp/pamac-build-ian/adwaita-qt/src/adwaita-qt-1.4.2/src/lib/adwaitasplitterproxy.cpp: In member function ‘void Adwaita::SplitterProxy::clearSplitter()’:
/var/tmp/pamac-build-ian/adwaita-qt/src/adwaita-qt-1.4.2/src/lib/adwaitasplitterproxy.cpp:312:67: warning: ‘QHoverEvent::QHoverEvent(QEvent::Type, const QPointF&, const QPointF&, Qt::KeyboardModifiers, const QPointingDevice*)’ is deprecated: Use the other constructor [-Wdeprecated-declarations]
  312 |             _splitter.data()->mapFromGlobal(QCursor::pos()), _hook);
In file included from /usr/include/qt6/QtGui/QHoverEvent:1,
                 from /var/tmp/pamac-build-ian/adwaita-qt/src/adwaita-qt-1.4.2/src/lib/adwaitasplitterproxy.h:27,
                 from /var/tmp/pamac-build-ian/adwaita-qt/src/adwaita-qt-1.4.2/src/lib/adwaitasplitterproxy.cpp:20:
/usr/include/qt6/QtGui/qevent.h:253:5: note: declared here
  253 |     QHoverEvent(Type type, const QPointF &pos, const QPointF &oldPos,
[ 59%] Building CXX object src/lib/CMakeFiles/adwaitaqt6priv.dir/adwaitawindowmanager.cpp.o
/var/tmp/pamac-build-ian/adwaita-qt/src/adwaita-qt-1.4.2/src/lib/adwaitawindowmanager.cpp: In member function ‘bool Adwaita::AppEventFilter::appMouseEvent(QObject*, QEvent*)’:
/var/tmp/pamac-build-ian/adwaita-qt/src/adwaita-qt-1.4.2/src/lib/adwaitawindowmanager.cpp:142:127: warning: ‘QMouseEvent::QMouseEvent(QEvent::Type, const QPointF&, Qt::MouseButton, Qt::MouseButtons, Qt::KeyboardModifiers, const QPointingDevice*)’ is deprecated: Use another constructor [-Wdeprecated-declarations]
  142 |         QMouseEvent mouseEvent(QEvent::MouseButtonRelease, _parent->_dragPoint, Qt::LeftButton, Qt::LeftButton, Qt::NoModifier);
In file included from /usr/include/qt6/QtGui/QMouseEvent:1,
                 from /var/tmp/pamac-build-ian/adwaita-qt/src/adwaita-qt-1.4.2/src/lib/adwaitawindowmanager.cpp:63:
/usr/include/qt6/QtGui/qevent.h:200:5: note: declared here
  200 |     QMouseEvent(Type type, const QPointF &localPos, Qt::MouseButton button,
/var/tmp/pamac-build-ian/adwaita-qt/src/adwaita-qt-1.4.2/src/lib/adwaitawindowmanager.cpp: In member function ‘bool Adwaita::WindowManager::mousePressEvent(QObject*, QEvent*)’:
/var/tmp/pamac-build-ian/adwaita-qt/src/adwaita-qt-1.4.2/src/lib/adwaitawindowmanager.cpp:337:110: warning: ‘QMouseEvent::QMouseEvent(QEvent::Type, const QPointF&, Qt::MouseButton, Qt::MouseButtons, Qt::KeyboardModifiers, const QPointingDevice*)’ is deprecated: Use another constructor [-Wdeprecated-declarations]
  337 |     QMouseEvent localMouseEvent(QEvent::MouseMove, localPoint, Qt::LeftButton, Qt::LeftButton, Qt::NoModifier);
[ 61%] Linking CXX shared library libadwaitaqt6priv.so
[ 62%] Built target adwaitaqt6priv
[ 62%] Built target adwaitaqt6_autogen_timestamp_deps
[ 64%] Automatic MOC for target adwaitaqt6
[ 64%] Built target adwaitaqt6_autogen
[ 66%] Stylesheet variant: light
[ 77%] Building CXX object src/lib/CMakeFiles/adwaitaqt6.dir/adwaita.cpp.o
[ 77%] Building CXX object src/lib/CMakeFiles/adwaitaqt6.dir/adwaitaqt6_autogen/mocs_compilation.cpp.o
[ 79%] Building CXX object src/lib/CMakeFiles/adwaitaqt6.dir/adwaitacolors.cpp.o
[ 81%] Building CXX object src/lib/CMakeFiles/adwaitaqt6.dir/adwaitarenderer.cpp.o
[ 83%] Building CXX object src/lib/CMakeFiles/adwaitaqt6.dir/qrc_stylesheet.cpp.o
[ 85%] Linking CXX shared library libadwaitaqt6.so
[ 87%] Built target adwaitaqt6
==> Entering fakeroot environment...
==> Starting package_adwaita-qt5()...
-- Install configuration: ""
-- Installing: /var/tmp/pamac-build-ian/adwaita-qt/pkg/adwaita-qt5/usr/lib/libadwaitaqtpriv.so.1.4.2
-- Installing: /var/tmp/pamac-build-ian/adwaita-qt/pkg/adwaita-qt5/usr/lib/libadwaitaqt.so.1.4.2
-- Set non-toolchain portion of runtime path of "/var/tmp/pamac-build-ian/adwaita-qt/pkg/adwaita-qt5/usr/lib/libadwaitaqt.so.1.4.2" to ""
-- Installing: /var/tmp/pamac-build-ian/adwaita-qt/pkg/adwaita-qt5/usr/include/AdwaitaQt/adwaita.h
-- Installing: /var/tmp/pamac-build-ian/adwaita-qt/pkg/adwaita-qt5/usr/include/AdwaitaQt/adwaitacolors.h
-- Installing: /var/tmp/pamac-build-ian/adwaita-qt/pkg/adwaita-qt5/usr/include/AdwaitaQt/adwaitarenderer.h
-- Installing: /var/tmp/pamac-build-ian/adwaita-qt/pkg/adwaita-qt5/usr/include/AdwaitaQt/adwaitaqt_export.h
-- Installing: /var/tmp/pamac-build-ian/adwaita-qt/pkg/adwaita-qt5/usr/lib/pkgconfig/adwaita-qt.pc
-- Installing: /var/tmp/pamac-build-ian/adwaita-qt/pkg/adwaita-qt5/usr/lib/cmake/AdwaitaQt/AdwaitaQtConfig.cmake
-- Installing: /var/tmp/pamac-build-ian/adwaita-qt/pkg/adwaita-qt5/usr/lib/cmake/AdwaitaQt/AdwaitaQtConfigVersion.cmake
-- Installing: /var/tmp/pamac-build-ian/adwaita-qt/pkg/adwaita-qt5/usr/lib/cmake/AdwaitaQt/AdwaitaQtTargets.cmake
-- Installing: /var/tmp/pamac-build-ian/adwaita-qt/pkg/adwaita-qt5/usr/lib/cmake/AdwaitaQt/AdwaitaQtTargets-noconfig.cmake
-- Installing: /var/tmp/pamac-build-ian/adwaita-qt/pkg/adwaita-qt5/usr/lib/qt/plugins/styles/adwaita.so
-- Set non-toolchain portion of runtime path of "/var/tmp/pamac-build-ian/adwaita-qt/pkg/adwaita-qt5/usr/lib/qt/plugins/styles/adwaita.so" to ""
==> Tidying install...
  -> Removing libtool files...
  -> Purging unwanted files...
  -> Removing static library files...
  -> Stripping unneeded symbols from binaries and libraries...
  -> Compressing man and info pages...
==> Checking for packaging issues...
==> Creating package "adwaita-qt5"...
  -> Generating .PKGINFO file...
  -> Generating .BUILDINFO file...
  -> Generating .MTREE file...
  -> Compressing package...
==> Starting package_adwaita-qt6()...
-- Installing: /var/tmp/pamac-build-ian/adwaita-qt/pkg/adwaita-qt6/usr/lib/libadwaitaqt6priv.so.1.4.2
-- Installing: /var/tmp/pamac-build-ian/adwaita-qt/pkg/adwaita-qt6/usr/lib/libadwaitaqt6.so.1.4.2
-- Set non-toolchain portion of runtime path of "/var/tmp/pamac-build-ian/adwaita-qt/pkg/adwaita-qt6/usr/lib/libadwaitaqt6.so.1.4.2" to ""
-- Installing: /var/tmp/pamac-build-ian/adwaita-qt/pkg/adwaita-qt6/usr/include/AdwaitaQt6/adwaita.h
-- Installing: /var/tmp/pamac-build-ian/adwaita-qt/pkg/adwaita-qt6/usr/include/AdwaitaQt6/adwaitacolors.h
-- Installing: /var/tmp/pamac-build-ian/adwaita-qt/pkg/adwaita-qt6/usr/include/AdwaitaQt6/adwaitarenderer.h
-- Installing: /var/tmp/pamac-build-ian/adwaita-qt/pkg/adwaita-qt6/usr/include/AdwaitaQt6/adwaitaqt_export.h
-- Installing: /var/tmp/pamac-build-ian/adwaita-qt/pkg/adwaita-qt6/usr/lib/pkgconfig/adwaita-qt6.pc
-- Installing: /var/tmp/pamac-build-ian/adwaita-qt/pkg/adwaita-qt6/usr/lib/cmake/AdwaitaQt6/AdwaitaQt6Config.cmake
-- Installing: /var/tmp/pamac-build-ian/adwaita-qt/pkg/adwaita-qt6/usr/lib/cmake/AdwaitaQt6/AdwaitaQt6ConfigVersion.cmake
-- Installing: /var/tmp/pamac-build-ian/adwaita-qt/pkg/adwaita-qt6/usr/lib/cmake/AdwaitaQt6/AdwaitaQt6Targets.cmake
-- Installing: /var/tmp/pamac-build-ian/adwaita-qt/pkg/adwaita-qt6/usr/lib/cmake/AdwaitaQt6/AdwaitaQt6Targets-noconfig.cmake
-- Installing: /var/tmp/pamac-build-ian/adwaita-qt/pkg/adwaita-qt6/usr/lib/qt6/plugins/styles/adwaita.so
-- Set non-toolchain portion of runtime path of "/var/tmp/pamac-build-ian/adwaita-qt/pkg/adwaita-qt6/usr/lib/qt6/plugins/styles/adwaita.so" to ""
==> Creating package "adwaita-qt6"...
==> Leaving fakeroot environment.
==> Finished making: adwaita-qt 1.4.2-1 (Fri 02 Aug 2024 09:51:50 AM PDT)
==> Cleaning up...
Failed to prepare transaction:
could not satisfy dependencies:
- unable to satisfy dependency 'adwaita-color-schemes' required by qgnomeplatform-qt6
Disclaimer: 1) AUR is not officially supported. 2) Your profile says stable, using aur on stable is even more unsupported. 3) Installing relatively important components like themes from aur is asking for trouble 4) Installing something from aur, which needs a bunch of other aur, is also generally a bad idea.
Reconsider if you really need all this and if it is worth the future problems that will arise from trying to force kde to be gnome (i am afraid that is just the beginning).
That said, have you tried to manually build adwaita-color-schemes first?
Okay I see. In that case, please disregard. I do not wish to use AUR.
