TrackPad Tricks?
I am experiencing some trackpad antics and don’t know where to start to exorcise them. All of sudden (after updating) my trackpad won’t accept a tap as a click but it moves the mouse? I thought it might be the hardware however my Manjaro (on microSD) works fine? Could I copy the nouse/trackpad configuration file from my microSD to SSD to fix the problem?
If so where is it?
I could just re-install but I thought I could learn something by fixing it.
Another oddity is my Dell P3551doesnt have the Manjaro grub menu? I probably should have addressed it when I first installed Manjaro, I made a timeshift backup but Dells BiOS is causing me anxiety.
Any suggestions are much appreciated.
About the trackpad issue, you can go to settings> Mouse & Touchpad and turn on the “Tap to Click” option! ( Also, I use GNOME, I’m not sure if things work the same way in KDE Plasma) (You can search for a similar option in your settings tho…)
That’s the problem. I can’t tap anything!I If I can find my wireless mouse I’ll see what happenss.
THNX…
this link might be helpful (it uses command line)
https://www.linuxquestions.org/questions/linux-laptop-and-netbook-25/manjaro-touchpad-tap-to-click-4175593004/
Thanks for the link.
I found my wireless mouse and it fixed the track-pad tricks.The settings weren’t changed and it just started working?
Now I have to find out why my graphics are inverted at startup. If I change the resolution it snaps backs to normal. Probably an Nvidia thing. Another post for another day.
Thanks for everyone’s help.
