Trackpad problem after resuming from suspend
Hello,
I am running 4.14.53-1-MANJARO with the KDE destop environment on a T440s thinkpad. I am experiencing trackpad problems, maybe someone has an idea how to tackle them?
Often (though not always) after resuming from suspend, my trackpad acts weirdly. Most noticeable, two or more finger gestures do not work anymore. I created a workaround with modprobe -r psmouse which seemed to solve the problem. After some days though, after issuing this command, my scrolling isn’t natural anymore. If I then go to System Settings > Touchpad, a notifiaction at the top comes up, saying:
Active settings don’t match saved settings. You currently see saved settings.
If I hit apply at the bottom of the window, everything works.
Anyone has any idea how to solve this or how to create a workaround for the natural scrolling similar to the modprobe -r psmouse?
Thanks for any kind of help!
sudo pacman -S fprintd                                        #D-Bus service to access fingerprint readers
Lenovo ThinkPad T440s
Power management/Suspend and hibernate
Thanks for replying.
I’m sorry if my explanation was not clear. By two or more finger gestures I mean double click if tapping with two fingers on the trackpad and middle click emulation if tapping with three. So I don’t think fprintd is of any relevance for me.
Thank you for the two links. However, I cannot extract any useful information from them.
This is a confirmed KDE bug here. I’ve been experiencing similar problems for quite some time and haven’t been able to find any good solution either.
Thanks @shivanshs9 for the link to the bug! I’ve found there
kcminit kcm_touchpad
which seems to be the workaround I’ve been looking for :slight_smile:
Glad to be of some help! :smiley:
Is this issue fixed? I have updated all latest packages but still have this issue.
Still unfixed on Manjaro 18.0.2 and kde Plasma 5.14.5
The link from @shivanshs9 refers to a bug fixed in 5.14. Maybe it is a similar bug or I don’t know why it is fixed there and not in Manjaro Plasma.
This service I wrote a few days back has a good likelihood of solving this issue.
Details here:
modprobe -r psmouse didn't work but modprobe psmouse worked :slight_smile:
