After suspend (shutting lid or sleep), the trackpad mouse no longer works. If I reboot it works fine.
Is there a command I can run to re-initialize the trackpad mouse?
Lenovo Slim 7 laptop.
In general: rmmod and modprobe
sudo modprobe -r psmouse && sleep 5 && sudo modprobe psmouse
while psmouse
is the module. that can differ.
And please no double posts. If you are working on Arch, then stick to that forum: trackpad mouse stops working on wake / Kernel & Hardware / Arch Linux Forums
That doesn’t work. I get an error.
Then try sudo rmmod i2c_hid && sudo modprobe i2c_hid
. And if you get an error, post what it says.
