Hi there,
I am quite new to Manjaro. I have Ambilight lighting system but it only starts once I run “sudo chmod 777 /dev/ttyUSB0”.
I want to know how to run an autoscript for this command to run at startup.
Thank you.
Paul
Hi there,
Thank you.
Paul
Hello,
Not quite sure why you want to do that. AFAIK hyperion
package does provide some ambilight functionality … but probably best is to use the hyperion.ng-git
package from AUR.
You can run from terminal:
pamac build hyperion.ng-git
For this part i rather recommend this, and should be straight forward:
Make a systemd unit like the following:
[Unit]
Description=Change chmod on /dev/ttyUSB0
After=multi-user.target
[Service]
Type=simple
ExecStart=/usr/bin/chmod 777 /dev/ttyUSB0
[Install]
WantedBy=multi-user.target
Make/save it, eg, as /etc/systemd/system/set-chmod.service
Then: systemctl daemon-reload
and systemctl enable --now set-chmod.service
: will start on every system startup; you can also manually execute it:
systemctl start set-chmod.service
Thank you very much Dave, this solved my problem and it was straight to the point.
I have tried installing Hyperion however I am not sure it has a GUI since I haven’t been able to run it. I installed all dependencies but I just don’t know how to run it.
