TP-Link TL-WN8200ND(UN) ver 2.20, USB is not recognized and set up on Manjaro 21 KDE iso
I’m sure there are drivers for this device as it uses common Realtek WiFi chip,
so recognizing this USB device and loading proper drivers should be nice on
new Manjaro ISO :slight_smile:
Someone from the team should make a PGKBUILD for this driver and the patch
But would be best if that team member has the device and can test it … On the other hand, it could be based on this http://aur.archlinux.org/packages/rtl8192eu but then you need base-devel, kernel headers and dkms by default in the ISO and also add the patch … not very convenient.
So, install the system and proceed to have it working.
Off course, it’s not a huge problem to make it work after installation, it just has no big reason not to work out of box for user experience and convenience, user friendliness and such :smiley:
If you have two of them, sending one to the devs would definitely help, as would donating the money it costs to the project
:bowing_man:
Therefore, I’ve marked this answer as the solution to your question as it is by far the best answer you’ll get.
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (If you disagree with my choice, just send me a personal message and explain why I shouldn’t have done this or :heart: or :+1: if you agree)
:innocent:
P.S. In the future, please don’t forget to come back and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
Solution
