I’ve installed Manjaro running KDE Plasma on a laptop I got yesterday, and everything seems to be working fine, except my touchscreen does not work at all (does not register that I have touched the screen at all, cursor position doesn’t change), and my brightness up and down buttons (F5 and F6 on my keyboard) do not register at all either when running it on xev.
From what it seems there doesn’t seem to be any touchscreen device in xinput? (output shown below)
What shows up when I run the command 'xinput list --long'
⎡ Virtual core pointer id=2 [master pointer (3)]
Reporting 7 classes:
Class originated from: 9. Type: XIButtonClass
Buttons supported: 10
Button labels: "Button Left" "Button Middle" "Button Right" "Button Wheel Up" "Button Wheel Down" "Button Horiz Wheel Left" "Button Horiz Wheel Right" None None None
Button state:
Class originated from: 9. Type: XIValuatorClass
Detail for Valuator 0:
Label: Rel X
Range: -1.000000 - -1.000000
Resolution: 0 units/m
Mode: relative
Detail for Valuator 1:
Label: Rel Y
Mode: relative
Detail for Valuator 2:
Label: Rel Horiz Scroll
Mode: relative
Detail for Valuator 3:
Label: Rel Vert Scroll
Mode: relative
Class originated from: 9. Type: XIScrollClass
Scroll info for Valuator 2
type: 2 (horizontal)
increment: 120.000000
flags: 0x0
Scroll info for Valuator 3
type: 1 (vertical)
flags: 0x0
⎜ ↳ Virtual core XTEST pointer id=4 [slave pointer (2)]
Reporting 3 classes:
Class originated from: 4. Type: XIButtonClass
Button state:
Class originated from: 4. Type: XIValuatorClass
Label: Rel X
Mode: relative
Label: Rel Y
Mode: relative
⎜ ↳ MSFT0001:01 04F3:3138 Mouse id=10 [slave pointer (2)]
Class originated from: 10. Type: XIButtonClass
Buttons supported: 7
Button state:
Class originated from: 10. Type: XIValuatorClass
Label: Rel X
Mode: relative
Label: Rel Y
Mode: relative
Mode: relative
Mode: relative
Class originated from: 10. Type: XIScrollClass
flags: 0x0
type: 1 (vertical)
flags: 0x0
⎜ ↳ MSFT0001:01 04F3:3138 Touchpad id=9 [slave pointer (2)]
Button state:
Label: Rel X
Mode: relative
Label: Rel Y
Mode: relative
Mode: relative
Mode: relative
flags: 0x0
type: 1 (vertical)
flags: 0x0
⎣ Virtual core keyboard id=3 [master keyboard (2)]
Reporting 1 classes:
Class originated from: 12. Type: XIKeyClass
Keycodes supported: 248
↳ Virtual core XTEST keyboard id=5 [slave keyboard (3)]
Class originated from: 5. Type: XIKeyClass
↳ Video Bus id=6 [slave keyboard (3)]
Class originated from: 6. Type: XIKeyClass
↳ Power Button id=7 [slave keyboard (3)]
Class originated from: 7. Type: XIKeyClass
↳ Integrated Camera: Integrated C id=8 [slave keyboard (3)]
Class originated from: 8. Type: XIKeyClass
↳ Ideapad extra buttons id=11 [slave keyboard (3)]
Class originated from: 11. Type: XIKeyClass
↳ AT Translated Set 2 keyboard id=12 [slave keyboard (3)]
System specs - 'inxi --admin --verbosity=7 --filter --width'
Kernel: 6.1.23-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=7b33fa44-40da-420c-9157-3fc9c7ea05d7 rw quiet
cryptdevice=UUID=14f6da74-4f88-4055-a726-2e7df0094149:luks-14f6da74-4f88-4055-a726-2e7df0094149
root=/dev/mapper/luks-14f6da74-4f88-4055-a726-2e7df0094149 splash
udev.log_priority=3 acpi_backlight=native
Desktop: KDE Plasma v: 5.27.4 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
Type: Convertible System: LENOVO product: 82BH v: Yoga 7 14ITL5
serial: <superuser required> Chassis: type: 31 v: Yoga 7 14ITL5
Mobo: LENOVO model: LNVNB161216 v: SDK0T76463 WIN
serial: <superuser required> UEFI: LENOVO v: F5CN59WW date: 11/25/2022
ID-1: BAT0 charge: 40.5 Wh (64.5%) condition: 62.8/71.0 Wh (88.4%)
volts: 15.8 min: 15.4 model: SMP L19M4PDC type: Li-poly serial: <filter>
status: discharging cycles: 274
RAM: total: 15.43 GiB used: 2.89 GiB (18.7%)
Info: model: 11th Gen Intel Core i7-1165G7 bits: 64 type: MT MCP
arch: Tiger Lake gen: core 11 level: v4 note: check built: 2020
process: Intel 10nm family: 6 model-id: 0x8C (140) stepping: 1
microcode: 0xA6
L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB desc: 4x1.2 MiB L3: 12 MiB
desc: 1x12 MiB
Speed (MHz): avg: 2574 high: 2800 min/max: 400/4700 scaling:
driver: intel_pstate governor: powersave cores: 1: 2800 2: 2800 3: 2800
4: 2800 5: 2800 6: 2800 7: 997 8: 2800 bogomips: 44864
arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
avx512_vnni avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd
avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts cat_l2
cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid cpuid_fault cx16
cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp hwp_act_window hwp_epp
hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b
movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm
rdt_a rdtscp rep_good sdbg sep sha_ni smap smep split_lock_detect ss ssbd
sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
tsc_adjust tsc_deadline_timer tsc_known_freq umip vaes vme vmx vnmi
vpclmulqdq vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB
filling, PBRSB-eIBRS: SW sequence
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Lenovo
driver: i915 v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21
ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4, HDMI-A-1, HDMI-A-2,
HDMI-A-3, HDMI-A-4 bus-ID: 0000:00:02.0 chip-ID: 8086:9a49 class-ID: 0300
Device-2: Bison Integrated Camera type: USB driver: uvcvideo bus-ID: 3-8:2
chip-ID: 5986:212a class-ID: 0e02
Display: x11 server: X.Org v: 21.1.8 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915 display-ID: :0
screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: ChiMei InnoLux 0x1432 built: 2020 res: 1920x1080
hz: 60 dpi: 158 gamma: 1.2 size: 309x173mm (12.17x6.81") diag: 354mm (13.9")
ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.6 Mesa 23.0.2 renderer: Mesa Intel Xe Graphics (TGL GT2)
direct-render: Yes
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Lenovo
driver: sof-audio-pci-intel-tgl
alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 0000:00:1f.3
chip-ID: 8086:a0c8 class-ID: 0401
API: ALSA v: k6.1.23-1-MANJARO status: kernel-api with: aoss
type: oss-emulator tools: alsamixer,amixer
Server-2: PipeWire v: 0.3.68 status: off with: wireplumber status: active
tools: pw-cli,wpctl
Server-3: PulseAudio v: 16.1 status: active tools: pacat,pactl
Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 0000:00:14.3
chip-ID: 8086:a0f0 class-ID: 0280
Device-1: Intel AX201 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-10:4
chip-ID: 8087:0026 class-ID: e001
Device-1: luks-14f6da74-4f88-4055-a726-2e7df0094149 maj-min: 254:0
type: LUKS dm: dm-0 size: 400.39 GiB
Components:
p-1: nvme0n1p4 maj-min: 259:4 size: 400.39 GiB
Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:9a0b rev: class-ID: 0104
Local Storage: total: 476.94 GiB used: 13.59 GiB (2.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: TeamGroup model: TM8FP4512G
lanes: 4 type: SSD serial: <filter> rev: ECFM12.3 temp: 29.9 C scheme: GPT
ID-1: / raw-size: 400.39 GiB size: 393.03 GiB (98.16%) used: 13.56 GiB (3.4%)
fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-14f6da74-4f88-4055-a726-2e7df0094149 label: N/A
uuid: 7b33fa44-40da-420c-9157-3fc9c7ea05d7
used: 29.5 MiB (30.7%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 8073-63E3
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 75.82 GiB fs: bitlocker
ID-3: /dev/nvme0n1p5 maj-min: 259:5 size: 625 MiB fs: ntfs label: N/A
uuid: 96FC6FA2FC6F7AFF
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 1 rev: 2.0
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 3-8:2 info: Bison Integrated Camera type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 5986:212a
class-ID: 0e02
Device-2: 3-9:3 info: LighTuning EgisTec EH576 type: <vendor specific>
driver: N/A interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 100mA
chip-ID: 1c7a:0576 class-ID: ff00 serial: <filter>
Device-3: 3-10:4 info: Intel AX201 Bluetooth type: Bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0026
class-ID: e001
Hub-4: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 40.0 C mobo: N/A
Processes: 240 Uptime: 15m wakeups: 2065 Init: systemd v: 252
default: graphical tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7
Packages: 1164 pm: pacman pkgs: 1159 libs: 328 tools: pamac pm: flatpak
pkgs: 5 Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.26
