I am unsure when it started, but after some update in the last month or two, when I rotate the display to portrait mode and use the stylus, the stylus position on screeen goes to the wrong position (as if it is still in landscape, so if I bring the stylus near the right side of the screen it puts the cursor on the top). It used to work perfectly fine before. Also, I can’t bring up the on screen keyboard when I touch the bottom of the screen.
Another set of issues I have had from the onset is that the screen does not autorotate, and the touchpad remains enabled even in “tablet mode” when I physically pivot the screen about its hinge. I previously was on XFCE desktop and had these issues as well and couldn’t even get the touchscreen to work, which is why I changed to gnome in the first place. I tried installing iio-sensor-proxy to rectify these issues, but to no avail.
Any and all help is greatly appreciated.
Output of inxi -Fazy
Kernel: 5.10.96-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=811cec17-7eec-496a-9a96-6051da30a639 rw quiet splash apparmor=1
security=apparmor resume=UUID=3ac62549-7017-4ea3-b062-a711fd221792
udev.log_priority=3
Desktop: GNOME 41.3 tk: GTK 3.24.31 wm: gnome-shell dm: GDM 41.3
Type: Laptop System: Google product: Akemi v: rev4
serial: <superuser required> Chassis: type: 9 serial: <superuser required>
Mobo: Google model: Akemi v: rev4 serial: <superuser required>
UEFI: coreboot v: MrChromebox-4.14 date: 07/25/2021
ID-1: BAT0 charge: 42.0 Wh (88.6%) condition: 47.4/51.2 Wh (92.5%)
volts: 8.2 min: 7.7 model: Sunwoda L19D4PG type: Li-ion serial: <filter>
status: Discharging cycles: 40
Device-1: hid-0018:27C6:0E36.0002-battery model: GDIX0000:00 27C6:0E36
serial: N/A charge: N/A status: N/A
Info: model: Intel Core i3-10110U bits: 64 type: MT MCP
arch: Comet/Whiskey Lake note: check family: 6 model-id: 0x8E (142)
stepping: 0xC (12) microcode: 0xEA
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 1000 min/max: 400/4100 scaling: driver: intel_pstate
governor: powersave cores: 1: 1000 2: 1000 3: 1000 4: 1000 bogomips: 20810
Type: srbds mitigation: TSX disabled
Device-1: Intel CometLake-U GT2 [UHD Graphics] driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:9b41 class-ID: 0300
Device-2: Acer Integrated Camera type: USB driver: uvcvideo bus-ID: 1-7:2
chip-ID: 5986:212e class-ID: 0e02
Display: wayland server: X.org 1.21.1.3 compositor: gnome-shell driver:
loaded: modesetting alternate: fbdev,vesa display-ID: 0
Device-1: Intel Comet Lake PCH-LP cAVS driver: sof-audio-pci
alternate: snd_hda_intel,snd_soc_skl,snd_sof_pci bus-ID: 00:1f.3
chip-ID: 8086:02c8 class-ID: 0401
Sound Server-1: ALSA v: k5.10.96-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.45 running: yes
Device-1: Intel Comet Lake PCH-LP CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:02f0 class-ID: 0280
bus-ID: 1-10:3 chip-ID: 8087:0026 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Local Storage: total: 119.24 GiB used: 78.51 GiB (65.8%)
model: MZALQ128HBHQ-000L2 size: 119.24 GiB block-size: physical: 512 B
rev: AL2QFXV7 temp: 31.9 C scheme: GPT
ID-1: / raw-size: 110.15 GiB size: 107.86 GiB (97.92%)
used: 78.51 GiB (72.8%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
dev: /dev/nvme0n1p3 maj-min: 259:3
System Temperatures: cpu: 44.0 C pch: 43.0 C mobo: N/A
Processes: 246 Uptime: 16m wakeups: 4314 Memory: 7.65 GiB
used: 2.62 GiB (34.2%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1339 lib: 417 flatpak: 0
Shell: Zsh v: 5.8 running-in: gnome-terminal inxi: 3.3.12
