Recently, in my laptop with Manjaro with XFCE touchscreen and mouse suddenly crashes. When it happens I can’t move anymore the pointer in the screen, it get stucked in the lower portion of the screen and can’t move. I appreciate your help. I didn´t experienced this before. It happens with Kernel with 5.17 and 5.15 previously installed and also tried with 5.18 and 5.19 and error persist. The more oldest kernel the more frequent issue experienced.
It happens randomly, using only touchscreen, using usb optical mouse, one app, many apps. Sometimes task manager starts appearing insistently before error occurs
journalctl --boot=-1 --priority=3 --catalog --no-pager
ago 29 06:50:47 semiramis kernel: Spectre V2 : WARNING: Unprivileged eBPF is enabled with eIBRS on, data leaks possible via Spectre v2 BHB attacks!
ago 29 06:50:47 semiramis kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.DGPV], AE_NOT_FOUND (20210730/psargs-330)
ago 29 06:50:47 semiramis kernel: ACPI Error: Aborting method \_SB.PCI0.RP05.PCRP._ON due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
ago 29 06:50:48 semiramis kernel: lis3lv02d: unknown sensor type 0x0
ago 29 06:50:49 semiramis dhcpcd[469]: no valid interfaces found
ago 29 06:50:56 semiramis lightdm[1112]: gkr-pam: unable to locate daemon control file
ago 29 06:54:52 semiramis kernel: watchdog: watchdog0: watchdog did not stop!
Hi, I found this similar topic without resolution. Of course there are more users experiencing this problem: for now, @kiboya and @Benasin
Also, I’m linking this another topic where @megavolt tried to help me, so I think this is all somehow related. I’ m trying to put all together here to find answers. Thanks in advance.
To give more info about my system I’ll paste more outputs based on above topic:
First, I don’ t have this file. In that directory I only have: 00-keyboard.conf
/etc/X11/xorg.conf.d/30-touchpad.conf
Hey, please. Problem stopped for a while but it came again and again. I installed KDE Plasma if it has to do with XFCE but nothing changes. I’m working well but suddenly my touchscreen goes crazy in the inner right corner and I can’t use the screen. I can only hardly use my keyboard because mouse makes movements and self clicks. In KDE Plasma I got this error:
coredumpctl info 3305
PID: 3305 (kscreen_osd_ser)
UID: 1000 (omnibus)
GID: 1000 (omnibus)
Signal: 11 (SEGV)
Timestamp: Sat 2022-11-05 07:11:51 CST (23min ago)
Command Line: /usr/lib/kscreen_osd_service
Executable: /usr/lib/kscreen_osd_service
Control Group: /user.slice/user-1000.slice/user@1000.service/background.slice/plasma-kscreen-osd.service
Unit: user@1000.service
User Unit: plasma-kscreen-osd.service
Slice: user-1000.slice
Owner UID: 1000 (omnibus)
Boot ID: 7a51dd6cb06e4d77a073a27a71627978
Machine ID: 4b977477d1f94b41a3f7e5a8c4e759d3
Hostname: semiramis
Storage: /var/lib/systemd/coredump/core.kscreen_osd_ser.1000.7a51dd6cb06e4d77a073a27a71627978.3305.1667653911000000.zst (present)
Disk Size: 3.7M
Message: Process 3305 (kscreen_osd_ser) of user 1000 dumped core.
Module linux-vdso.so.1 with build-id cc7c06b95a8fd3754824a9224780b913388b8bb4
Module libwebp.so.7 with build-id 96dd01a02a3b0b4dae0d744fc3200fd36f1c2148
Module libwebpdemux.so.2 with build-id 181ecf1a79aa805a45cce672f3f229570eca9f26
Module libwebpmux.so.3 with build-id c987ad73c6cbbfcdb4d632ead20256769852066e
Module libqwebp.so with build-id 725d6aeee464966be97e71ea125da887497e73f8
Module libqwbmp.so with build-id ebaf2ce77c046c0c2de405a8efd3a7367ba6fb5f
Module libtiff.so.5 with build-id 62a8aefb339c3cbe35d1089c66c527a7b090804c
Module libqtiff.so with build-id a8c7a67d7bfc70aec589e49d2640214d3f3ea0e2
Module libqtga.so with build-id 09befee394e2ae493cb3d0174ed7422b95c0ca1c
Module libqsvg.so with build-id e00dd7ced56a175eef4e4c63fab3faec7191d143
Module libQt5Pdf.so.5 with build-id a4e4fc8897f265f7a24b1d883d68147c0dcf1036
Module libqpdf.so with build-id 3dae34811999e0e7cfaff259afab2809dc58145c
Module liblcms2.so.2 with build-id c01e5649a38dbf37768d02dc751b52de0dcbd141
Module libmng.so.2 with build-id 2de13b8bba73f358ab2e323aa2209c2e2fc886e7
Module libqmng.so with build-id 8647deb2c743c3649f8b86158cb9ea4412460cd3
Module libqjpeg.so with build-id 084e64bc3e811ec381bcc51a86105cdb624997e9
Module libjpeg.so.8 with build-id 46dfd8b2cbe8a10d13cd3182a7b490d0959534f9
Module libjasper.so.6 with build-id 920c93104c2081399a4d6334e239cc0fa14bc4b2
Module libqjp2.so with build-id fa28f346f69d77d5377a79e206842165a6ea4880
Module libqico.so with build-id a43ca21df2fe1bc4fa39b49493a9bd7ec71db2c8
Module libqicns.so with build-id 9abf6684280e69a83a486248849775d27dddcaba
Module libqgif.so with build-id a6e54e41d1e766e702d2e4d4b8ce54e94291daf3
Module libwindowplugin.so with build-id 607f45b39ea2369baf25afdd70fba816c6fc25e1
Module libKF5Kirigami2.so.5 with build-id 9da45886e79d1d394d5471eee27e0181bdc368ea
Module libKirigamiPlugin.so with build-id 925ed09d941711ebed6c37b825f628d36a5fc8bd
Module libqtquicktemplates2plugin.so with build-id f4b00f294df9f8e45a2abca8a6b4423d74bed3c0
Module libplasmaextracomponentsplugin.so with build-id b3b09a7c0ad3bf95fb664a5a34bf580bf7d2b762
Module libxcb-res.so.0 with build-id cd3dbd6dd9e412a002d1be5ae0ec0d85650542ba
Module KF5WindowSystemX11Plugin.so with build-id 9750008551c84c8cd749a50df79be39e44ab8020
Module libQt5Sql.so.5 with build-id 612004f5350b4b351ff572542b62824ff96a23cb
Module libKF5Package.so.5 with build-id c50734cba9d1f13eeb2edeb51242061f8f766fa8
Module libKF5WaylandClient.so.5 with build-id 302dd5e044cf2504aaaa997d88e3772d644589b1
Module libOpenGL.so.0 with build-id 3df533822644f44fa89abdb75b9f89220dfdee56
Module libKF5Declarative.so.5 with build-id 8dd4af291129d1b2ea068ac3c5075c9e1369939a
Module libKF5Plasma.so.5 with build-id 1c5f32f73952a8904c68dbc3bd883c9f7614cac6
Module libEGL.so.1 with build-id 14389538015bb4a3a44e794e2466e31bf0834209
Module libxcb-composite.so.0 with build-id e8b69e2806d928f66445390cc50ab33a0b98bef0
Module libxcb-damage.so.0 with build-id d18fa3897f9041bfe25380abd9834332896cda81
Module libKF5QuickAddons.so.5 with build-id 37af8eae46213a682f971f71613eb285cb3b3a7c
Module libKF5PlasmaQuick.so.5 with build-id f91652fc44d01d83bb083526b60dcdb7e4b7255e
Module libcorebindingsplugin.so with build-id 53a1870ad4eb36211448334f1a8027eb1ddfaa62
Module libqquicklayoutsplugin.so with build-id 7a4113b6a11813d6e9be13985841de8c6824d775
Module libqtquickcontrols2plugin.so with build-id d977ec4fc318ca05a84a9fc7db1faad6ca4732d1
Module libQt5QmlWorkerScript.so.5 with build-id 38e5b4ffdd879132bcd64d5859e8649e72b1e9dc
Module libqtquick2plugin.so with build-id 550d613539501220da472cd367f7c65c834abe2d
Module libxml2.so.2 with build-id 171e32069b76d4cfedbfdf97f2087807948a9b3d
Module libncursesw.so.6 with build-id b9917757481e6fa6097e2a1f31f5bb5eaf138c4e
Module libedit.so.0 with build-id 4b0babfcad161c2ad0af6e59e2493258db23a331
Module libdrm_nouveau.so.2 with build-id 7e3a572a981d481c9e503d27f18d5cbe066e7db4
Module libdrm_amdgpu.so.1 with build-id 84c55b198afb267724c1d704a4a6384458446e28
Module libelf.so.1 with build-id 5ba0792747dce7480d031794ed90c620da72dbff
Module libdrm_radeon.so.1 with build-id 121a4f7e02db7ecdf8badd7aa64c6860aff121aa
Module libsensors.so.5 with build-id dc8b2c1c0d8525411aca188ea3cc3fb86d381d30
Module libLLVM-14.so with build-id 16d23f3ab6fb7269b2f13a9932a2a7ec4b1d5104
Module iris_dri.so with build-id 0b17a567605ce2c8f7104556d877a4db03733c74
Module libxcb-present.so.0 with build-id 8ed389d9cd6ad7110fbb00c93b32e0efaa71a6b1
Module libxcb-dri3.so.0 with build-id 088c750254cc139e7d62b8a3fc7795a138447ccf
Module libxshmfence.so.1 with build-id 132b07a9077d5068fc07934d2a447b03c35a5f55
Module libXxf86vm.so.1 with build-id b0dccf26256706727cd89edf8a562618d754b6ee
Module libxcb-dri2.so.0 with build-id 7bde0abc84135ae6258a8d1d130864071c2cc327
Module libdrm.so.2 with build-id 5b59e55b50556f6d541e4d73fd6a2dcfb1983894
Module libglapi.so.0 with build-id cbed20ec1e1b9b063317c45975da77915f9da138
Module libGLX_mesa.so.0 with build-id 448040a780989abc3c34b2d8a4af02865e709f6c
Module libxcb-glx.so.0 with build-id 71d5b6691f53a235696da49ffa2178d643ecc228
Module libqxcb-glx-integration.so with build-id a9ee30eef2f19532b08a6e6572737e0a6ecec96d
Module libcomposeplatforminputcontextplugin.so with build-id b7d75f89aa42cbf4504bce73360cd2bb3fe2535c
Module libdl.so.2 with build-id 414d1d630bc04818a150b9c73e4493f3395e8869
Module libgmp.so.10 with build-id 26cec2ebe94cc5c4cb99e6988717347222b324fd
Module libhogweed.so.6 with build-id 5c4a99ad0aabe13bd9b517f92ab339436a2bc1f2
Module libnettle.so.8 with build-id 6a26cbe6819abc8c57668f80ca8c8160fd85e29e
Module libunistring.so.2 with build-id 617dbf3d3d6f85d6556a7a036e23845e95490158
Module libidn2.so.0 with build-id b16e7570b102789b13ff77289762dbfe3f8f46bc
Module libbrotlienc.so.1 with build-id 74adbc62e4fbb5da9d37b5aa458471f4130862ff
Module libp11-kit.so.0 with build-id cc372ea3c28c4d3dfc633b4d2e933c8584d2af16
Module libogg.so.0 with build-id ca0cae30a809f10db1f16e54a23b4e5ff7b2c54c
Module libvorbis.so.0 with build-id f4e086347f6c1a66eb73cfe13974a29bd39aabca
Module libpthread.so.0 with build-id 3954d7fd57fa4db438d0ccdd8e2c6f7cc97c2e46
Module libusbmuxd-2.0.so.6 with build-id fd9f05e7f5b0da4e15972f75b61fd9b4b9f06dbe
Module libtasn1.so.6 with build-id fa2f7a5bfbcda1481ab5875d5744730ea1be8fb1
Module libgnutls.so.30 with build-id e849ad24d363553f5ddc88d43926e1ab2601ada9
Module libblkid.so.1 with build-id fb2c5d3c17aac74758a3eb80a2bc1c16bcf183b1
Module libXext.so.6 with build-id d7f3b1c9d5be6574b5faf83b74f8bba3d0dfa3c6
Module libltdl.so.7 with build-id 6a619e7b85ea9702e595881863bc9e599565e8a0
Module libtdb.so.1 with build-id f2bdb5ac97b6addf2026d93b08c8d15defcd9bb8
Module libvorbisfile.so.3 with build-id 45d2551167a616d448beb033ba49394831992887
Module libKF5DBusAddons.so.5 with build-id 03abf1c24e5a269ee395ad4099652feafb12be6f
Module libplist-2.0.so.3 with build-id f16bdd42b3d750ba0a150d286248f5dc50cc76cb
Module libimobiledevice-1.0.so.6 with build-id bc258677480403cc2df4f0efcfc97e06af826ddc
Module libudev.so.1 with build-id 239ca4dad8e4e0711b19826feabd72d58270942e
Module libKF5Archive.so.5 with build-id 784b900eebadfb900b9f958788fb5c1f99cec2b8
Module libQt5Svg.so.5 with build-id 7db0284946e4871e7f9effc797f1dee6b7cb1be6
Module libQt5PrintSupport.so.5 with build-id 9fa154675ddc5fbbb81c273ceb2dc49eaa03fdb3
Module libKF5GlobalAccel.so.5 with build-id 58892df8bbd414c674c37405b389d9e38ef904cb
Module libmount.so.1 with build-id 9064fc3620c42e6f7aed38119f0a3ec39fca9a37
Module libacl.so.1 with build-id 27869ed0219ade5d2ffd50eaee11f967187faa8b
Module libKF5AuthCore.so.5 with build-id e8c3961a260b70043d5543749b7ce3bd144709d7
Module libKF5Crash.so.5 with build-id 63a18381ba033fcc9d55aedcd43b520fe04b3ecc
Module libQt5QuickTemplates2.so.5 with build-id ef1e40831d52b364bb22c93e3155f3fb579f1fb4
Module libdbusmenu-qt5.so.2 with build-id 346cd54093968d3de9e61cc329e9512d248dce18
Module libXtst.so.6 with build-id eaf941ac9100f7854ebc0d512979d2fc6e87d461
Module libQt5TextToSpeech.so.5 with build-id 593099f8617753c871f48e5951f368c3a863e1cf
Module libcanberra.so.0 with build-id 8ddef69c9b84a86062c88a59510639cd908fc6d3
Module libKF5Service.so.5 with build-id 48775fbc4bee84e539074c055290386ec37555a9
Module libQt5Xml.so.5 with build-id f67bcabb5df91d3dd74fb54fd53421bcd089b9f4
Module libKF5Codecs.so.5 with build-id 0b578cfe76a2b39f96ba7bc6df0ddd9be7c22ac7
Module libKF5GuiAddons.so.5 with build-id 500f3ce625ec0405128077cfd2ff1b03e301aaf0
Module libKF5ItemViews.so.5 with build-id da9ae9155b462b4622737b62445d6a5ee4a4e2f4
Module libKF5KIOGui.so.5 with build-id 39d267ba908cd0c25c0f29483778f34c34aa477e
Module libKF5Solid.so.5 with build-id 4c3b06e1896b37ac7c92f0fee714d7da425040ba
Module libKF5Bookmarks.so.5 with build-id eac2902348e7f3cf50624eee40054c375870ff60
Module libKF5CoreAddons.so.5 with build-id 62326905c473db19337c7e01e790490ba70df854
Module libKF5ConfigCore.so.5 with build-id dea712f5c33eb84ced0e4dea973e8b687ae94f46
Module libKF5WidgetsAddons.so.5 with build-id a9a32bb7b20a4b655c7b984ec4e7285816386971
Module libKF5ConfigGui.so.5 with build-id 3f24792ea7987b59d73fbee76297ca00e42f00a0
Module libKF5ConfigWidgets.so.5 with build-id 7dc07957cb9e0b1c8b4f94cc4706132aca8a65d9
Module libKF5IconThemes.so.5 with build-id 84a935d8c24609b710db56c9cbc90bbe15b990b0
Module libKF5XmlGui.so.5 with build-id b2b06c04caed2139f99b5de3cb253e3aa0b64dcb
Module libKF5Completion.so.5 with build-id 6c0702106cae7afb0e5bbeede714d3d526358fd4
Module libKF5JobWidgets.so.5 with build-id 0c31576fdf79ff7e39ed60db7566fddde770e5e1
Module libKF5KIOCore.so.5 with build-id c1468f75ae5f45203c5abacab49b92a351b781e6
Module libQt5QuickControls2.so.5 with build-id cb27d61b09aa45ce43aeef8e025765452a153dc0
Module libKF5Notifications.so.5 with build-id 873c11b816ee7117d21e6dcf27f364a62a37c591
Module libKF5KIOWidgets.so.5 with build-id 822db0cc4c0ddebe052b89f6a3a27d5a35a01574
Module libKF5KIOFileWidgets.so.5 with build-id 9ef12b55f79d5a4fcab9247aa680900112b26ac2
Module KDEPlasmaPlatformTheme.so with build-id 5e08eb70da25c0eddc8f49722617584ddaa07081
Module libXfixes.so.3 with build-id 0a05c7e8714522bfbdd7c0027c3e2a94965664b0
Module libXrender.so.1 with build-id 9d6512ea1c9698e8c81f27e89fda57d36eb4b18e
Module libXcursor.so.1 with build-id f0525ae3715ac95f96a8cdb44795b03f831334b0
Module libuuid.so.1 with build-id 9057a530e6b3b0e71f24602a0039c490c9a0b5a1
Module libxcb-util.so.1 with build-id b1e4c01b388a3bd7a0a9ad384865b61f5f1d4a24
Module libxkbcommon-x11.so.0 with build-id 90654f41d9fe91c74bef6672a8b57ab34418b27a
Module libICE.so.6 with build-id a78252e65631a98d7935f1bca668c2fe1d6bbb53
Module libSM.so.6 with build-id 66cef8ae9a7848679be78dd26fd47e05110d03b5
Module libxcb-xinput.so.0 with build-id 409ee697e2b16243bf1fc6429e672f2359033388
Module libxcb-xkb.so.1 with build-id bad7e1eb65df04a6b2d676a08f68844856edaace
Module libxcb-xinerama.so.0 with build-id 5d2ab2683447d9bb7bcc49c058dfa06bcb65560d
Module libxcb-xfixes.so.0 with build-id e231a68d00ee4cfa12a2c31e755a9e2c1e7be450
Module libxcb-sync.so.1 with build-id 13025f6de23a271636ad321c77eda98801e62e8e
Module libxcb-shape.so.0 with build-id f9aab9846b5e3523bd534f8a845f36a37d42b3fa
Module libxcb-render.so.0 with build-id b1ca498d665807ab0ccdafbe8070853efd058173
Module libxcb-render-util.so.0 with build-id be7563af6c149b8412129d31bf3e262eb94b0efb
Module libxcb-randr.so.0 with build-id c914473ab7592ed5cf5c191200faaac1089c12ad
Module libxcb-shm.so.0 with build-id 828fec4d856e2710e732ea8d92c3f250c807b1c2
Module libxcb-image.so.0 with build-id f74049aed07d4b443711334c4d6692439c2595db
Module libxcb-icccm.so.4 with build-id 5d6f83a2aa185e59274a061f07b8a50b766445f8
Module libX11-xcb.so.1 with build-id f92352eae0a30aea89d11beb22367fa985288925
Module libQt5XcbQpa.so.5 with build-id 12d2bca39e8610215c70cfde3bfab531d34b8406
Module libqxcb.so with build-id 1fdbc58e0182862fe58a8b652b794def082a3ca0
Module libbrotlicommon.so.1 with build-id acfd597a977c8087bb6184383daae2e828a9ce42
Module libgpg-error.so.0 with build-id 470d76ceb1e53cb017f78c08936e9bafaeb4058b
Module libresolv.so.2 with build-id 2e70cfe9f2972fb13487eeefcb10e4afafed6157
Module libkeyutils.so.1 with build-id ac405ddd17be10ce538da3211415ee50c8f8df79
Module libkrb5support.so.0 with build-id 9a22a372b2157fb05da1bad94b92d9617513af81
Module libcom_err.so.2 with build-id 3360a28740ffbbd5a5c0c21d09072445908707e5
Module libk5crypto.so.3 with build-id 47d53a3ea2b172eb3db1be0ae0272c7c045267e8
Module libkrb5.so.3 with build-id 1fc969c1f54103d87e400237751b4804569a2730
Module libbrotlidec.so.1 with build-id 66c54e9301f7e102ecc1d88547e5f0e8a056fe22
Module libbz2.so.1.0 with build-id 919597c477c9b2cb9cdbb7745ed6494ac0e6da60
Module libexpat.so.1 with build-id a98bfab551dfa3df6889c33d5fd2ccfa6d505608
Module libpcre2-8.so.0 with build-id 917fc43d2c9f8539a3e324555c6c73886e8000a8
Module libicudata.so.72 with build-id a133b365160fc45e002163e5435f3029f4254cfa
Module liblz4.so.1 with build-id 84ea95d811dad359e94e100ebe6a746294ffe8a7
Module liblzma.so.5 with build-id 8a7334fec02fef6a82ff641a68b3e3200a44a702
Module libgcrypt.so.20 with build-id 8bf3cb884124273640de797a3e77d86c98434ea4
Module libcap.so.2 with build-id 9b38b08de708f439a9d0a4f8b9914151bc8d4b50
Module libgraphite2.so.3 with build-id ce58945ebb55b86d3a4e717b6eae29efc4720d8e
Module libGLX.so.0 with build-id d2c37fb8ec3bc53c67c013b0c6ac63ec086c8883
Module libGLdispatch.so.0 with build-id 7879a881271650eff97c35aff7a8674859c5ae94
Module libcrypto.so.1.1 with build-id 7981ea3d69f3c28e46ee312a815af96eab93775c
Module libssl.so.1.1 with build-id e6b1f97a5b60b4248c49dfc5b11f53f281b507d0
Module libgssapi_krb5.so.2 with build-id a10eaeef6e9969e80048d247666a3af155716afc
Module libxkbcommon.so.0 with build-id 6cf66eead3fcc20fe5df10162bfbcdcdc8b2a183
Module libfreetype.so.6 with build-id f89dd5502e75aca28fb5c3ccd0dbd26fe822bfef
Module libfontconfig.so.1 with build-id 9e856b5b37a3f4f7176ad8f92b2123508c95406e
Module libwayland-cursor.so.0 with build-id 46a637dbcbb02d6712a201f177377b66598b9121
Module libffi.so.8 with build-id 5c6b22b6624dd486a0783dfe74fee085b626b573
Module libXdmcp.so.6 with build-id d864159ab0008415667db8d5f251696d75c90df2
Module libXau.so.6 with build-id d9d5e8277140f1a86d3a07d9b52b1703c0a2f9a8
Module ld-linux-x86-64.so.2 with build-id 22bd7a2c03d8cfc05ef7092bfae5932223189bc1
Module libglib-2.0.so.0 with build-id 49826f5cd4f784c8050176991d46fd93a5fcee9f
Module libzstd.so.1 with build-id ab54c2881f53ab314e134f3e08c76d504376dd5d
Module libpcre2-16.so.0 with build-id 8ad49680a3f743a5241632a400d0de30aeaa54dd
Module libicuuc.so.72 with build-id c2e0249a038bd0fe76e681ecd2b73951c65a0866
Module libicui18n.so.72 with build-id aec148964d10586dae138df84f087835382396f2
Module libdouble-conversion.so.3 with build-id 74bfa78f70f9ae1f759f0ae383fbc7f6f7faf6f8
Module libsystemd.so.0 with build-id 461d1674a5e4c71184837ae7a6a827c9570ada42
Module libmd4c.so.0 with build-id 2151dba72cdc9960097e6e960a58a2f03c8bb96e
Module libharfbuzz.so.0 with build-id 181bbb0db2bce74b6bd5ed66ee7dcbed96323d8b
Module libz.so.1 with build-id 5340199d53cb95e609028ce1143675c742ff4218
Module libpng16.so.16 with build-id 14d3b3cc9d61ec1b7c1f86bdf108218a99364945
Module libGL.so.1 with build-id 6f65953140bc8a2aba47c9d492658dc61891393e
Module libgcc_s.so.1 with build-id 85db482c4585a328d95ec41124337a967bb24d8f
Module libQt5Network.so.5 with build-id e375f270860de999955dd4910b4a6bf230acd1c7
Module libQt5QmlModels.so.5 with build-id 75ac4ba2a588a639d18be70e47f2b106930ac1a5
Module libdbus-1.so.3 with build-id 6d6e4846c8e56903b4fe7d992ae6bb30c8a20a9c
Module libQt5WaylandClient.so.5 with build-id 032f7f11d4e8511b03ff65222f387e69913adfbf
Module libwayland-client.so.0 with build-id 515c72111400d7bdbfbdfcec78d597e4986a5943
Module libm.so.6 with build-id 2c8ff1d29b255da5b7371efd5caf57444d622838
Module libQt5Widgets.so.5 with build-id c700b6b0b14c58b3d3943b2d413d6cda5e0d8975
Module libQt5X11Extras.so.5 with build-id 78547956b3be2e12eece7fa5e9fa9f161b022c50
Module libxcb-keysyms.so.1 with build-id bc0fb833936f8065a75216318f4d4fb7c51a8b00
Module libxcb.so.1 with build-id 13d677412a71468381b11092915d231f664d18d3
Module libX11.so.6 with build-id 21e886e968772b7964d646f54c1faecc56734de9
Module libc.so.6 with build-id 1e94beb079e278ac4f2c8bce1f53091548ea1584
Module libstdc++.so.6 with build-id 735a3d0cc7699fd69337361cba4aedb644b2a7ed
Module libQt5Core.so.5 with build-id 083f29a2d33003f77f7d03516313798698bc42af
Module libQt5Gui.so.5 with build-id b63602b780993f6ec111d5fb2c0ee187f42d14fa
Module libQt5Qml.so.5 with build-id 22231cfcf29a284259109c7862fb6e72406b131a
Module libQt5Quick.so.5 with build-id 7943b27c49d44215357f6219398a7b376dcf4cbd
Module libQt5DBus.so.5 with build-id 80839ec0184277ea0382ce3fdc7f84eaebb4dff9
Module libLayerShellQtInterface.so.5 with build-id 049e4864b324f0a4e44f7cc55b7e607a7d560493
Module libKF5Screen.so.7 with build-id 90ca44ff82582aad8c00dc742ef372f62e69400d
Module libKF5WindowSystem.so.5 with build-id 8ec18b141cfc9a0ee4ffe9f352fe26c60ffa4fc4
Module libKF5I18n.so.5 with build-id 6a91b57f66c86d2b080056c0195cf095311dad9e
Module kscreen_osd_service with build-id fc273e34a96de00cb5f6ca0e918ab76c2b44aaa2
Stack trace of thread 3305:
#0 0x00007f5733d426cf _ZN7QWindow10setVisibleEb (libQt5Gui.so.5 + 0x1426cf)
#1 0x00007f57338bd381 n/a (libQt5Core.so.5 + 0x2bd381)
#2 0x00007f57338bd724 _ZN7QObject9destroyedEPS_ (libQt5Core.so.5 + 0x2bd724)
#3 0x00007f57338b3cec _ZN7QObjectD2Ev (libQt5Core.so.5 + 0x2b3cec)
#4 0x00007f573519ac2a n/a (libKF5Screen.so.7 + 0x28c2a)
#5 0x000055890cc1a956 n/a (kscreen_osd_service + 0xa956)
#6 0x000055890cc1a9e5 n/a (kscreen_osd_service + 0xa9e5)
#7 0x00007f57338bd381 n/a (libQt5Core.so.5 + 0x2bd381)
#8 0x00007f57338bf8df _ZN6QTimer7timeoutENS_14QPrivateSignalE (libQt5Core.so.5 + 0x2bf8df)
#9 0x00007f57338b04c6 _ZN7QObject5eventEP6QEvent (libQt5Core.so.5 + 0x2b04c6)
#10 0x00007f573388cb88 _ZN16QCoreApplication15notifyInternal2EP7QObjectP6QEvent (libQt5Core.so.5 + 0x28cb88)
#11 0x00007f57338d6d53 _ZN14QTimerInfoList14activateTimersEv (libQt5Core.so.5 + 0x2d6d53)
#12 0x00007f57338d734a n/a (libQt5Core.so.5 + 0x2d734a)
#13 0x00007f573211687b g_main_context_dispatch (libglib-2.0.so.0 + 0x5587b)
#14 0x00007f573216d279 n/a (libglib-2.0.so.0 + 0xac279)
#15 0x00007f5732115132 g_main_context_iteration (libglib-2.0.so.0 + 0x54132)
#16 0x00007f57338d750c _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt5Core.so.5 + 0x2d750c)
#17 0x00007f573388532c _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5Core.so.5 + 0x28532c)
#18 0x00007f573388fe59 _ZN16QCoreApplication4execEv (libQt5Core.so.5 + 0x28fe59)
#19 0x000055890cc154db n/a (kscreen_osd_service + 0x54db)
#20 0x00007f573483c290 n/a (libc.so.6 + 0x23290)
#21 0x00007f573483c34a __libc_start_main (libc.so.6 + 0x2334a)
#22 0x000055890cc15685 n/a (kscreen_osd_service + 0x5685)
Stack trace of thread 3309:
#0 0x00007f573489c4b6 n/a (libc.so.6 + 0x834b6)
#1 0x00007f573489ecd0 pthread_cond_wait (libc.so.6 + 0x85cd0)
#2 0x00007f572670799e n/a (iris_dri.so + 0x10799e)
#3 0x00007f57266baf8c n/a (iris_dri.so + 0xbaf8c)
#4 0x00007f57267078cc n/a (iris_dri.so + 0x1078cc)
#5 0x00007f573489f8fd n/a (libc.so.6 + 0x868fd)
#6 0x00007f5734921a60 n/a (libc.so.6 + 0x108a60)
Stack trace of thread 3308:
Stack trace of thread 3307:
#0 0x00007f57349140bf __poll (libc.so.6 + 0xfb0bf)
#1 0x00007f5734f8020b n/a (libxcb.so.1 + 0xd20b)
#2 0x00007f5734f81ccd xcb_wait_for_event (libxcb.so.1 + 0xeccd)
#3 0x00007f572e92bf72 n/a (libQt5XcbQpa.so.5 + 0x61f72)
#4 0x00007f57336e42ba n/a (libQt5Core.so.5 + 0xe42ba)
Stack trace of thread 3310:
Stack trace of thread 3312:
Stack trace of thread 3311:
Stack trace of thread 3314:
Stack trace of thread 3313:
Stack trace of thread 3306:
#1 0x00007f573216d1df n/a (libglib-2.0.so.0 + 0xac1df)
#2 0x00007f5732115132 g_main_context_iteration (libglib-2.0.so.0 + 0x54132)
#3 0x00007f57338d750c _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt5Core.so.5 + 0x2d750c)
#4 0x00007f573388532c _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5Core.so.5 + 0x28532c)
#5 0x00007f57336e749f _ZN7QThread4execEv (libQt5Core.so.5 + 0xe749f)
#6 0x00007f5735108cba n/a (libQt5DBus.so.5 + 0x23cba)
#7 0x00007f57336e42ba n/a (libQt5Core.so.5 + 0xe42ba)
#8 0x00007f573489f8fd n/a (libc.so.6 + 0x868fd)
#9 0x00007f5734921a60 n/a (libc.so.6 + 0x108a60)
