Hey there,
I tried to run xinput_calibrator to set up my external monitor (w/ touchscreen) in Manjaro without any luck. Sadly it was working fine in PopOS or Mint.
I also tried to follow this guide but get stuck when running verbose mode as I don’t get any debug line.
Here is my inxi:
Kernel: 5.11.2-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-5.11-x86_64
root=UUID=3606155d-3089-42e2-9416-0f7f55d675bf ro quiet apparmor=1
Desktop: KDE Plasma 5.21.2 tk: Qt 5.15.2 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Laptop System: HUAWEI product: HLYL-WXX9 v: M1090 serial: <filter>
Mobo: HUAWEI model: HLYL-WXX9-PCB v: M1090 serial: <filter> UEFI: HUAWEI
v: 1.07 date: 12/14/2020
ID-1: BAT1 charge: 56.1 Wh condition: 56.4/54.9 Wh (103%) volts: 8.7/7.6
model: DYNAPACK HB6081V1ECW-22T type: Li-ion serial: <filter>
status: Unknown cycles: 5
Device-1: hidpp_battery_0 model: Logitech MX Ergo Multi-Device Trackball
serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: Discharging
RAM: total: 15.08 GiB used: 4.35 GiB (28.9%)
Info: 8-Core model: AMD Ryzen 7 4800H with Radeon Graphics bits: 64
type: MT MCP arch: Zen 2 family: 17 (23) model-id: 60 (96) stepping: 1
microcode: 8600104 L2 cache: 4 MiB bogomips: 92664
Speed: 1397 MHz min/max: 1400/2900 MHz boost: enabled Core speeds (MHz):
1: 1397 2: 1396 3: 1905 4: 1907 5: 1907 6: 1903 7: 1907 8: 1906 9: 1397
10: 1397 11: 1397 12: 1397 13: 1397 14: 1397 15: 4282 16: 4292
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs irperf lahf_lm
lbrv lm mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx
nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter
pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni
popcnt pse pse36 rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm svm_lock syscall tce topoext tsc tsc_scale umip v_vmsave_vmload vgif
vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt
xsaves
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW,
Device-1: AMD Renoir vendor: QUANTA driver: amdgpu v: kernel bus ID: 03:00.0
chip ID: 1002:1636 class ID: 0300
Device-2: Quanta ov9734_techfront_camera type: USB driver: uvcvideo
bus ID: 1-4:5 chip ID: 0408:1040 class ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver:
loaded: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa
display ID: :0 screens: 1
Screen-1: 0 s-res: 3929x2016 s-dpi: 96 s-size: 1038x532mm (40.9x20.9")
s-diag: 1166mm (45.9")
Monitor-1: eDP res: 1920x1080 hz: 60 dpi: 137 size: 355x199mm (14.0x7.8")
diag: 407mm (16")
Monitor-2: DisplayPort-0 res: 1920x1080 hz: 60 dpi: 141
size: 345x194mm (13.6x7.6") diag: 396mm (15.6")
OpenGL: renderer: AMD RENOIR (DRM 3.40.0 5.11.2-1-MANJARO LLVM 11.1.0)
v: 4.6 Mesa 20.3.4 direct render: Yes
Device-1: AMD vendor: QUANTA driver: snd_hda_intel v: kernel bus ID: 03:00.1
chip ID: 1002:1637 class ID: 0403
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor vendor: QUANTA
driver: N/A alternate: snd_pci_acp3x, snd_rn_pci_acp3x bus ID: 03:00.5
chip ID: 1022:15e2 class ID: 0480
Device-3: AMD Family 17h HD Audio vendor: QUANTA driver: snd_hda_intel
v: kernel bus ID: 03:00.6 chip ID: 1022:15e3 class ID: 0403
Sound Server: ALSA v: k5.11.2-1-MANJARO
Device-1: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
vendor: & Tele RSH driver: rtw_8822ce v: N/A modules: rtw88_8822ce
port: 2000 bus ID: 01:00.0 chip ID: 10ec:c822 class ID: 0280
Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
bus ID: 3-4:4 chip ID: 1358:c123 class ID: e001 serial: <filter>
Message: Required tool hciconfig not installed. Check --recommends
Local Storage: total: 476.94 GiB used: 70.18 GiB (14.7%)
model: PC SN730 SDBPNTY-512G-1027 size: 476.94 GiB block size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 rotation: SSD
serial: <filter> rev: 11120000 temp: 42.9 C scheme: GPT
ID-1: / raw size: 476.64 GiB size: 468.16 GiB (98.22%)
used: 70.18 GiB (15.0%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 3606155d-3089-42e2-9416-0f7f55d675bf
ID-2: /boot/efi raw size: 300 MiB size: 299.4 MiB (99.80%)
used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: BFA6-B0BB
ID-3: /run/timeshift/backup raw size: 476.64 GiB size: <superuser required>
used: <superuser required> fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
Message: No Unmounted partitions found.
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
speed: 480 Mb/s chip ID: 1d6b:0002 class ID: 0900
Hub-2: 1-1:2 info: Terminus USB 2.0 Hub ports: 4 rev: 2.0 speed: 480 Mb/s
chip ID: 1a40:0801 class ID: 0900
Device-1: 1-1.3:8 info: Silicon Works Multi-touch Device type: HID
driver: hid-multitouch,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s
chip ID: 29bd:4101 class ID: 0300
Device-2: 1-1.4:6 info: QinHeng CH340 serial converter
type: <vendor specific> driver: ch341,ch341-uart interfaces: 1 rev: 1.1
speed: 12 Mb/s chip ID: 1a86:7523 class ID: ff00
Device-3: 1-2:3 info: Holtek USB Gaming Keyboard type: Keyboard,HID
driver: hid-generic,usbhid interfaces: 3 rev: 1.1 speed: 12 Mb/s
chip ID: 04d9:a0f8 class ID: 0300
Device-4: 1-4:5 info: Quanta ov9734_techfront_camera type: Video
driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s chip ID: 0408:1040
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
chip ID: 1d6b:0003 class ID: 0900
Hub-4: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Device-1: 3-1:2 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
chip ID: 046d:c52b class ID: 0300
Device-2: 3-3:3 info: Shenzhen Goodix Fingerprint Reader
type: Communication,CDC-Data driver: N/A interfaces: 2 rev: 2.0
speed: 12 Mb/s chip ID: 27c6:5117 class ID: 0a00
Device-3: 3-4:4 info: Realtek Bluetooth Radio type: Bluetooth driver: btusb
interfaces: 2 rev: 1.0 speed: 12 Mb/s chip ID: 1358:c123 class ID: e001
serial: <filter>
Hub-5: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 58.5 C mobo: N/A gpu: amdgpu temp: 42.0 C
Processes: 339 Uptime: 1h 22m wakeups: 7 Init: systemd v: 247 Compilers:
gcc: 10.2.0 clang: 11.1.0 Packages: pacman: 1473 lib: 419 flatpak: 0
Shell: Bash v: 5.1.0 running in: konsole inxi: 3.3.01
xrandr output:
Screen 0: minimum 320 x 200, current 3929 x 2016, maximum 16384 x 16384
eDP connected primary 1920x1080+2009+0 (normal left inverted right x axis y axis) 355mm x 199mm
1920x1080 60.01*+
1680x1050 60.01
1280x1024 60.01
1440x900 60.01
1280x800 60.01
1280x720 60.01
1024x768 60.01
800x600 60.01
640x480 60.01
HDMI-A-0 disconnected (normal left inverted right x axis y axis)
DisplayPort-0 connected 1920x1080+0+936 (normal left inverted right x axis y axis) 345mm x 194mm
3840x2160 59.98 + 60.00 50.00 59.94 30.00 30.00 25.00 24.00 29.97 23.98
2560x1600 59.99
2560x1440 60.00
2048x1536 60.02
1920x1440 60.00
1856x1392 60.00
1792x1344 60.00
2048x1152 60.00
1920x1200 59.88
1920x1080 60.00* 50.00
1600x1200 60.00
1680x1050 59.95
1680x945 60.02
1400x1050 59.98
1600x900 60.00
1280x1024 60.02
1440x900 59.89
1280x960 60.00
1366x768 59.79
1360x768 60.02
1280x800 59.81
1280x768 59.87
1280x720 60.00 50.00 59.94
1024x768 60.00
1024x576 59.97
800x600 60.32 56.25
720x576 50.00
848x480 60.00
720x480 60.00 59.94
640x480 60.00 59.94
720x400 70.08
Oddly, when running xinput_calibrator --list it actually shows two devices:
Device "Silicon Works Multi-touch SW4101C Mouse" id=9
Device "Silicon Works Multi-touch SW4101C" id=19
The first (id=9) shows up in my input devices in system settings as game controller
Obviously I tried to run the calibrator for both without luck.
The touch function actually works and even the scrolling. It’s quite precise if I touch the bottom left angle of the display, as I get towards the center it starts messing up and if I touch the center it basically points to the top right corner of the display.
What should I do to get it working?
