Touchpad tap too sensitive
Hi all
I recently switched to KDE plasma from GNOME on Manjaro (via a fresh install). I have issues with my touchpad: Very often, the cursor will appear to be “stuck” on the screen and not move. More precisely, the cursor just doesn’t move from the place it’s currently at for a few seconds despite me moving my finger.
I suspected that the issue is that the sensitivity of the “tap to click” setting is too high (or just wrong), as sometimes when I move the cursor it would automatically e.g. switch focus to a window I was passing over select text on screen. However, I couldn’t figure out how to modify that. I’ve looked at the libinput documentation, but the only thing I see which may be related is the “Debugging pressure range” instructions, which is not applicable to my machine, with libinput measure touchpad-pressure returning
This device does not have the capabilities for pressure-based touch detection. Details: Device does not have ABS_PRESSURE or ABS_MT_PRESSURE
I’ve seen that somebody had a similar issue (Touchpad too sensitive) some 5 years ago, but unfortunately with no solution in the thread.
As I was running Manjaro with GNOME on the same laptop before, where the touchpad worked perfectly, I don’t think this is a hardware issue.
Any help is much appreciated.
`inxi -zv8`
inxi -zv8`
  Kernel: 7.1.13-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 16.2.1
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-7.1-x86_64
    root=UUID=7ae3bbab-12c3-42dd-b55a-dcabfefdd1ac rw rootflags=subvol=@
    quiet
    cryptdevice=UUID=62d56385-1306-4774-9762-b85e693f1bca:luks-62d56385-1306-4774-9762-b85e693f1bca
    root=/dev/mapper/luks-62d56385-1306-4774-9762-b85e693f1bca splash
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.7.4 tk: Qt v: N/A info: frameworks v: 6.29.0
  Type: Laptop System: ASUSTeK product: ASUS Zenbook 14 UX3405CA_UX3405CA
    v: 1.0 serial: <superuser required>
  Mobo: ASUSTeK model: UX3405CA v: 1.0 serial: <superuser required>
    uuid: <superuser required> Firmware: UEFI vendor: American Megatrends LLC.
    v: UX3405CA.314 date: 11/20/2025
  ID-1: BAT0 charge: 71.9 Wh (100%) condition: 71.9/75.1 Wh (95.7%)
    volts: 8.73 min: 7.97 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
    charging: status: full control: start: N/A end: 100% cycles: 43
  System RAM: total: 32 GiB available: 30.71 GiB used: 18 GiB (58.6%)
  Array-1: capacity: 64 GiB slots: 8 modules: 8 EC: None
  Device-1: Controller0-ChannelA type: LPDDR5 detail: synchronous
    size: 4 GiB speed: spec: 8400 MT/s actual: 7467 MT/s volts: curr: 0.5
    min: 0.5 max: 0.5 width (bits): data: 16 total: 16 manufacturer: SK Hynix
    part-no: H58G66CK8BX147 serial: N/A
  Device-2: Controller0-ChannelB type: LPDDR5 detail: synchronous
  Device-3: Controller0-ChannelC type: LPDDR5 detail: synchronous
  Device-4: Controller0-ChannelD type: LPDDR5 detail: synchronous
  Device-5: Controller1-ChannelA type: LPDDR5 detail: synchronous
  Device-6: Controller1-ChannelB type: LPDDR5 detail: synchronous
  Device-7: Controller1-ChannelC type: LPDDR5 detail: synchronous
  Device-8: Controller1-ChannelD type: LPDDR5 detail: synchronous
  Info: model: Intel Core Ultra 9 285H bits: 64 type: MCP arch: Arrow Lake
    level: v3 note: check built: 2024+ process: Intel 20a (2nm) family: 6
    model-id: 0xC5 (197) stepping: 2 microcode: 0x122
  Topology: cpus: 1x dies: 1 clusters: 9 cores: 16 smt: <unsupported> cache:
    L1: 1.6 MiB desc: d-10x32 KiB, 6x48 KiB; i-16x64 KiB L2: 28 MiB desc: 1x2
    MiB, 6x3 MiB, 2x4 MiB L3: 24 MiB desc: 1x24 MiB
  Speed (MHz): avg: 1702 min/max: 400/5400:4500:2500 scaling:
    driver: intel_pstate governor: powersave cores: 1: 1702 2: 1702 3: 1702
    4: 1702 5: 1702 6: 1702 7: 1702 8: 1702 9: 1702 10: 1702 11: 1702 12: 1702
    13: 1702 14: 1702 15: 1702 16: 1702 bogomips: 117964
    bts bus_lock_detect clflush clflushopt clwb cmov constant_tsc cpuid
    f16c flexpriority flush_l1d fma fpu fsgsbase fsrm fxsr gfni hfi ht hwp
    hwp_act_window hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt
    ida intel_pt invpcid lahf_lm lam lass lm mca mce md_clear mmx monitor
    movbe movdir64b movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe
    pcid pclmulqdq pconfig pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36
    pts rdpid rdrand rdseed rdtscp rep_good sdbg sep serialize sha_ni smap
    smep smx split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
    syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer
    tsc_known_freq umip user_shstk vaes vme vmx vnmi vpclmulqdq vpid waitpkg
    wbnoinvd x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
    conditional; PBRSB-eIBRS: Not affected; BHI: BHI_DIS_S
  Device-1: Intel Arrow Lake-P [Arc Pro 130T/140T] vendor: ASUSTeK
    driver: i915 v: kernel alternate: xe arch: Xe2-LPG process: TSMC n3 (3nm)
    built: 2025+ ports: active: HDMI-A-1,eDP-1 empty: DP-1,DP-2
    bus-ID: 00:02.0 chip-ID: 8086:7d51 class-ID: 0300
  Device-2: Shinetech USB2.0 FHD UVC WebCam driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-9:2 chip-ID: 3277:0055
  Display: wayland server: X.org v: 1.21.1.24 with: Xwayland v: 24.1.13
    alternate: fbdev,vesa dri: iris gpu: i915 d-rect: 3840x1200 display-ID: 0
  Monitor-1: HDMI-A-1 pos: primary,left model: Idek Iiyama PL2492H
    serial: <filter> built: 2024 res: mode: 1920x1080 hz: 100 scale: 100% (1)
    dpi: 93 gamma: 1.2 chroma: red: x: 0.651 y: 0.329 green: x: 0.310 y: 0.620
    blue: x: 0.149 y: 0.047 white: x: 0.314 y: 0.329
    size: 527x296mm (20.75x11.65") diag: 604mm (23.8") ratio: 16:9
    modes: 1920x1080, 1680x1050, 1280x1024, 1440x900, 1280x800, 1152x864,
    1280x720, 1024x768, 800x600, 720x576, 720x480, 640x480, 720x400
  Monitor-2: eDP-1 pos: right model: Samsung 0x41a0 built: 2022 res:
    mode: 1920x1200 hz: 60 scale: 100% (1) dpi: 161 gamma: 1.2 chroma: red:
    x: 0.682 y: 0.322 green: x: 0.235 y: 0.725 blue: x: 0.137 y: 0.047 white:
    x: 0.314 y: 0.329 size: 302x189mm (11.89x7.44") diag: 356mm (14")
    ratio: 16:10 modes: 1920x1200
    drv: iris x11: drv: iris
  API: OpenGL v: 4.6 vendor: intel mesa v: 26.2.2-arch1.1 glx-v: 1.4
    direct-render: yes renderer: Mesa Intel Graphics (ARL) device-ID: 8086:7d51
    memory: 29.99 GiB unified: yes display-ID: :1.0
  API: Vulkan v: 1.4.357 layers: 4 device: 0 type: integrated-gpu
    name: Intel Graphics (ARL) driver: mesa intel v: 26.2.2-arch1.1
    device-ID: 8086:7d51 surfaces: N/A
    wl: wayland-info x11: xdpyinfo,xprop
  Device-1: Intel Core Ultra 200H/200V Series Processors HD Audio
    vendor: ASUSTeK driver: sof-audio-pci-intel-mtl
    alternate: snd_sof_pci_intel_mtl,snd_hda_intel bus-ID: 00:1f.3
    chip-ID: 8086:7728 class-ID: 0401
  API: ALSA v: k7.1.13-2-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.6.8 status: active with: 1: pipewire-pulse
  Device-1: Intel Arrow Lake CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:7740 class-ID: 0280
  IF-ID-1: proton0 state: unknown speed: N/A duplex: N/A mac: N/A
  IP v4: <filter> type: noprefixroute scope: global
  IP v6: <filter> type: noprefixroute scope: global
  IF-ID-2: pvpnksintrf0 state: unknown speed: N/A duplex: N/A mac: <filter>
  Device-1: Intel driver: btusb v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 3-10:3 chip-ID: 8087:0037 class-ID: e001
  Device-1: luks-62d56385-1306-4774-9762-b85e693f1bca maj-min: 253:0
    type: LUKS dm: dm-0 size: 953.57 GiB
  Components:
  p-1: nvme0n1p2 maj-min: 259:2 size: 953.57 GiB
  Local Storage: total: 3.66 TiB used: 784.01 GiB (20.9%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Micron
    model: MTFDKBA1T0QGN-1BN1AABGA size: 953.87 GiB block-size: physical: 512 B
    fw-rev: V8MA000 temp: 56.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital
    model: WD30NDZW-11A8JS0 size: 2.73 TiB block-size: physical: 4096 B
    logical: 512 B type: USB rev: 3.1 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1
    tech: HDD rpm: 5400 serial: <filter> fw-rev: 1026 scheme: GPT
  ID-1: / raw-size: 953.57 GiB size: 953.57 GiB (100.00%)
    used: 253.63 GiB (26.6%) fs: btrfs dev: /dev/dm-0 maj-min: 253:0
    mapped: luks-62d56385-1306-4774-9762-b85e693f1bca label: N/A
    uuid: 7ae3bbab-12c3-42dd-b55a-dcabfefdd1ac
    used: 984 KiB (0.3%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: B1EC-32BC
  ID-3: /home raw-size: 953.57 GiB size: 953.57 GiB (100.00%)
  ID-4: /run/media/mivkov/BACKUP_LENOVO raw-size: 1000 GiB
    size: 983.24 GiB (98.32%) used: 530.38 GiB (53.9%) fs: ext4 dev: /dev/sda1
    maj-min: 8:1 label: BACKUP_LENOVO
    uuid: a8d61218-9812-417e-a904-69e22710ab1b
  ID-5: /var/cache raw-size: 953.57 GiB size: 953.57 GiB (100.00%)
  ID-6: /var/log raw-size: 953.57 GiB size: 953.57 GiB (100.00%)
  ID-1: /dev/sda2 maj-min: 8:2 size: 1.75 TiB fs: ext4 label: WD_free
    uuid: 9db1d608-7e3e-4845-8a84-70b8485548a8
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-2: 2-0:1 info: super-speed hub ports: 3 rev: 3.1
  Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 3-9:2 info: Shinetech USB2.0 FHD UVC WebCam type: video
    driver: uvcvideo interfaces: 5 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 power: 500mA chip-ID: 3277:0055 class-ID: fe01
    serial: <filter>
  Device-2: 3-10:3 info: Intel type: bluetooth driver: btusb interfaces: 2
    rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 100mA
  Device-1: 4-1:2 info: Western Digital Elements 2621 type: mass storage
    driver: usb-storage interfaces: 1 rev: 3.1 speed: 5 Gb/s (596.0 MiB/s)
    lanes: 1 mode: 3.2 gen-1x1 power: 896mA chip-ID: 1058:2621 class-ID: 0806
    serial: <filter>
  System Temperatures: cpu: 52.0 C mobo: N/A
  Fan Speeds (rpm): cpu: 2600 fan-1: 2479
  Packages: 1949 pm: pacman pkgs: 1931 libs: 408 tools: pamac pm: flatpak
    pkgs: 18
    1: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
    2: https://mirror.vinehost.net/manjaro/stable/$repo/$arch
    3: https://mirror.komelt.dev/manjaro/stable/$repo/$arch
    4: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
    5: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
    6: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
    7: https://mirrors.manjaro.org/repo/stable/$repo/$arch
    8: https://mirrors2.manjaro.org/stable/$repo/$arch
    9: https://mirrors.eric.ovh/manjaro/stable/$repo/$arch
    10: https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/stable/$repo/$arch
    11: https://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
    12: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
    13: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
    14: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
    15: http://ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
    16: https://mirror.init7.net/manjaro/stable/$repo/$arch
    17: https://ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
    18: https://mirror.dkm.cz/manjaro/stable/$repo/$arch
    19: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
    20: https://mirror.rabisu.com/mirrors/manjaro/stable/$repo/$arch
    21: https://mirror.bakertelekom.fr/manjaro/stable/$repo/$arch
    22: https://mirror.23m.com/manjaro/stable/$repo/$arch
    23: https://ftp.belnet.be/mirrors/manjaro/repos/stable/$repo/$arch
    24: https://mirrors.ft.uam.es/manjaro/stable/$repo/$arch
    25: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
    26: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
    27: https://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
    28: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
    29: https://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
    30: https://ipng.mm.fcix.net/manjaro/stable/$repo/$arch
    31: https://mirrors.netix.net/manjaro/stable/$repo/$arch
    32: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
    33: https://mirror1.sox.rs/manjaro/stable/$repo/$arch
    34: https://mirror.informatik.tu-freiberg.de/manjaro/stable/$repo/$arch
    35: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
    36: https://mirror.it4i.cz/manjaro/stable/$repo/$arch
    37: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
    38: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
    39: https://ftp.caliu.cat/manjaro/stable/$repo/$arch
    40: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
    41: https://manjaro.mirror.garr.it/manjaro/stable/$repo/$arch
    42: https://ftp.psnc.pl/linux/manjaro/stable/$repo/$arch
    43: https://distrohub.kyiv.ua/manjaro/stable/$repo/$arch
    44: https://fosszone.csd.auth.gr/manjaro/stable/$repo/$arch
    45: https://ftp.linux.org.tr/manjaro/stable/$repo/$arch
    46: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
    47: https://mirror.datacenter.by/pub/mirrors/manjaro/stable/$repo/$arch
    48: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
    49: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
    50: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
    51: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
    52: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
    53: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
    54: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    55: https://mirror.ourhost.az/manjaro/stable/$repo/$arch
    56: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
    57: https://muug.ca/mirror/manjaro/stable/$repo/$arch
    58: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
    59: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
    60: https://ba.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    61: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
    62: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
    63: http://ftp.dei.uc.pt/pub/linux/manjaro/stable/$repo/$arch
    64: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
    65: https://ftp.cc.uoc.gr/mirrors/linux/manjaro/stable/$repo/$arch
    66: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
    67: https://mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
    68: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
    69: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
    70: https://manjaro.mirror.liquidtelecom.com/stable/$repo/$arch
    71: https://mirror.hiesoft.net/manjaro/stable/$repo/$arch
    72: https://manjaro.grena.ge/stable/$repo/$arch
    73: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
    74: https://mirror.fcix.net/manjaro/stable/$repo/$arch
    75: https://mirrors.atlas.net.co/manjaro/stable/$repo/$arch
    76: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
    77: http://ossmirror.mycloud.services/os/linux/manjaro/stable/$repo/$arch
    78: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
    79: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
    80: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
    81: https://mirror.xeonbd.com/manjaro
`mhwd -li`
mhwd -li
> Installed PCI configs:
           video-linux            2024.05.06                true            PCI
`mhwd-kernel -li`
mhwd-kernel -li
Currently running: 7.1.13-2-MANJARO (linux71)
   * linux71
Kernel 7.1 is EOL. Switch to 7.2 or fall back to a LTS kernel. Maybe that already fixes the problem.
You can basically change the touchpad sensitivity in the system settings GUI. Did you try that?
I can modify the cursor speed, not the actual touchpad sensitivity, which appears may be too sensitive to distinguish a tap from a scroll.
I’ll give a newer kernel a try.
@mivkov
Unless there is a specific reason not to, the latest LTS kernel is generally recommended – currently, kernel 6.18 (LTS).
I tried out both 6.18 and 7.2, issue persists. It also persists with libinput 1.32.0.
Does the lagging only occur when you start moving the finger on the touchpad or also or exclusively during movement?
I think it’s most commonly when I start moving the finger after having it off the touchpad after a few seconds.
Kernel 7.3 is currently available. Some predict it will be the next LTS release (however, I personally think that kernel 7.4 is still a possibility for that honour).
To the point: See if 7.3 might improve things – it’s legitimately the “latest and greatest” in kernels.
I’ll give it a go, but I doubt it’ll be the issue.
As mentioned above, I used to run Manjaro with GNOME on the same machine, and it runs perfectly out of box with respect to the touchpad. I downloaded another iso and launched manjaro+gnome from a usb key to verify it (and double-check that both versions use the exact same version of libinput - they do.) Therefore, I think it must be something with the KDE Plasma config or settings.
Google AI suggests an issue with Wayland/KWin which seems to behave technically different than the GNOME compositor Mutter and may cause cursor lags on your specific hardware.
Maybe that helps to further pinpoint a solution?
As a kernel change hasn’t resolved the issue, perhaps a newer version of libinput might be worth trying? This would also mean switching to Testing or Unstable branch, as they both have libinput v1.32.0-1, whilst Stable branch is still on libinput v1.31.3-1. Ref: https://manjaristas.org/branch_compare?q=libinput
This can be easily done by switching branches. If you switch to Testing branch, Plasma will also be updated from v6.7.4 to v6.7.5.
If you choose to switch to Unstable branch, Plasma will be updated to v6.8.1.
To switch to Testing branch:
sudo pacman-mirrors -a -B testing && sudo pacman-mirrors -f && sudo pacman -Syyu
or, to switch to Unstable branch:
sudo pacman-mirrors -a -B unstable && sudo pacman-mirrors -f && sudo pacman -Syyu
To return to Stable branch:
sudo pacman-mirrors -a -B stable && sudo pacman-mirrors -f && sudo pacman -Syyuu
Note: the extra u is required to enable package downgrades when moving from Unstable to Testing or Stable, or from Testing to Stable
I’ve already tried libinput at 1.32.0 to no avail. As GNOME uses 1.31.1, that shouldn’t be the issue.
Still, it wouldn’t hurt to test if the issue has been fixed in Plasma 6.7.5 (Testing branch) or Plasma 6.8.1 (Unstable branch).
The problem could be related to kwin rather than libinput (since there seems to be no issue with libinput when using Gnome).
You can easily roll back to Stable branch afterwards by following the instructions I included earlier.
The issue persists on the Testing branch.
What did the libinput developers have to say on the matter? :eyes:
Presuming your Stable updates are current, all official Manjaro editions should still be using 1.31.3-1. If you feel that 1.31.1 works, you might try downgrading libinput temporarily to establish whether that version works for you on Plasma also.
mbn info libinput -q
Branch         : archlinux
Version        : 1.32.0-1
Repository     : extra
Build Date     : Thu 17 Sep 2026 23:57:00
Packager       : Jan Alexander Steffens (heftig) <heftig@archlinux.org>
Branch         : unstable
Version        : 1.32.0-1
Repository     : extra
Branch         : testing
Version        : 1.32.0-1
Repository     : extra
Branch         : stable
Version        : 1.31.3-1
Repository     : extra
Build Date     : Thu 04 Jun 2026 11:54:49
Basically, that there’s nothing really they can do about it.
I’m not sure I understand. The Plasma installation came with 1.31.3-1 too, just like GNOME. That wasn’t working for me, so I tried upgrading to 1.32.0, which also didn’t work. (I furthermore tried downgrading, too, to 1.29 I think, and that killed Plasma. It killed the session as soon as I logged in and I was promptly returned to the login screen. So don’t do that at home, kids.)
Did I misunderstand? I took the version 1.31.1 you mentioned as the version that worked for you, while 1.31.3-1 and above, have not.
I couldn’t find your report;
the closest I found was this, but it’s on a Debian platform:
There seem to be other possibly related reports, but as far as I delved, apparently nothing definitive.
Have you tested for the possibility of an environmental cause; perhaps a configuration issue limited to your User account?
The easiest way to rule that out is to create a new User, and determine whether the issue also follows you there – obviously, if it still happens, then it’s ruled out, but if it doesn’t, that opens up a new direction to diagnose.
Ah, dang, that’s on me, apologies. I messed up the versions when typing them up. What I meant is that GNOME uses the same version, 1.31.3-1, which is the one that works for me on GNOME, but not for Plasma. (And that I have also tried 1.32.0, where the issue persisted in Plasma, as well as a older one, which broke Plasma).
Did I get the wrong url? I meant to post the issue I raised (https://gitlab.freedesktop.org/libinput/libinput/-/work_items/1348).
It was a fresh install from scratch, would there really be use in making another user?
As a quick sanity check, have you tried temporarily disabling tap-to-click (via Plasma settings) to see if this freezing/lagging still occurs? I know this isn’t a solution, but might give a further clue.
With your earlier comment, it sounds to me like the trackpad isn’t sensitive enough, causing your finger to “skip” as you move it?
Yes, I have tried disabling “tap to click”. The lagging/delay still persists. With tap to click on, I experience phantom clicks while moving the cursor.
It’s less skipping and more of delayed notice that something’s happening. As if it doesn’t register my finger’s motion for a second or two.
